[PATCH 3/3] score: Add _CPU_Instruction_illegal()
Fri Jul 20 14:28:33 UTC 2018
I want to reiterate my comment that some ISAs have valid instructions
with an encoding of all zeroes. Off the top of my head, MIPS32 of all
0s is the encoding for sll $0, $0, 0, which is a nop.
I am not too sure about the purpose of the test anymore, as if an
illegal instruction exception occurs, the alignment/data access
exception does not get executed.
Gedare
On Fri, Jul 20, 2018 at 2:53 AM, Sebastian Huber
> On some architectures/simulators it is difficult to provoke an
> exception with misaligned or illegal data loads.  Use an illegal
> instruction instead.
> Update #3433.
>  cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h      |  5 +++++
>  cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h |  5 +++++
>  cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h    |  5 +++++
>  cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h    |  5 +++++
>  cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h   | 10 ++++++++++
>  cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h  |  5 +++++
>  cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h    |  5 +++++
>  cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h       |  5 +++++
>  cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h    |  5 +++++
>  cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h  |  5 +++++
>  cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h     |  5 +++++
>  cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h   |  5 +++++
>  testsuites/sptests/spfatal26/init.c                     | 13 ++++++++++---
>  20 files changed, 110 insertions(+), 3 deletions(-)
> diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
> index d007a7982b..b856349db3 100644
> --- a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
> @@ -106,6 +106,11 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
>  void _CPU_Context_validate( uintptr_t pattern );
> +RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal( void )
> +  __asm__ volatile ( "udf" );
>  RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
>    __asm__ volatile ( "nop" );
> diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
> index 5d8bd77161..78b87ef981 100644
> --- a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
> @@ -37,6 +37,11 @@ RTEMS_INLINE_ROUTINE void _CPU_Context_validate( uintptr_t pattern )
> +  __asm__ volatile ( ".word 0" );
> diff --git a/cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
> index a291aabe2f..5f8102009f 100644
> --- a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
> @@ -29,6 +29,11 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
> diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
> index c13180a06d..86d0ace0f3 100644
> --- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
> @@ -105,6 +105,16 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
> + * @brief Emits an illegal instruction.
> + * This function is used only in test sptests/spfatal26.
>   * @brief Emits a no operation instruction (nop).
>   * This function is used only in test sptests/spcache01.
> diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
> index 148e23c309..e9beab85c8 100644
> --- a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
>    __asm__ volatile ( "l.nop" );
> diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
> index 4f5efe5ba3..e46d9bfabc 100644
> --- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
> @@ -242,6 +242,11 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
> diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
> index 8c29b86c4d..dcf666d2ad 100644
> --- a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
> @@ -317,6 +317,11 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
> diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
> index 93e5b45437..c125b8af72 100644
> --- a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
> @@ -150,6 +150,11 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
> +  __asm__ volatile ( "unimp" );
> diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
> index 5d8bd77161..fab09bb15b 100644
> --- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
> --- a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
> diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> index 543c0918d2..722edeb00e 100644
> --- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> @@ -47,6 +47,11 @@ RTEMS_INLINE_ROUTINE void _CPU_Context_volatile_clobber( uintptr_t pattern )
>    /* TODO */
>    while (1) {
> diff --git a/testsuites/sptests/spfatal26/init.c b/testsuites/sptests/spfatal26/init.c
> index 1848659d6a..3643e46814 100644
> --- a/testsuites/sptests/spfatal26/init.c
> +++ b/testsuites/sptests/spfatal26/init.c
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
> + * Copyright (c) 2012, 2018 embedded brains GmbH.  All rights reserved.
>   *  embedded brains GmbH
>   *  Obere Lagerstr. 30
> @@ -16,14 +16,20 @@
>    #include "config.h"
>  #endif
> -#include "tmacros.h"
> +#include <rtems.h>
> +#include <rtems/score/cpuimpl.h>
>  #include <limits.h>
> -#include <rtems.h>
> +#include <tmacros.h>
>  const char rtems_test_name[] = "SPFATAL 26";
> +static void provoke_illegal_instruction_exception( void )
> +  _CPU_Instruction_illegal();
>  static void provoke_aligment_or_data_access_exception( void )
>    uintptr_t one = 1;
> @@ -53,6 +59,7 @@ static void Init( rtems_task_argument arg )
>    TEST_BEGIN();
> +  provoke_illegal_instruction_exception();
>    provoke_aligment_or_data_access_exception();
>    rtems_test_assert( 0 );
> 2.13.7
> devel mailing list
> devel at rtems.org
