[PATCH 30/45] libfdt: Remove leading underscores from identifiers
    Sebastian Huber
    Wed Jul 18 07:35:39 UTC 2018
From: David Gibson <david at gibson.dropbear.id.au>
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API).  This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system.  It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it.  In most
cases we move it to the end, as our new convention for marking internal
identifiers.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt.c             | 10 ++---
 cpukit/dtc/libfdt/fdt_ro.c          | 32 ++++++-------
 cpukit/dtc/libfdt/fdt_rw.c          | 90 ++++++++++++++++++-------------------
 cpukit/dtc/libfdt/fdt_sw.c          | 24 +++++-----
 cpukit/dtc/libfdt/fdt_wip.c         | 10 ++---
 cpukit/dtc/libfdt/libfdt_internal.h | 32 ++++++-------
 cpukit/include/fdt.h                |  6 +--
 cpukit/include/libfdt.h             | 30 ++++++-------
 cpukit/include/libfdt_env.h         |  6 +--
 9 files changed, 120 insertions(+), 120 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index 22286a1aae..fd13236736 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -88,7 +88,7 @@ const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int len)
 		    || ((offset + len) > fdt_size_dt_struct(fdt)))
 			return NULL;
-	return _fdt_offset_ptr(fdt, offset);
+	return fdt_offset_ptr_(fdt, offset);
 uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
@@ -141,7 +141,7 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
 	return tag;
-int _fdt_check_node_offset(const void *fdt, int offset)
+int fdt_check_node_offset_(const void *fdt, int offset)
 	if ((offset < 0) || (offset % FDT_TAGSIZE)
 	    || (fdt_next_tag(fdt, offset, &offset) != FDT_BEGIN_NODE))
@@ -150,7 +150,7 @@ int _fdt_check_node_offset(const void *fdt, int offset)
 	return offset;
-int _fdt_check_prop_offset(const void *fdt, int offset)
+int fdt_check_prop_offset_(const void *fdt, int offset)
 	    || (fdt_next_tag(fdt, offset, &offset) != FDT_PROP))
@@ -165,7 +165,7 @@ int fdt_next_node(const void *fdt, int offset, int *depth)
 	uint32_t tag;
 	if (offset >= 0)
-		if ((nextoffset = _fdt_check_node_offset(fdt, offset)) < 0)
+		if ((nextoffset = fdt_check_node_offset_(fdt, offset)) < 0)
 			return nextoffset;
 	do {
@@ -227,7 +227,7 @@ int fdt_next_subnode(const void *fdt, int offset)
 	return offset;
-const char *_fdt_find_string(const char *strtab, int tabsize, const char *s)
+const char *fdt_find_string_(const char *strtab, int tabsize, const char *s)
 	int len = strlen(s) + 1;
 	const char *last = strtab + tabsize - len;
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index 08de2cce67..ce17814b2b 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -55,7 +55,7 @@
 #include "libfdt_internal.h"
-static int _fdt_nodename_eq(const void *fdt, int offset,
+static int fdt_nodename_eq_(const void *fdt, int offset,
 			    const char *s, int len)
 	const char *p = fdt_offset_ptr(fdt, offset + FDT_TAGSIZE, len+1);
@@ -80,7 +80,7 @@ const char *fdt_string(const void *fdt, int stroffset)
 	return (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
-static int _fdt_string_eq(const void *fdt, int stroffset,
+static int fdt_string_eq_(const void *fdt, int stroffset,
 	const char *p = fdt_string(fdt, stroffset);
@@ -117,8 +117,8 @@ uint32_t fdt_get_max_phandle(const void *fdt)
 int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size)
 	FDT_CHECK_HEADER(fdt);
-	*address = fdt64_to_cpu(_fdt_mem_rsv(fdt, n)->address);
-	*size = fdt64_to_cpu(_fdt_mem_rsv(fdt, n)->size);
+	*address = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->address);
+	*size = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->size);
 	return 0;
@@ -126,12 +126,12 @@ int fdt_num_mem_rsv(const void *fdt)
 	int i = 0;
-	while (fdt64_to_cpu(_fdt_mem_rsv(fdt, i)->size) != 0)
+	while (fdt64_to_cpu(fdt_mem_rsv_(fdt, i)->size) != 0)
 		i++;
 	return i;
-static int _nextprop(const void *fdt, int offset)
+static int nextprop_(const void *fdt, int offset)
 	uint32_t tag;
 	int nextoffset;
@@ -166,7 +166,7 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset,
 	     (offset >= 0) && (depth >= 0);
 	     offset = fdt_next_node(fdt, offset, &depth))
 		if ((depth == 1)
-		    && _fdt_nodename_eq(fdt, offset, name, namelen))
+		    && fdt_nodename_eq_(fdt, offset, name, namelen))
 			return offset;
 	if (depth < 0)
@@ -232,11 +232,11 @@ int fdt_path_offset(const void *fdt, const char *path)
 const char *fdt_get_name(const void *fdt, int nodeoffset, int *len)
-	const struct fdt_node_header *nh = _fdt_offset_ptr(fdt, nodeoffset);
+	const struct fdt_node_header *nh = fdt_offset_ptr_(fdt, nodeoffset);
 	int err;
 	if (((err = fdt_check_header(fdt)) != 0)
-	    || ((err = _fdt_check_node_offset(fdt, nodeoffset)) < 0))
+	    || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))
 			goto fail;
 	if (len)
@@ -254,18 +254,18 @@ int fdt_first_property_offset(const void *fdt, int nodeoffset)
 	int offset;
-	if ((offset = _fdt_check_node_offset(fdt, nodeoffset)) < 0)
+	if ((offset = fdt_check_node_offset_(fdt, nodeoffset)) < 0)
 		return offset;
-	return _nextprop(fdt, offset);
+	return nextprop_(fdt, offset);
 int fdt_next_property_offset(const void *fdt, int offset)
-	if ((offset = _fdt_check_prop_offset(fdt, offset)) < 0)
+	if ((offset = fdt_check_prop_offset_(fdt, offset)) < 0)
 		return offset;
 const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
@@ -275,13 +275,13 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
 	int err;
 	const struct fdt_property *prop;
-	if ((err = _fdt_check_prop_offset(fdt, offset)) < 0) {
+	if ((err = fdt_check_prop_offset_(fdt, offset)) < 0) {
 		if (lenp)
 			*lenp = err;
 		return NULL;
-	prop = _fdt_offset_ptr(fdt, offset);
+	prop = fdt_offset_ptr_(fdt, offset);
 	if (lenp)
 		*lenp = fdt32_to_cpu(prop->len);
@@ -303,7 +303,7 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt,
 			offset = -FDT_ERR_INTERNAL;
 			break;
-		if (_fdt_string_eq(fdt, fdt32_to_cpu(prop->nameoff),
+		if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff),
 				   name, namelen))
 			return prop;
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 5c3a2bb0bc..9b829051e4 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -55,8 +55,8 @@
-static int _fdt_blocks_misordered(const void *fdt,
-			      int mem_rsv_size, int struct_size)
+static int fdt_blocks_misordered_(const void *fdt,
+				  int mem_rsv_size, int struct_size)
 	return (fdt_off_mem_rsvmap(fdt) < FDT_ALIGN(sizeof(struct fdt_header), 8))
 		|| (fdt_off_dt_struct(fdt) <
@@ -67,13 +67,13 @@ static int _fdt_blocks_misordered(const void *fdt,
 		    (fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt)));
-static int _fdt_rw_check_header(void *fdt)
+static int fdt_rw_check_header_(void *fdt)
 	if (fdt_version(fdt) < 17)
 		return -FDT_ERR_BADVERSION;
-	if (_fdt_blocks_misordered(fdt, sizeof(struct fdt_reserve_entry),
+	if (fdt_blocks_misordered_(fdt, sizeof(struct fdt_reserve_entry),
 		return -FDT_ERR_BADLAYOUT;
 	if (fdt_version(fdt) > 17)
@@ -84,20 +84,20 @@ static int _fdt_rw_check_header(void *fdt)
 #define FDT_RW_CHECK_HEADER(fdt) \
-		int __err; \
-		if ((__err = _fdt_rw_check_header(fdt)) != 0) \
-			return __err; \
+		int err_; \
+		if ((err_ = fdt_rw_check_header_(fdt)) != 0) \
+			return err_; \
-static inline int _fdt_data_size(void *fdt)
+static inline int fdt_data_size_(void *fdt)
 	return fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt);
-static int _fdt_splice(void *fdt, void *splicepoint, int oldlen, int newlen)
+static int fdt_splice_(void *fdt, void *splicepoint, int oldlen, int newlen)
 	char *p = splicepoint;
-	char *end = (char *)fdt + _fdt_data_size(fdt);
+	char *end = (char *)fdt + fdt_data_size_(fdt);
 	if (((p + oldlen) < p) || ((p + oldlen) > end))
 		return -FDT_ERR_BADOFFSET;
@@ -109,12 +109,12 @@ static int _fdt_splice(void *fdt, void *splicepoint, int oldlen, int newlen)
 	return 0;
-static int _fdt_splice_mem_rsv(void *fdt, struct fdt_reserve_entry *p,
+static int fdt_splice_mem_rsv_(void *fdt, struct fdt_reserve_entry *p,
 			       int oldn, int newn)
 	int delta = (newn - oldn) * sizeof(*p);
 	int err;
-	err = _fdt_splice(fdt, p, oldn * sizeof(*p), newn * sizeof(*p));
+	err = fdt_splice_(fdt, p, oldn * sizeof(*p), newn * sizeof(*p));
 	if (err)
 		return err;
 	fdt_set_off_dt_struct(fdt, fdt_off_dt_struct(fdt) + delta);
@@ -122,13 +122,13 @@ static int _fdt_splice_mem_rsv(void *fdt, struct fdt_reserve_entry *p,
 	return 0;
-static int _fdt_splice_struct(void *fdt, void *p,
+static int fdt_splice_struct_(void *fdt, void *p,
 	int delta = newlen - oldlen;
 	int err;
-	if ((err = _fdt_splice(fdt, p, oldlen, newlen)))
+	if ((err = fdt_splice_(fdt, p, oldlen, newlen)))
 		return err;
 	fdt_set_size_dt_struct(fdt, fdt_size_dt_struct(fdt) + delta);
@@ -136,20 +136,20 @@ static int _fdt_splice_struct(void *fdt, void *p,
 	return 0;
-static int _fdt_splice_string(void *fdt, int newlen)
+static int fdt_splice_string_(void *fdt, int newlen)
 	void *p = (char *)fdt
 		+ fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt);
 	int err;
-	if ((err = _fdt_splice(fdt, p, 0, newlen)))
+	if ((err = fdt_splice_(fdt, p, 0, newlen)))
 		return err;
 	fdt_set_size_dt_strings(fdt, fdt_size_dt_strings(fdt) + newlen);
 	return 0;
-static int _fdt_find_add_string(void *fdt, const char *s)
+static int fdt_find_add_string_(void *fdt, const char *s)
 	char *strtab = (char *)fdt + fdt_off_dt_strings(fdt);
 	const char *p;
@@ -157,13 +157,13 @@ static int _fdt_find_add_string(void *fdt, const char *s)
 	int err;
-	p = _fdt_find_string(strtab, fdt_size_dt_strings(fdt), s);
+	p = fdt_find_string_(strtab, fdt_size_dt_strings(fdt), s);
 	if (p)
 		/* found it */
 		return (p - strtab);
 	new = strtab + fdt_size_dt_strings(fdt);
-	err = _fdt_splice_string(fdt, len);
+	err = fdt_splice_string_(fdt, len);
 	if (err)
 		return err;
@@ -178,8 +178,8 @@ int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size)
 	FDT_RW_CHECK_HEADER(fdt);
-	re = _fdt_mem_rsv_w(fdt, fdt_num_mem_rsv(fdt));
-	err = _fdt_splice_mem_rsv(fdt, re, 0, 1);
+	re = fdt_mem_rsv_w_(fdt, fdt_num_mem_rsv(fdt));
+	err = fdt_splice_mem_rsv_(fdt, re, 0, 1);
 	if (err)
 		return err;
@@ -190,17 +190,17 @@ int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size)
 int fdt_del_mem_rsv(void *fdt, int n)
-	struct fdt_reserve_entry *re = _fdt_mem_rsv_w(fdt, n);
+	struct fdt_reserve_entry *re = fdt_mem_rsv_w_(fdt, n);
 	if (n >= fdt_num_mem_rsv(fdt))
 		return -FDT_ERR_NOTFOUND;
-	return _fdt_splice_mem_rsv(fdt, re, 1, 0);
+	return fdt_splice_mem_rsv_(fdt, re, 1, 0);
-static int _fdt_resize_property(void *fdt, int nodeoffset, const char *name,
+static int fdt_resize_property_(void *fdt, int nodeoffset, const char *name,
 				int len, struct fdt_property **prop)
 	int oldlen;
@@ -210,7 +210,7 @@ static int _fdt_resize_property(void *fdt, int nodeoffset, const char *name,
 	if (!*prop)
 		return oldlen;
-	if ((err = _fdt_splice_struct(fdt, (*prop)->data, FDT_TAGALIGN(oldlen),
+	if ((err = fdt_splice_struct_(fdt, (*prop)->data, FDT_TAGALIGN(oldlen),
 				      FDT_TAGALIGN(len))))
 		return err;
@@ -218,7 +218,7 @@ static int _fdt_resize_property(void *fdt, int nodeoffset, const char *name,
 	return 0;
-static int _fdt_add_property(void *fdt, int nodeoffset, const char *name,
+static int fdt_add_property_(void *fdt, int nodeoffset, const char *name,
 	int proplen;
@@ -226,17 +226,17 @@ static int _fdt_add_property(void *fdt, int nodeoffset, const char *name,
 	int namestroff;
 	int err;
-	if ((nextoffset = _fdt_check_node_offset(fdt, nodeoffset)) < 0)
+	if ((nextoffset = fdt_check_node_offset_(fdt, nodeoffset)) < 0)
 		return nextoffset;
-	namestroff = _fdt_find_add_string(fdt, name);
+	namestroff = fdt_find_add_string_(fdt, name);
 	if (namestroff < 0)
 		return namestroff;
-	*prop = _fdt_offset_ptr_w(fdt, nextoffset);
+	*prop = fdt_offset_ptr_w_(fdt, nextoffset);
 	proplen = sizeof(**prop) + FDT_TAGALIGN(len);
-	err = _fdt_splice_struct(fdt, *prop, 0, proplen);
+	err = fdt_splice_struct_(fdt, *prop, 0, proplen);
 	if (err)
 		return err;
@@ -260,7 +260,7 @@ int fdt_set_name(void *fdt, int nodeoffset, const char *name)
 	newlen = strlen(name);
-	err = _fdt_splice_struct(fdt, namep, FDT_TAGALIGN(oldlen+1),
+	err = fdt_splice_struct_(fdt, namep, FDT_TAGALIGN(oldlen+1),
 				 FDT_TAGALIGN(newlen+1));
 	if (err)
 		return err;
@@ -277,9 +277,9 @@ int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name,
-	err = _fdt_resize_property(fdt, nodeoffset, name, len, &prop);
+	err = fdt_resize_property_(fdt, nodeoffset, name, len, &prop);
 	if (err == -FDT_ERR_NOTFOUND)
-		err = _fdt_add_property(fdt, nodeoffset, name, len, &prop);
+		err = fdt_add_property_(fdt, nodeoffset, name, len, &prop);
 	if (err)
 		return err;
@@ -313,7 +313,7 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name,
 	prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen);
 	if (prop) {
 		newlen = len + oldlen;
-		err = _fdt_splice_struct(fdt, prop->data,
+		err = fdt_splice_struct_(fdt, prop->data,
 					 FDT_TAGALIGN(newlen));
 		if (err)
@@ -321,7 +321,7 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name,
 		prop->len = cpu_to_fdt32(newlen);
 		memcpy(prop->data + oldlen, val, len);
 	} else {
 		if (err)
 			return err;
 		memcpy(prop->data, val, len);
@@ -341,7 +341,7 @@ int fdt_delprop(void *fdt, int nodeoffset, const char *name)
 		return len;
 	proplen = sizeof(*prop) + FDT_TAGALIGN(len);
-	return _fdt_splice_struct(fdt, prop, proplen, 0);
+	return fdt_splice_struct_(fdt, prop, proplen, 0);
 int fdt_add_subnode_namelen(void *fdt, int parentoffset,
@@ -369,10 +369,10 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset,
 		tag = fdt_next_tag(fdt, offset, &nextoffset);
 	} while ((tag == FDT_PROP) || (tag == FDT_NOP));
-	nh = _fdt_offset_ptr_w(fdt, offset);
+	nh = fdt_offset_ptr_w_(fdt, offset);
 	nodelen = sizeof(*nh) + FDT_TAGALIGN(namelen+1) + FDT_TAGSIZE;
-	err = _fdt_splice_struct(fdt, nh, 0, nodelen);
+	err = fdt_splice_struct_(fdt, nh, 0, nodelen);
 	if (err)
 		return err;
@@ -396,15 +396,15 @@ int fdt_del_node(void *fdt, int nodeoffset)
-	endoffset = _fdt_node_end_offset(fdt, nodeoffset);
+	endoffset = fdt_node_end_offset_(fdt, nodeoffset);
 	if (endoffset < 0)
 		return endoffset;
-	return _fdt_splice_struct(fdt, _fdt_offset_ptr_w(fdt, nodeoffset),
+	return fdt_splice_struct_(fdt, fdt_offset_ptr_w_(fdt, nodeoffset),
 				  endoffset - nodeoffset, 0);
-static void _fdt_packblocks(const char *old, char *new,
+static void fdt_packblocks_(const char *old, char *new,
 	int mem_rsv_off, struct_off, strings_off;
@@ -450,7 +450,7 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize)
 			return struct_size;
-	if (!_fdt_blocks_misordered(fdt, mem_rsv_size, struct_size)) {
+	if (!fdt_blocks_misordered_(fdt, mem_rsv_size, struct_size)) {
 		/* no further work necessary */
 		err = fdt_move(fdt, buf, bufsize);
 		if (err)
@@ -478,7 +478,7 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize)
 			return -FDT_ERR_NOSPACE;
-	_fdt_packblocks(fdt, tmp, mem_rsv_size, struct_size);
+	fdt_packblocks_(fdt, tmp, mem_rsv_size, struct_size);
 	memmove(buf, tmp, newsize);
 	fdt_set_magic(buf, FDT_MAGIC);
@@ -498,8 +498,8 @@ int fdt_pack(void *fdt)
 	mem_rsv_size = (fdt_num_mem_rsv(fdt)+1)
 		* sizeof(struct fdt_reserve_entry);
-	_fdt_packblocks(fdt, fdt, mem_rsv_size, fdt_size_dt_struct(fdt));
-	fdt_set_totalsize(fdt, _fdt_data_size(fdt));
+	fdt_packblocks_(fdt, fdt, mem_rsv_size, fdt_size_dt_struct(fdt));
+	fdt_set_totalsize(fdt, fdt_data_size_(fdt));
 	return 0;
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 2bd15e7aef..6d33cc29d0 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -55,7 +55,7 @@
-static int _fdt_sw_check_header(void *fdt)
+static int fdt_sw_check_header_(void *fdt)
 	if (fdt_magic(fdt) != FDT_SW_MAGIC)
 		return -FDT_ERR_BADMAGIC;
@@ -66,11 +66,11 @@ static int _fdt_sw_check_header(void *fdt)
 #define FDT_SW_CHECK_HEADER(fdt) \
 		int err; \
-		if ((err = _fdt_sw_check_header(fdt)) != 0) \
+		if ((err = fdt_sw_check_header_(fdt)) != 0) \
 			return err; \
-static void *_fdt_grab_space(void *fdt, size_t len)
+static void *fdt_grab_space_(void *fdt, size_t len)
 	int offset = fdt_size_dt_struct(fdt);
 	int spaceleft;
@@ -82,7 +82,7 @@ static void *_fdt_grab_space(void *fdt, size_t len)
 		return NULL;
 	fdt_set_size_dt_struct(fdt, offset + len);
-	return _fdt_offset_ptr_w(fdt, offset);
+	return fdt_offset_ptr_w_(fdt, offset);
 int fdt_create(void *buf, int bufsize)
@@ -174,7 +174,7 @@ int fdt_begin_node(void *fdt, const char *name)
 	FDT_SW_CHECK_HEADER(fdt);
-	nh = _fdt_grab_space(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen));
+	nh = fdt_grab_space_(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen));
 	if (! nh)
@@ -189,7 +189,7 @@ int fdt_end_node(void *fdt)
-	en = _fdt_grab_space(fdt, FDT_TAGSIZE);
+	en = fdt_grab_space_(fdt, FDT_TAGSIZE);
 	if (! en)
@@ -197,7 +197,7 @@ int fdt_end_node(void *fdt)
 	return 0;
 	char *strtab = (char *)fdt + fdt_totalsize(fdt);
 	const char *p;
@@ -205,7 +205,7 @@ static int _fdt_find_add_string(void *fdt, const char *s)
 	int struct_top, offset;
-	p = _fdt_find_string(strtab - strtabsize, strtabsize, s);
+	p = fdt_find_string_(strtab - strtabsize, strtabsize, s);
 	if (p)
 		return p - strtab;
@@ -227,11 +227,11 @@ int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp)
-	nameoff = _fdt_find_add_string(fdt, name);
+	nameoff = fdt_find_add_string_(fdt, name);
 	if (nameoff == 0)
-	prop = _fdt_grab_space(fdt, sizeof(*prop) + FDT_TAGALIGN(len));
+	prop = fdt_grab_space_(fdt, sizeof(*prop) + FDT_TAGALIGN(len));
 	if (! prop)
@@ -265,7 +265,7 @@ int fdt_finish(void *fdt)
 	/* Add terminator */
-	end = _fdt_grab_space(fdt, sizeof(*end));
+	end = fdt_grab_space_(fdt, sizeof(*end));
 	if (! end)
 	*end = cpu_to_fdt32(FDT_END);
@@ -281,7 +281,7 @@ int fdt_finish(void *fdt)
 	while ((tag = fdt_next_tag(fdt, offset, &nextoffset)) != FDT_END) {
 		if (tag == FDT_PROP) {
 			struct fdt_property *prop =
-				_fdt_offset_ptr_w(fdt, offset);
+				fdt_offset_ptr_w_(fdt, offset);
 			int nameoff;
 			nameoff = fdt32_to_cpu(prop->nameoff);
diff --git a/cpukit/dtc/libfdt/fdt_wip.c b/cpukit/dtc/libfdt/fdt_wip.c
index 5e85919862..534c1cbbb2 100644
--- a/cpukit/dtc/libfdt/fdt_wip.c
+++ b/cpukit/dtc/libfdt/fdt_wip.c
@@ -93,7 +93,7 @@ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name,
 						   val, len);
-static void _fdt_nop_region(void *start, int len)
+static void fdt_nop_region_(void *start, int len)
 	fdt32_t *p;
@@ -110,12 +110,12 @@ int fdt_nop_property(void *fdt, int nodeoffset, const char *name)
 	if (!prop)
 		return len;
-	_fdt_nop_region(prop, len + sizeof(*prop));
+	fdt_nop_region_(prop, len + sizeof(*prop));
 	return 0;
-int _fdt_node_end_offset(void *fdt, int offset)
+int fdt_node_end_offset_(void *fdt, int offset)
 	int depth = 0;
@@ -129,11 +129,11 @@ int fdt_nop_node(void *fdt, int nodeoffset)
 	int endoffset;
 	if (endoffset < 0)
 		return endoffset;
-	_fdt_nop_region(fdt_offset_ptr_w(fdt, nodeoffset, 0),
+	fdt_nop_region_(fdt_offset_ptr_w(fdt, nodeoffset, 0),
 			endoffset - nodeoffset);
 	return 0;
diff --git a/cpukit/dtc/libfdt/libfdt_internal.h b/cpukit/dtc/libfdt/libfdt_internal.h
index 02cfa6fb61..7681e19229 100644
--- a/cpukit/dtc/libfdt/libfdt_internal.h
+++ b/cpukit/dtc/libfdt/libfdt_internal.h
@@ -1,5 +1,5 @@
-#ifndef _LIBFDT_INTERNAL_H
-#define _LIBFDT_INTERNAL_H
+#ifndef LIBFDT_INTERNAL_H
+#define LIBFDT_INTERNAL_H
  * libfdt - Flat Device Tree manipulation
  * Copyright (C) 2006 David Gibson, IBM Corporation.
@@ -57,27 +57,27 @@
 #define FDT_CHECK_HEADER(fdt) \
-		int __err; \
-		if ((__err = fdt_check_header(fdt)) != 0) \
-			return __err; \
+		int err_; \
+		if ((err_ = fdt_check_header(fdt)) != 0) \
+			return err_; \
-int _fdt_check_node_offset(const void *fdt, int offset);
-int _fdt_check_prop_offset(const void *fdt, int offset);
-const char *_fdt_find_string(const char *strtab, int tabsize, const char *s);
-int _fdt_node_end_offset(void *fdt, int nodeoffset);
+int fdt_check_node_offset_(const void *fdt, int offset);
+int fdt_check_prop_offset_(const void *fdt, int offset);
+const char *fdt_find_string_(const char *strtab, int tabsize, const char *s);
+int fdt_node_end_offset_(void *fdt, int nodeoffset);
-static inline const void *_fdt_offset_ptr(const void *fdt, int offset)
+static inline const void *fdt_offset_ptr_(const void *fdt, int offset)
 	return (const char *)fdt + fdt_off_dt_struct(fdt) + offset;
-static inline void *_fdt_offset_ptr_w(void *fdt, int offset)
+static inline void *fdt_offset_ptr_w_(void *fdt, int offset)
-	return (void *)(uintptr_t)_fdt_offset_ptr(fdt, offset);
+	return (void *)(uintptr_t)fdt_offset_ptr_(fdt, offset);
-static inline const struct fdt_reserve_entry *_fdt_mem_rsv(const void *fdt, int n)
+static inline const struct fdt_reserve_entry *fdt_mem_rsv_(const void *fdt, int n)
 	const struct fdt_reserve_entry *rsv_table =
 		(const struct fdt_reserve_entry *)
@@ -85,11 +85,11 @@ static inline const struct fdt_reserve_entry *_fdt_mem_rsv(const void *fdt, int
 	return rsv_table + n;
-static inline struct fdt_reserve_entry *_fdt_mem_rsv_w(void *fdt, int n)
+static inline struct fdt_reserve_entry *fdt_mem_rsv_w_(void *fdt, int n)
-	return (void *)(uintptr_t)_fdt_mem_rsv(fdt, n);
+	return (void *)(uintptr_t)fdt_mem_rsv_(fdt, n);
 #define FDT_SW_MAGIC		(~FDT_MAGIC)
-#endif /* _LIBFDT_INTERNAL_H */
+#endif /* LIBFDT_INTERNAL_H */
diff --git a/cpukit/include/fdt.h b/cpukit/include/fdt.h
index 526aedb515..74961f9026 100644
--- a/cpukit/include/fdt.h
+++ b/cpukit/include/fdt.h
@@ -1,5 +1,5 @@
-#ifndef _FDT_H
-#define _FDT_H
+#ifndef FDT_H
+#define FDT_H
@@ -108,4 +108,4 @@ struct fdt_property {
 #define FDT_V16_SIZE	FDT_V3_SIZE
 #define FDT_V17_SIZE	(FDT_V16_SIZE + sizeof(fdt32_t))
-#endif /* _FDT_H */
+#endif /* FDT_H */
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index c8865208df..baa882cfa1 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -1,5 +1,5 @@
-#ifndef _LIBFDT_H
-#define _LIBFDT_H
+#ifndef LIBFDT_H
+#define LIBFDT_H
@@ -225,23 +225,23 @@ int fdt_next_subnode(const void *fdt, int offset);
 #define fdt_size_dt_strings(fdt)	(fdt_get_header(fdt, size_dt_strings))
 #define fdt_size_dt_struct(fdt)		(fdt_get_header(fdt, size_dt_struct))
-#define __fdt_set_hdr(name) \
+#define fdt_set_hdr_(name) \
 	static inline void fdt_set_##name(void *fdt, uint32_t val) \
 		struct fdt_header *fdth = (struct fdt_header *)fdt; \
 		fdth->name = cpu_to_fdt32(val); \
-__fdt_set_hdr(magic);
-__fdt_set_hdr(totalsize);
-__fdt_set_hdr(off_dt_struct);
-__fdt_set_hdr(off_dt_strings);
-__fdt_set_hdr(off_mem_rsvmap);
-__fdt_set_hdr(version);
-__fdt_set_hdr(last_comp_version);
-__fdt_set_hdr(boot_cpuid_phys);
-__fdt_set_hdr(size_dt_strings);
-__fdt_set_hdr(size_dt_struct);
-#undef __fdt_set_hdr
+fdt_set_hdr_(magic);
+fdt_set_hdr_(totalsize);
+fdt_set_hdr_(off_dt_struct);
+fdt_set_hdr_(off_dt_strings);
+fdt_set_hdr_(off_mem_rsvmap);
+fdt_set_hdr_(version);
+fdt_set_hdr_(last_comp_version);
+fdt_set_hdr_(boot_cpuid_phys);
+fdt_set_hdr_(size_dt_strings);
+fdt_set_hdr_(size_dt_struct);
+#undef fdt_set_hdr_
  * fdt_check_header - sanity check a device tree or possible device tree
@@ -1896,4 +1896,4 @@ int fdt_overlay_apply(void *fdt, void *fdto);
 const char *fdt_strerror(int errval);
-#endif /* _LIBFDT_H */
+#endif /* LIBFDT_H */
diff --git a/cpukit/include/libfdt_env.h b/cpukit/include/libfdt_env.h
index 952056cddf..3605d93254 100644
--- a/cpukit/include/libfdt_env.h
+++ b/cpukit/include/libfdt_env.h
@@ -1,5 +1,5 @@
-#ifndef _LIBFDT_ENV_H
-#define _LIBFDT_ENV_H
+#ifndef LIBFDT_ENV_H
+#define LIBFDT_ENV_H
@@ -109,4 +109,4 @@ static inline fdt64_t cpu_to_fdt64(uint64_t x)
 #undef CPU_TO_FDT16
 #undef EXTRACT_BYTE
-#endif /* _LIBFDT_ENV_H */
+#endif /* LIBFDT_ENV_H */
2.13.7
