[PATCH 42/45] libfdt: Add helpers for accessing unaligned words
Wed Jul 18 07:35:51 UTC 2018
From: David Gibson <david at gibson.dropbear.id.au>
This adds some helpers to load (32 or 64 bit) words from an fdt blob, even
if they're unaligned and we're on a platform that doesn't like plain
unaligned loads and stores.  We then use the helpers in a number of places.
There are two purposes for this:
1) This makes libfdt more robust against a blob loaded at an unaligned
   address.  It's usually good practice to load a blob at a 64-bit
   alignment, but it's nice to work even then.
2) Users can use these helpers to load integer values from within property
   values.  These can often be unaligned, even if the blob as a whole is
   aligned, since some property encodings have integers and strings mixed
   together without any alignment gaps.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_ro.c | 18 +++++++++---------
 cpukit/include/libfdt.h    | 25 ++++++++++++++++++++++++-
 2 files changed, 33 insertions(+), 10 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index 4ba7c93313..eafc142828 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -191,8 +191,8 @@ int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size)
 	if (!re)
 		return -FDT_ERR_BADOFFSET;
-	*address = fdt64_to_cpu(re->address);
-	*size = fdt64_to_cpu(re->size);
+	*address = fdt64_ld(&re->address);
+	*size = fdt64_ld(&re->size);
 	return 0;
@@ -202,7 +202,7 @@ int fdt_num_mem_rsv(const void *fdt)
 	const struct fdt_reserve_entry *re;
 	for (i = 0; (re = fdt_mem_rsv(fdt, i)) != NULL; i++) {
-		if (fdt64_to_cpu(re->size) == 0)
+		if (fdt64_ld(&re->size) == 0)
 			return i;
 	return -FDT_ERR_TRUNCATED;
@@ -379,7 +379,7 @@ static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt,
 	prop = fdt_offset_ptr_(fdt, offset);
 	if (lenp)
-		*lenp = fdt32_to_cpu(prop->len);
+		*lenp = fdt32_ld(&prop->len);
 	return prop;
@@ -416,7 +416,7 @@ static const struct fdt_property *fdt_get_property_namelen_(const void *fdt,
 			offset = -FDT_ERR_INTERNAL;
 			break;
-		if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff),
+		if (fdt_string_eq_(fdt, fdt32_ld(&prop->nameoff),
 				   name, namelen)) {
 			if (poffset)
 				*poffset = offset;
@@ -469,7 +469,7 @@ const void *fdt_getprop_namelen(const void *fdt, int nodeoffset,
 	/* Handle realignment */
 	if (fdt_version(fdt) < 0x10 && (poffset + sizeof(*prop)) % 8 &&
-	    fdt32_to_cpu(prop->len) >= 8)
+	    fdt32_ld(&prop->len) >= 8)
 		return prop->data + 4;
 	return prop->data;
@@ -485,7 +485,7 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset,
 	if (namep) {
 		const char *name;
 		int namelen;
-		name = fdt_get_string(fdt, fdt32_to_cpu(prop->nameoff),
+		name = fdt_get_string(fdt, fdt32_ld(&prop->nameoff),
 				      &namelen);
 		if (!name) {
 			if (lenp)
@@ -497,7 +497,7 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset,
 	if (fdt_version(fdt) < 0x10 && (offset + sizeof(*prop)) % 8 &&
 	return prop->data;
@@ -522,7 +522,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset)
 			return 0;
-	return fdt32_to_cpu(*php);
+	return fdt32_ld(php);
 const char *fdt_get_alias_namelen(const void *fdt,
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index c99d28fea5..38ec313094 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -154,6 +154,29 @@ static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen)
 uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset);
+ * Alignment helpers:
+ *     These helpers access words from a device tree blob.  They're
+ *     built to work even with unaligned pointers on platforms (ike
+ *     ARM) that don't like unaligned loads and stores
+static inline uint32_t fdt32_ld(const fdt32_t *p)
+	fdt32_t v;
+	memcpy(&v, p, sizeof(v));
+	return fdt32_to_cpu(v);
+static inline uint64_t fdt64_ld(const fdt64_t *p)
+	fdt64_t v;
+	return fdt64_to_cpu(v);
 /* Traversal functions                                                */
@@ -214,7 +237,7 @@ int fdt_next_subnode(const void *fdt, int offset);
 /* General functions                                                  */
 #define fdt_get_header(fdt, field) \
-	(fdt32_to_cpu(((const struct fdt_header *)(fdt))->field))
+	(fdt32_ld(&((const struct fdt_header *)(fdt))->field))
 #define fdt_magic(fdt)			(fdt_get_header(fdt, magic))
 #define fdt_totalsize(fdt)		(fdt_get_header(fdt, totalsize))
 #define fdt_off_dt_struct(fdt)		(fdt_get_header(fdt, off_dt_struct))
2.13.7
