[PATCH 24/45] libfdt: Change names of sparse helper macros
Wed Jul 18 07:35:33 UTC 2018
From: David Gibson <david at gibson.dropbear.id.au>
The default libfdt_env.h (for POSIXish userland builds) supports sparse
checking.  It has a couple of helper macros, __force and __bitwise which
expand the relevant sparse attributes to enable checking for incorrect
or missing endian conversions.
Those are bad names: for one, leading underscores are supposed to be
reserved for the system libraries, and worse, some systems (including
RHEL7) do define those names already.
So change them to FDT_FORCE and FDT_BITWISE which are far less likely to
have collisions.
Suggested-by: Paolo Bonzini <pbonzini at redhat.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/include/libfdt_env.h | 26 +++++++++++++-------------
 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/cpukit/include/libfdt_env.h b/cpukit/include/libfdt_env.h
index 99f936dacc..952056cddf 100644
--- a/cpukit/include/libfdt_env.h
+++ b/cpukit/include/libfdt_env.h
@@ -58,16 +58,16 @@
 #ifdef __CHECKER__
-#define __force __attribute__((force))
-#define __bitwise __attribute__((bitwise))
+#define FDT_FORCE __attribute__((force))
+#define FDT_BITWISE __attribute__((bitwise))
 #else
-#define __force
-#define __bitwise
+#define FDT_FORCE
 #endif
-typedef uint16_t __bitwise fdt16_t;
-typedef uint32_t __bitwise fdt32_t;
-typedef uint64_t __bitwise fdt64_t;
+typedef uint16_t FDT_BITWISE fdt16_t;
+typedef uint32_t FDT_BITWISE fdt32_t;
+typedef uint64_t FDT_BITWISE fdt64_t;
 #define EXTRACT_BYTE(x, n)	((unsigned long long)((uint8_t *)&x)[n])
 #define CPU_TO_FDT16(x) ((EXTRACT_BYTE(x, 0) << 8) | EXTRACT_BYTE(x, 1))
@@ -80,29 +80,29 @@ typedef uint64_t __bitwise fdt64_t;
 static inline uint16_t fdt16_to_cpu(fdt16_t x)
-	return (__force uint16_t)CPU_TO_FDT16(x);
+	return (FDT_FORCE uint16_t)CPU_TO_FDT16(x);
 static inline fdt16_t cpu_to_fdt16(uint16_t x)
-	return (__force fdt16_t)CPU_TO_FDT16(x);
+	return (FDT_FORCE fdt16_t)CPU_TO_FDT16(x);
 static inline uint32_t fdt32_to_cpu(fdt32_t x)
-	return (__force uint32_t)CPU_TO_FDT32(x);
+	return (FDT_FORCE uint32_t)CPU_TO_FDT32(x);
 static inline fdt32_t cpu_to_fdt32(uint32_t x)
-	return (__force fdt32_t)CPU_TO_FDT32(x);
+	return (FDT_FORCE fdt32_t)CPU_TO_FDT32(x);
 static inline uint64_t fdt64_to_cpu(fdt64_t x)
-	return (__force uint64_t)CPU_TO_FDT64(x);
+	return (FDT_FORCE uint64_t)CPU_TO_FDT64(x);
 static inline fdt64_t cpu_to_fdt64(uint64_t x)
-	return (__force fdt64_t)CPU_TO_FDT64(x);
+	return (FDT_FORCE fdt64_t)CPU_TO_FDT64(x);
 #undef CPU_TO_FDT64
 #undef CPU_TO_FDT32
2.13.7
