[PATCH] sptests/spfatal26: Use an illegal instruction
Joel Sherrill
joel at rtems.org
Thu Jul 19 15:03:00 UTC 2018
On Thu, Jul 19, 2018 at 8:49 AM, Gedare Bloom <gedare at rtems.org> wrote:
> For now we don't need to generalize this approach or make any kind of
> facility like this available outside of testing.
> (FYI: 0 is a "nop" on some architectures)
> Gedare
> On Thu, Jul 19, 2018 at 9:37 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > I thought about adding a _CPU_Illegal_instruction() function to
> > <rtems/score/cpu.h>. But, do you want such a toxic function in a header
> file
> > or librtemscpu.a? Now it is isolated in the test and can do no harm.
I have wondered if there enough architectural oddities like this in
the tests where a central place to address them would be helpful
when porting.
Where all do you have to check now when porting?
> > On 19/07/18 15:35, Joel Sherrill wrote:
> >> This looks like a good approach. If 0 is a valid instruction on
> >> some architecture, we can add a conditional.
> >> On Thu, Jul 19, 2018 at 5:55 AM, Sebastian Huber
> >> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >> On some architectures/simulators it is difficult to provoke an
> >> exception with misaligned or illegal data loads. Use an illegal
> >> instruction instead.
> >> Update #3433.
> >> testsuites/sptests/spfatal26/init.c | 10 +++++++++-
> >> 1 file changed, 9 insertions(+), 1 deletion(-)
> >> diff --git a/testsuites/sptests/spfatal26/init.c
> >> b/testsuites/sptests/spfatal26/init.c
> >> index 1848659d6a..7d635f3b84 100644
> >> --- a/testsuites/sptests/spfatal26/init.c
> >> +++ b/testsuites/sptests/spfatal26/init.c
> >> @@ -1,5 +1,5 @@
> >> - * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
> >> + * Copyright (c) 2012, 2018 embedded brains GmbH. All rights
> >> reserved.
> >> * embedded brains GmbH
> >> * Obere Lagerstr. 30
> >> @@ -24,6 +24,13 @@
> >> const char rtems_test_name[] = "SPFATAL 26";
> >> +static void provoke_illegal_instruction_exception( void )
> >> +#ifdef __riscv
> >> + __asm__ volatile (".word 0");
> >> +#endif
> >> static void provoke_aligment_or_data_access_exception( void )
> >> uintptr_t one = 1;
> >> @@ -53,6 +60,7 @@ static void Init( rtems_task_argument arg )
> >> TEST_BEGIN();
> >> + provoke_illegal_instruction_exception();
> >> provoke_aligment_or_data_access_exception();
> >> rtems_test_assert( 0 );
> >> -- 2.13.7
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org <mailto:devel at rtems.org>
> >> http://lists.rtems.org/mailman/listinfo/devel
> >> <http://lists.rtems.org/mailman/listinfo/devel>
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180719/ff38b961/attachment.html>
