[PATCH 1/3] 5: Update to Binutils 2.31.1
Fri Jul 20 08:53:33 UTC 2018
 rtems/config/5/rtems-default.bset            |  2 +-
 rtems/config/5/rtems-epiphany.bset           |  2 +-
 rtems/config/5/rtems-m32c.bset               |  2 +-
 rtems/config/5/rtems-or1k.bset               |  2 +-
 rtems/config/5/rtems-riscv32.bset            |  2 +-
 rtems/config/5/rtems-riscv64.bset            |  2 +-
 rtems/config/tools/rtems-binutils-2.31.1.cfg | 27 +++++++++++++++++++++++++++
 7 files changed, 33 insertions(+), 6 deletions(-)
 create mode 100644 rtems/config/tools/rtems-binutils-2.31.1.cfg
diff --git a/rtems/config/5/rtems-default.bset b/rtems/config/5/rtems-default.bset
index dcafbdc..eed39fd 100644
--- a/rtems/config/5/rtems-default.bset
+++ b/rtems/config/5/rtems-default.bset
@@ -10,7 +10,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-binutils-2.30
+tools/rtems-binutils-2.31.1
 tools/rtems-gcc-7.3.0-newlib-3.0.0
 tools/rtems-gdb-8.0.1-1
 tools/rtems-tools-5-1
diff --git a/rtems/config/5/rtems-epiphany.bset b/rtems/config/5/rtems-epiphany.bset
index b7ac799..566cb1a 100644
--- a/rtems/config/5/rtems-epiphany.bset
+++ b/rtems/config/5/rtems-epiphany.bset
@@ -33,7 +33,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
 tools/rtems-gdb-7.8.1-1
diff --git a/rtems/config/5/rtems-m32c.bset b/rtems/config/5/rtems-m32c.bset
index addce75..63fb260 100644
--- a/rtems/config/5/rtems-m32c.bset
+++ b/rtems/config/5/rtems-m32c.bset
@@ -40,7 +40,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
 tools/rtems-gcc-4.8.3-newlib-3.0.0
diff --git a/rtems/config/5/rtems-or1k.bset b/rtems/config/5/rtems-or1k.bset
index 15be88e..d29bb85 100644
--- a/rtems/config/5/rtems-or1k.bset
+++ b/rtems/config/5/rtems-or1k.bset
@@ -32,7 +32,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
 tools/rtems-gcc-4.9.3-newlib-3.0.0
 tools/rtems-gdb-7.11-2
diff --git a/rtems/config/5/rtems-riscv32.bset b/rtems/config/5/rtems-riscv32.bset
index 07853b5..5dce1da 100644
--- a/rtems/config/5/rtems-riscv32.bset
+++ b/rtems/config/5/rtems-riscv32.bset
@@ -10,7 +10,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-binutils-160d1b3d74593bf42155da24569f54a6e7140f65
 tools/rtems-gcc-2e2052934b0c82e0726ed44de4a9b0a29ed6b276-newlib-3.0.0
 tools/rtems-gdb-160d1b3d74593bf42155da24569f54a6e7140f65
diff --git a/rtems/config/5/rtems-riscv64.bset b/rtems/config/5/rtems-riscv64.bset
index 0b4e676..6d4ff2b 100644
--- a/rtems/config/5/rtems-riscv64.bset
+++ b/rtems/config/5/rtems-riscv64.bset
@@ -10,7 +10,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
diff --git a/rtems/config/tools/rtems-binutils-2.31.1.cfg b/rtems/config/tools/rtems-binutils-2.31.1.cfg
new file mode 100644
index 0000000..121736e
--- /dev/null
+++ b/rtems/config/tools/rtems-binutils-2.31.1.cfg
@@ -0,0 +1,27 @@
+# Binutils 2.31.1
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%define binutils_version 2.31.1
+%hash sha512 binutils-%{binutils_version}.tar.bz2 b42954e6f49a0adcd2676bdd77dfb59bfc25cec8184b007521d1e2b1d5d0593b58639e3d9448d5a40fe024c3cea386a37743627d6bb16d502f52a4a32b9573bd
+# Enable deterministic archives by default. This will be the default
+# there all tools using this binutils will create deterministic
+# archives.
+%define with_deterministic_archives 1
+# Enable 64-bit BFD support
+%define with_64_bit_bfd 1
+# The binutils build instructions. We use 2.xx Release 1.
+%include %{_configdir}/binutils-2-1.cfg
2.13.7
