[PATCH 28/45] Introduce fdt_setprop_placeholder() method
Wed Jul 18 07:35:37 UTC 2018
From: Pantelis Antoniou <pantelis.antoniou at konsulko.com>
In some cases you need to add a property but the contents of it
are not known at creation time, merely the extend of it.
This method allows you to create a property of a given size (filled
with garbage) while a pointer to the property data will be provided.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou at konsulko.com>
[dwg: Corrected commit message]
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_rw.c | 20 +++++++++++++++++---
 cpukit/include/libfdt.h    | 31 +++++++++++++++++++++++++++++++
 2 files changed, 48 insertions(+), 3 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 8b487f6c0f..5c3a2bb0bc 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -269,8 +269,8 @@ int fdt_set_name(void *fdt, int nodeoffset, const char *name)
 	return 0;
-int fdt_setprop(void *fdt, int nodeoffset, const char *name,
-		const void *val, int len)
+int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name,
+			    int len, void **prop_data)
 	struct fdt_property *prop;
 	int err;
@@ -283,8 +283,22 @@ int fdt_setprop(void *fdt, int nodeoffset, const char *name,
 	if (err)
 		return err;
+	*prop_data = prop->data;
+	return 0;
+int fdt_setprop(void *fdt, int nodeoffset, const char *name,
+		const void *val, int len)
+	void *prop_data;
+	int err;
+	err = fdt_setprop_placeholder(fdt, nodeoffset, name, len, &prop_data);
+	if (err)
+		return err;
 	if (len)
-		memcpy(prop->data, val, len);
+		memcpy(prop_data, val, len);
 	return 0;
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index a248b1b57a..313c72a2d1 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -1449,6 +1449,37 @@ int fdt_setprop(void *fdt, int nodeoffset, const char *name,
 		const void *val, int len);
+ * fdt_setprop _placeholder - allocate space for a property
+ * @fdt: pointer to the device tree blob
+ * @nodeoffset: offset of the node whose property to change
+ * @name: name of the property to change
+ * @len: length of the property value
+ * @prop_data: return pointer to property data
+ * fdt_setprop_placeholer() allocates the named property in the given node.
+ * If the property exists it is resized. In either case a pointer to the
+ * property data is returned.
+ * This function may insert or delete data from the blob, and will
+ * therefore change the offsets of some existing nodes.
+ * returns:
+ *	0, on success
+ *	-FDT_ERR_NOSPACE, there is insufficient free space in the blob to
+ *		contain the new property value
+ *	-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag
+ *	-FDT_ERR_BADLAYOUT,
+ *	-FDT_ERR_BADMAGIC,
+ *	-FDT_ERR_BADVERSION,
+ *	-FDT_ERR_BADSTATE,
+ *	-FDT_ERR_BADSTRUCTURE,
+ *	-FDT_ERR_TRUNCATED, standard meanings
+			    int len, void **prop_data);
  * fdt_setprop_u32 - set a property to a 32-bit integer
2.13.7
