[PATCH 2/3] Allow external Newlib sources
Fri Jul 20 14:19:57 UTC 2018
I guess this just follows the pattern used for binutils/gdb on same
targets. Seems fine to me.
On Fri, Jul 20, 2018 at 4:53 AM, Sebastian Huber
>  source-builder/config/gcc-common-1.cfg | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
> index 03d84bc..b432fdf 100644
> --- a/source-builder/config/gcc-common-1.cfg
> +++ b/source-builder/config/gcc-common-1.cfg
> @@ -66,8 +66,8 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
>    cd ${build_top}
>    # newlib
> -  source_dir_newlib="newlib-%{newlib_version}"
> -  %source setup newlib -q -D -n newlib-%{newlib_version}
> +  source_dir_newlib=%{?newlib_external:%{newlib_expand_name}}%{!?newlib_external:"newlib-%{newlib_version}"}
> +  %source setup newlib -q -D -n ${source_dir_newlib}
>    %patch setup newlib -p1
>    cd ${build_top}
> 2.13.7
> devel mailing list
> devel at rtems.org
