Fwd: Build Linux: PASSED 5/rtems-moxie on x86_64-linux-gnu
Joel Sherrill
joel at rtems.org
Fri Jul 20 13:39:02 UTC 2018
Sebastian
There is an odd warning about chown having an absolute path. Any idea
what's up with your environment?
--joel
---------- Forwarded message ---------
Date: Fri, Jul 20, 2018, 7:29 AM
Subject: Build Linux: PASSED 5/rtems-moxie on x86_64-linux-gnu
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 5 (1767b06d488a)
warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
Host: Linux-4.4.138-59-default-x86_64-with-SuSE-42.3-x86_64
Linux huber-nb-linux 4.4.138-59-default #1 SMP Mon Jun 18 13:48:42
UTC
2018 (f0b8f6b) x86_64 x86_64
Build Time: 0:12:25.093248
Output
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-linux-gnu-1
building: autoconf-2.69-x86_64-linux-gnu-1
reporting: tools/rtems-autoconf-2.69-1.cfg ->
autoconf-2.69-x86_64-linux-gnu-1.txt
autoconf-2.69-x86_64-linux-gnu-1.xml
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-linux-gnu-1
building: automake-1.12.6-x86_64-linux-gnu-1
reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-x86_64-linux-gnu-1.txt
automake-1.12.6-x86_64-linux-gnu-1.xml
installing: autoconf-2.69-x86_64-linux-gnu-1 -> /build/rtems/5
installing: automake-1.12.6-x86_64-linux-gnu-1 -> /build/rtems/5
cleaning: autoconf-2.69-x86_64-linux-gnu-1
cleaning: automake-1.12.6-x86_64-linux-gnu-1
Build Set: Time 0:00:12.433038
Build Set: Time 0:00:19.470551
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
building: expat-2.1.0-x86_64-linux-gnu-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
config: tools/rtems-binutils-2.31.1.cfg
package: moxie-rtems5-binutils-2.31.1-x86_64-linux-gnu-1
building: moxie-rtems5-binutils-2.31.1-x86_64-linux-gnu-1
reporting: tools/rtems-binutils-2.31.1.cfg ->
moxie-rtems5-binutils-2.31.1-x86_64-linux-gnu-1.txt
moxie-rtems5-binutils-2.31.1-x86_64-linux-gnu-1.xml
config:
tools/rtems-gcc-7.3.0-newlib-916ef5fb8865f72d0f5ad3f4f479adac44ea94b1.cfg
package:
moxie-rtems5-gcc-7.3.0-newlib-916ef5fb8865f72d0f5ad3f4f479adac44ea94b1-x86_64-linux-gnu-1
building:
reporting:
moxie-rtems5-gcc-7.3.0-newlib-916ef5fb8865f72d0f5ad3f4f479adac44ea94b1-x86_64-linux-gnu-1.txt
reporting:
moxie-rtems5-gcc-7.3.0-newlib-916ef5fb8865f72d0f5ad3f4f479adac44ea94b1-x86_64-linux-gnu-1.xml
config: tools/rtems-gdb-8.0.1-1.cfg
package: moxie-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
building: moxie-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
reporting: tools/rtems-gdb-8.0.1-1.cfg ->
moxie-rtems5-gdb-8.0.1-x86_64-linux-gnu-1.txt
moxie-rtems5-gdb-8.0.1-x86_64-linux-gnu-1.xml
config: tools/rtems-tools-5-1.cfg
package: rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def-1
building: rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def-1
reporting: tools/rtems-tools-5-1.cfg ->
rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def-1.txt
rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def-1.xml
config: tools/rtems-kernel-5.cfg
package: moxie-rtems5-kernel-5-1
building: moxie-rtems5-kernel-5-1
reporting: tools/rtems-kernel-5.cfg -> moxie-rtems5-kernel-5-1.txt
reporting: tools/rtems-kernel-5.cfg -> moxie-rtems5-kernel-5-1.xml
installing: dtc-1.4.1-x86_64-linux-gnu-1 -> /build/rtems/5
installing: expat-2.1.0-x86_64-linux-gnu-1 -> /build/rtems/5
installing: moxie-rtems5-binutils-2.31.1-x86_64-linux-gnu-1 ->
/build/rtems/5
installing:
-> /build/rtems/5
installing: moxie-rtems5-gdb-8.0.1-x86_64-linux-gnu-1 -> /build/rtems/5
installing: rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def-1 ->
/build/rtems/5
installing: moxie-rtems5-kernel-5-1 -> /build/rtems/5
cleaning: dtc-1.4.1-x86_64-linux-gnu-1
cleaning: expat-2.1.0-x86_64-linux-gnu-1
cleaning: moxie-rtems5-binutils-2.31.1-x86_64-linux-gnu-1
cleaning:
cleaning: moxie-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
cleaning: rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def-1
cleaning: moxie-rtems5-kernel-5-1
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:17:19 2018
Report: devel/dtc-1.4.1-1.cfg
RTEMS Source Builder Repository Status
Remotes:
1: origin: ssh://
sebh at dispatch.rtems.org/data/git/rtems-source-builder.git
2: main: https://main.eb.localhost/git/rtems-source-builder.git
Status:
Clean
Head:
Commit: 1767b06d488a03954d3baa3d4e5e5a47f569de10
Build Set: (1) devel/dtc-1.4.1-1.cfg
Build Set: (2) devel/dtc-1.4.1-1.cfg
Package: dtc-1.4.1-x86_64-linux-gnu-1
Config: devel/dtc-1.4.1-1.cfg
Summary:
Device Tree Compiler v1.4.1 for target moxie-rtems5 on host
x86_64-linux-gnu
URL:
http://www.jdl.com/software/
Version:
1.4.1
Release:
1
Sources: 1
1: https://www.kernel.org/pub/software/utils/dtc/dtc-1.4.1.tar.gz
sha256:
03e74e4ee9378be15f19eb24197dfa32070efc3c85e93269e56d7ade133e359f
Patches: 0
Preparation:
build_top=$(pwd)
%setup source dtc -q -n dtc-1.4.1
%setup patch dtc -p1
cd ${build_top}
Build:
build_top=$(pwd)
cd dtc-1.4.1
# Build and build flags means force build == host
# gcc is not ready to be compiled with -std=gnu99
LDFLAGS="${SB_HOST_LDFLAGS}"
CC=$(echo "gcc ${SB_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "g++ ${SB_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
CC_FOR_BUILD=${CC}
CXX_FOR_BUILD=${CXX}
export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS
make PREFIX=/build/rtems/5
cd ${build_top}
Install:
build_top=$(pwd)
rm -rf $SB_BUILD_ROOT
cd dtc-1.4.1
make DESTDIR=$SB_BUILD_ROOT PREFIX=/build/rtems/5 install
cd ${build_top}
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Summary:
x86_64-linux-gnu
URL:
Version:
1.4.1
Release:
1
Sources: 1
sha256:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
cd dtc-1.4.1
CC_FOR_BUILD=${CC}
cd ${build_top}
Install:
build_top=$(pwd)
cd dtc-1.4.1
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:17:49 2018
Report: devel/expat-2.1.0-1.cfg
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Build Set: (1) devel/expat-2.1.0-1.cfg
Build Set: (2) devel/expat-2.1.0-1.cfg
Package: expat-2.1.0-x86_64-linux-gnu-1
Config: devel/expat-2.1.0-1.cfg
Summary:
Expat XML Parser v2.1.0 for target moxie-rtems5 on host x86_64-linux-gnu
URL:
http://expat.sourceforge.net/
Version:
2.1.0
Release:
1
Sources: 1
1:
https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz
sha256:
823705472f816df21c8f6aa026dd162b280806838bb55b3432b0fb1fcca7eb86
Patches: 0
Preparation:
build_top=$(pwd)
%setup source expat -q -n expat-2.1.0
%setup patch expat -p1
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
# Host and build flags, Cross build if host and build are different and
# Cxc build if target is deifned and also different.
# Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
if test "x86_64-linux-gnu" != "x86_64-linux-gnu" ; then
# Cross build
CC=$(echo "x86_64-linux-gnu-gcc" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "x86_64-linux-gnu-g++" | sed -e 's,-std=gnu99 ,,')
CPPFLAGS="${SB_HOST_CPPFLAGS}"
CFLAGS="${SB_HOST_CFLAGS}"
CXXFLAGS="${SB_HOST_CXXFLAGS}"
# Host
CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
# Build
CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CC_FOR_BUILD=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_BUILD=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
else
LDFLAGS="${SB_BUILD_LDFLAGS}"
CC=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
CC_FOR_BUILD=${CC}
fi
export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS
export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST
export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD
./configure \
--build=x86_64-linux-gnu --host=x86_64-linux-gnu \
--verbose \
--prefix=/build/rtems/5 --bindir=/build/rtems/5/bin \
--exec-prefix=/build/rtems/5 \
--includedir=/build/rtems/5/include --libdir=/build/rtems/5/lib \
--mandir=/build/rtems/5/share/man --infodir=/build/rtems/5/share/info
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd expat-2.1.0
make DESTDIR=$SB_BUILD_ROOT install
cd ${build_top}
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Summary:
URL:
Version:
2.1.0
Release:
1
Sources: 1
1:
sha256:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
./configure \
--verbose \
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd expat-2.1.0
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:18:39 2018
Report: tools/rtems-binutils-2.31.1.cfg
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Build Set: (1) tools/rtems-binutils-2.31.1.cfg
Build Set: (2) tools/rtems-binutils-2.31.1.cfg
Package: moxie-rtems5-binutils-2.31.1-x86_64-linux-gnu-1
Config: tools/rtems-binutils-2.31.1.cfg
Summary:
Binutils v2.31.1 for target moxie-rtems5 on host x86_64-linux-gnu
URL:
http://sources.redhat.com/binutils
Version:
2.31.1
Release:
1
Sources: 1
1: ftp://ftp.gnu.org/gnu/binutils/binutils-2.31.1.tar.bz2
sha512:
b42954e6f49a0adcd2676bdd77dfb59bfc25cec8184b007521d1e2b1d5d0593b58639e3d9448d5a40fe024c3cea386a37743627d6bb16d502f52a4a32b9573bd
Patches: 0
Preparation:
build_top=$(pwd)
binutils_source="binutils-2.31.1"
source_dir_binutils=${binutils_source}
%setup source binutils -q -n ${binutils_source}
%setup patch binutils -p1
cd ${build_top}
Build:
build_top=$(pwd)
# Cross-build (Xc) if no target or the host and target match.
# Canadian-cross (Cxc) if build, host and target are all different.
if test -z "moxie-rtems5" -o "x86_64-linux-gnu" == "moxie-rtems5" ; then
build_dir="build-xc"
else
build_dir="build-cxc"
fi
else
build_dir="build"
fi
mkdir -p ${build_dir}
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
../${source_dir_binutils}/configure \
--target=moxie-rtems5 \
--verbose --disable-nls \
--disable-gdb --disable-libdecnumber --disable-readline --disable-sim \
--enable-deterministic-archives \
--enable-64-bit-bfd \
--disable-lto \
--without-included-gettext \
--disable-win32-registry \
--disable-werror \
make -j 12 all
cd ${build_top}
Install:
cd ${build_top}
/bin/rm -rf $SB_BUILD_ROOT
cd ${build_dir}
/bin/rm -rf $SB_BUILD_ROOT/build/rtems/5/share/info/configure.info*
/bin/rm -f $SB_BUILD_ROOT/build/rtems/5/share/info/dir
touch $SB_BUILD_ROOT/build/rtems/5/share/info/dir
mkdir -p $SB_BUILD_ROOT/build/rtems/5/share/locale
/bin/rm -f ${SB_BUILD_ROOT}/build/rtems/5/lib/libiberty*
if test ! -f ${SB_BUILD_ROOT}/build/rtems/5/bin/moxie-rtems5-dlltool; then
/bin/rm -f
${SB_BUILD_ROOT}/build/rtems/5/share/man/man1/moxie-rtems5-dlltool*
fi
if test ! -f ${SB_BUILD_ROOT}/build/rtems/5/bin/moxie-rtems5-nlmconv; then
/bin/rm -f
${SB_BUILD_ROOT}/build/rtems/5/share/man/man1/moxie-rtems5-nlmconv*
fi
if test ! -f ${SB_BUILD_ROOT}/build/rtems/5/bin/moxie-rtems5-windres; then
/bin/rm -f
${SB_BUILD_ROOT}/build/rtems/5/share/man/man1/moxie-rtems5-windres*
fi
if test ! -f ${SB_BUILD_ROOT}/build/rtems/5/bin/moxie-rtems5-windmc; then
/bin/rm -f
${SB_BUILD_ROOT}/build/rtems/5/share/man/man1/moxie-rtems5-windmc*
fi
cd ${build_top}
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Summary:
URL:
Version:
2.31.1
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
--disable-lto \
--disable-werror \
make -j 12 all
cd ${build_top}
Install:
cd ${build_top}
cd ${build_dir}
/bin/rm -f
fi
/bin/rm -f
fi
/bin/rm -f
fi
/bin/rm -f
fi
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:26:49 2018
Report:
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Build Set: (1)
Build Set: (2)
Package:
Config:
Summary:
GCC v7.3.0 and Newlib v916ef5fb8865f72d0f5ad3f4f479adac44ea94b1 for
URL:
http://gcc.gnu.org/
Version:
7.3.0
Release:
1
Sources: 5
1: --rsb-file=newlib-916ef5fb8865f72d0f5ad3f4f479adac44ea94b1.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/916ef5fb8865f72d0f5ad3f4f479adac44ea94b1
No checksum
2: https://ftp.gnu.org/gnu/gcc/gcc-7.3.0/gcc-7.3.0.tar.xz
sha512:
ad41a7e4584e40e92cdf860bc0288500fbaf5dfb7e8c3fcabe9eba809c87bcfa85b46c19c19921b0cdf6d05483faede8287bb9ea120c0d1559449a70e602c8d4
3: https://ftp.gnu.org/gnu/gmp/gmp-6.1.0.tar.bz2
sha512:
3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
4: https://ftp.gnu.org/gnu/mpc/mpc-1.0.3.tar.gz
sha512:
0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
5: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2
sha512:
51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
Patches: 0
Preparation:
build_top=$(pwd)
gcc_source="gcc-7.3.0"
source_dir_gcc=${gcc_source}
%setup source gcc -q -n ${gcc_source}
%setup patch gcc -p1
cd ${build_top}
source_dir_newlib=sourceware-mirror-newlib-cygwin-916ef5fb8865f72d0f5ad3f4f479adac44ea94b1
%setup source newlib -q -D -n ${source_dir_newlib}
%setup patch newlib -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/newlib
ln -s $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
source_dir_mpfr="mpfr-3.1.4"
%setup source mpfr -q -D -n mpfr-3.1.4
%setup patch mpfr -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpfr
ln -s $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
source_dir_mpc="mpc-1.0.3"
%setup source mpc -q -D -n mpc-1.0.3
%setup patch mpc -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpc
ln -s $PWD/${source_dir_mpc} ${source_dir_gcc}/mpc
source_dir_gmp="gmp-6.1.0"
%setup source gmp -q -D -n gmp-6.1.0
%setup patch gmp -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/gmp
ln -s $PWD/${source_dir_gmp} ${source_dir_gcc}/gmp
echo "RTEMS 5, RSB 1767b06d488a03954d3baa3d4e5e5a47f569de10, Newlib
916ef5fb8865f72d0f5ad3f4f479adac44ea94b1" > ${source_dir_gcc}/gcc/DEV-PHASE
cd ${source_dir_gcc}
contrib/gcc_update --touch
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
languages="$languages,c++"
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
../${source_dir_gcc}/configure \
--prefix=/build/rtems/5 \
--exec_prefix=/build/rtems/5 \
--includedir=/build/rtems/5/include \
--libexecdir=/build/rtems/5/libexec \
--mandir=/build/rtems/5/share/man \
--infodir=/build/rtems/5/share/info \
--datadir=/build/rtems/5/share \
--disable-libstdcxx-pch \
--with-gnu-as --with-gnu-ld --verbose \
--with-newlib \
--disable-nls --without-included-gettext \
--enable-version-specific-runtime-libs \
--disable-lto \
--enable-newlib-io-c99-formats \
--enable-newlib-iconv \
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,\
cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,\
iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,\
iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,\
iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,\
ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,\
utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,\
win_1253,win_1254,win_1255,win_1256,win_1257,win_1258 \
--enable-threads \
--disable-plugin \
--enable-libgomp \
--enable-languages="$languages"
if test "%_host" != "%_build" ; then
mkdir -p gcc/include
cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
fi
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
/bin/rm -f ${SB_BUILD_ROOT}/build/rtems/5/lib/libiberty.a
/bin/rm -f $SB_BUILD_ROOT/build/rtems/5/bin/moxie-rtems5-c++filt
/bin/rm -f $SB_BUILD_ROOT/build/rtems/5/share/man/man3/*ffi*
/bin/rm -rf ${source_dir_gcc}/newlib
/bin/rm -rf ${source_dir_gcc}/mpfr
/bin/rm -rf ${source_dir_gcc}/mpc
/bin/rm -rf ${source_dir_gcc}/gmp
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:26:50 2018
Report:
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Build Set: (1)
Build Set: (2)
Package:
Config:
Summary:
URL:
http://gcc.gnu.org/
Version:
7.3.0
Release:
1
Sources: 5
No checksum
sha512:
sha512:
sha512:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
--with-newlib \
--disable-lto \
--enable-threads \
--disable-plugin \
--enable-libgomp \
fi
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:29:04 2018
Report: tools/rtems-gdb-8.0.1-1.cfg
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Build Set: (1) tools/rtems-gdb-8.0.1-1.cfg
Build Set: (2) tools/rtems-gdb-8.0.1-1.cfg
Package: moxie-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
Config: tools/rtems-gdb-8.0.1-1.cfg
Summary:
GDB v8.0.1 for target moxie-rtems5 on host x86_64-linux-gnu
URL:
http://www.gnu.org/software/gdb/
Version:
8.0.1
Release:
1
Sources: 1
1: http://ftp.gnu.org/gnu/gdb/gdb-8.0.1.tar.xz
sha512:
5eb328910033f0918058be2f92caebf1e8dfc6caa3c730d99d621627e53de3c1b43761c2f683d53555893253c2f06768cbf56cdea051a3d291ffb6cfae87b5e1
Patches: 1
1:
https://devel.rtems.org/raw-attachment/ticket/3460/gdb-8.0.1-sis-leon2-leon3.diff
sha512:
a16859b5badbce8ecbc9259553b2abe7e93b4fb8ab899e18e8ddb294a1433f49df8ddee418bb6ab55dc2402e5ad6aca6274fb9e8b53278574f269a555fdeddcf
Preparation:
build_top=$(pwd)
gdb_source="gdb-8.0.1"
source_dir_gdb=${gdb_source}
%setup source gdb -q -n ${gdb_source}
%setup patch gdb -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
GDB_LIBS_STATIC="-lexpat"
else
GDB_LIBS="-Xlinker -Bstatic ${LIBS_STATIC} -Xlinker -Bdynamic"
fi
LIBS_STATIC=${GDB_LIBS_STATIC} \
LIBS=${GDB_LIBS} \
../${source_dir_gdb}/configure \
--disable-gas --disable-binutils --disable-ld --disable-gold
--disable-gprof \
--disable-werror \
--enable-sim \
--without-zlib \
--with-expat \
--with-guile=no \
--with-python \
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Summary:
URL:
Version:
8.0.1
Release:
1
Sources: 1
sha512:
Patches: 1
1:
sha512:
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
else
fi
LIBS=${GDB_LIBS} \
--disable-gprof \
--disable-werror \
--enable-sim \
--without-zlib \
--with-expat \
--with-guile=no \
--with-python \
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:29:26 2018
Report: tools/rtems-tools-5-1.cfg
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Build Set: (1) tools/rtems-tools-5-1.cfg
Build Set: (2) tools/rtems-tools-5-1.cfg
Package: rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def-1
Config: tools/rtems-tools-5-1.cfg
Summary:
RTEMS Tools 156b2273a491eba0b0d605fa774d4d81d2ae2def for host
x86_64-linux-gnu
URL:
http://www.rtems.org/
Version:
Release:
1
Sources: 1
1:
https://git.rtems.org/rtems-tools/snapshot/rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def.tar.bz2
sha512:
f7c0f387516d5a1162534acaa2b77890ed5c19cd677b8ec97dd0b8a73c7472d85b4d1260d2e00651b2921c5602faa3537a5e605c36b88f69a0251cd935e9ee78
Patches: 0
Preparation:
build_top=$(pwd)
rtems_tools_source=rtems-tools-156b2273a491eba0b0d605fa774d4d81d2ae2def
source_dir_rtems_tools=${rtems_tools_source}
%setup source rtems-tools -q -n ${rtems_tools_source}
%setup patch rtems-tools -p1
cd ${build_top}
Build:
build_top=$(pwd)
RT_HOST="--host=x86_64-linux-gnu"
else
RT_HOST=
fi
cd ${source_dir_rtems_tools}
./waf distclean configure ${RT_HOST} --prefix=/build/rtems/5
./waf
cd ${build_top}
Install:
build_top=$(pwd)
SB_BUILD_ROOT_WAF=$SB_BUILD_ROOT
./waf --destdir=$SB_BUILD_ROOT_WAF install
cd ${build_top}
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Summary:
x86_64-linux-gnu
URL:
Version:
Release:
1
Sources: 1
1:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
RT_HOST=
fi
./waf
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_top}
Report: tools/rtems-kernel-5.cfg
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Build Set: (1) tools/rtems-kernel-5.cfg
Build Set: (2) tools/rtems-kernel-5.cfg
Package: moxie-rtems5-kernel-5-1
Config: tools/rtems-kernel-5.cfg
Summary:
RTEMS v5 for target moxie-rtems5 on host x86_64-linux-gnu
URL:
Version:
5
Release:
1
Sources: 0
Patches: 0
RTEMS Tools Project <users at rtems.org> Fri Jul 20 14:29:27 2018
Remotes:
1: origin: ssh://
Status:
Clean
Head:
Summary:
URL:
Version:
5
Release:
1
Sources: 0
Patches: 0
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180720/da3f1689/attachment-0001.html>
