[PATCH 04/45] Correct space-after-tab in libfdt.h
Wed Jul 18 07:35:13 UTC 2018
There are a few places with a space before a tab in this file. Fix them.
Signed-off-by: Simon Glass <sjg at chromium.org>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/include/libfdt.h | 25 ++++++++++++-------------
 1 file changed, 12 insertions(+), 13 deletions(-)
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 78adb1232e..25311cbfe7 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -174,15 +174,15 @@ int fdt_next_subnode(const void *fdt, int offset);
 #define fdt_get_header(fdt, field) \
 	(fdt32_to_cpu(((const struct fdt_header *)(fdt))->field))
-#define fdt_magic(fdt) 			(fdt_get_header(fdt, magic))
+#define fdt_magic(fdt)			(fdt_get_header(fdt, magic))
 #define fdt_totalsize(fdt)		(fdt_get_header(fdt, totalsize))
 #define fdt_off_dt_struct(fdt)		(fdt_get_header(fdt, off_dt_struct))
 #define fdt_off_dt_strings(fdt)		(fdt_get_header(fdt, off_dt_strings))
 #define fdt_off_mem_rsvmap(fdt)		(fdt_get_header(fdt, off_mem_rsvmap))
 #define fdt_version(fdt)		(fdt_get_header(fdt, version))
-#define fdt_last_comp_version(fdt) 	(fdt_get_header(fdt, last_comp_version))
-#define fdt_boot_cpuid_phys(fdt) 	(fdt_get_header(fdt, boot_cpuid_phys))
-#define fdt_size_dt_strings(fdt) 	(fdt_get_header(fdt, size_dt_strings))
+#define fdt_last_comp_version(fdt)	(fdt_get_header(fdt, last_comp_version))
+#define fdt_boot_cpuid_phys(fdt)	(fdt_get_header(fdt, boot_cpuid_phys))
+#define fdt_size_dt_strings(fdt)	(fdt_get_header(fdt, size_dt_strings))
 #define fdt_size_dt_struct(fdt)		(fdt_get_header(fdt, size_dt_struct))
 #define __fdt_set_hdr(name) \
@@ -647,7 +647,7 @@ const char *fdt_get_alias(const void *fdt, const char *name);
  *	0, on success
  *		buf contains the absolute path of the node at
  *		nodeoffset, as a NUL-terminated string.
- * 	-FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag
+ *	-FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag
  *	-FDT_ERR_NOSPACE, the path of the given node is longer than (bufsize-1)
  *		characters and will not fit in the given buffer.
  *	-FDT_ERR_BADMAGIC,
@@ -677,11 +677,10 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen);
  * structure from the start to nodeoffset.
  * returns:
  *	structure block offset of the node at node offset's ancestor
  *		of depth supernodedepth (>=0), on success
-*	-FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of nodeoffset
+ *	-FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of nodeoffset
  *	-FDT_ERR_BADVERSION,
  *	-FDT_ERR_BADSTATE,
@@ -703,7 +702,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset,
  * returns:
  *	depth of the node at nodeoffset (>=0), on success
@@ -726,7 +725,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset);
  * returns:
  *	structure block offset of the parent of the node at nodeoffset
  *		(>=0), on success
@@ -766,7 +765,7 @@ int fdt_parent_offset(const void *fdt, int nodeoffset);
  *		 on success
  *	-FDT_ERR_NOTFOUND, no node matching the criterion exists in the
  *		tree after startoffset
@@ -813,7 +812,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle);
  *	1, if the node has a 'compatible' property, but it does not list
  *		the given string
  *	-FDT_ERR_NOTFOUND, if the given node has no 'compatible' property
- * 	-FDT_ERR_BADOFFSET, if nodeoffset does not refer to a BEGIN_NODE tag
+ *	-FDT_ERR_BADOFFSET, if nodeoffset does not refer to a BEGIN_NODE tag
@@ -850,7 +849,7 @@ int fdt_node_check_compatible(const void *fdt, int nodeoffset,
  *		 on success
2.13.7
