[PATCH 11/45] libfdt: Add fdt_setprop_inplace_namelen_partial
Wed Jul 18 07:35:20 UTC 2018
From: Maxime Ripard <maxime.ripard at free-electrons.com>
Add a function to modify inplace only a portion of a property..
This is especially useful when the property is an array of values, and you
want to update one of them without changing the DT size.
Acked-by: Simon Glass <sjg at chromium.org>
Reviewed-by: David Gibson <david at gibson.dropbear.id.au>
Signed-off-by: Maxime Ripard <maxime.ripard at free-electrons.com>
[dwg: Remove unnecessary unsigned qualifier, correct a comment]
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_wip.c | 29 +++++++++++++++++++++++++----
 cpukit/include/libfdt.h     | 21 +++++++++++++++++++++
 2 files changed, 46 insertions(+), 4 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_wip.c b/cpukit/dtc/libfdt/fdt_wip.c
index c5bbb68d32..6aaab39992 100644
--- a/cpukit/dtc/libfdt/fdt_wip.c
+++ b/cpukit/dtc/libfdt/fdt_wip.c
@@ -55,21 +55,42 @@
 #include "libfdt_internal.h"
+int fdt_setprop_inplace_namelen_partial(void *fdt, int nodeoffset,
+					const char *name, int namelen,
+					uint32_t idx, const void *val,
+					int len)
+	void *propval;
+	int proplen;
+	propval = fdt_getprop_namelen_w(fdt, nodeoffset, name, namelen,
+					&proplen);
+	if (!propval)
+		return proplen;
+	if (proplen < (len + idx))
+		return -FDT_ERR_NOSPACE;
+	memcpy((char *)propval + idx, val, len);
+	return 0;
 int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name,
 			const void *val, int len)
-	void *propval;
+	const void *propval;
 	int proplen;
-	propval = fdt_getprop_w(fdt, nodeoffset, name, &proplen);
+	propval = fdt_getprop(fdt, nodeoffset, name, &proplen);
 	if (! propval)
 		return proplen;
 	if (proplen != len)
-	memcpy(propval, val, len);
-	return 0;
+	return fdt_setprop_inplace_namelen_partial(fdt, nodeoffset, name,
+						   strlen(name), 0,
+						   val, len);
 static void _fdt_nop_region(void *start, int len)
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 0189350fb3..376e628150 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -1080,6 +1080,27 @@ int fdt_size_cells(const void *fdt, int nodeoffset);
+ * fdt_setprop_inplace_namelen_partial - change a property's value,
+ *                                       but not its size
+ * @fdt: pointer to the device tree blob
+ * @nodeoffset: offset of the node whose property to change
+ * @name: name of the property to change
+ * @namelen: number of characters of name to consider
+ * @idx: index of the property to change in the array
+ * @val: pointer to data to replace the property value with
+ * @len: length of the property value
+ * Identical to fdt_setprop_inplace(), but modifies the given property
+ * starting from the given index, and using only the first characters
+ * of the name. It is useful when you want to manipulate only one value of
+ * an array and you have a string that doesn't end with \0.
+					int len);
  * fdt_setprop_inplace - change a property's value, but not its size
2.13.7
