QorIQ Boards
Thu Jul 19 18:54:12 UTC 2018
----- Am 19. Jul 2018 um 20:44 schrieb joel joel at rtems.org:
> On Thu, Jul 19, 2018 at 1:42 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> ----- Am 19. Jul 2018 um 17:01 schrieb joel joel at rtems.org:
>> > Hi
>> > Is the list of boards in the BSP README up to date?
>> > Board support package for the Freescale QorIQ platform:
>> >  http://en.wikipedia.org/wiki/QorIQ
>> > Boards known to work P1020RDB, MVME2500, T2080RDB and T4240RDB.
>> > I was asked for PowerPC reference boards and thought this
>> > was the way to go.
>> Yes, this list is up to date. Due to the use of the device tree and boot
>> via U-Boot custom boards should work as well. I am not sure if the e5500
>> based chips will work out of the box.
> Thanks. git blame showed 2017 so I wanted to ask. I checked a price
> on the T4240RDB and it was supposed to be only USD1500 at Digikey.
> If you don't require THAT many cores, does one of these boards
> stand out for any reason to you? Or should be avoided?
At least my T4240RDB had an unreliable external reset.
