[PATCH] sptests/spfatal26: Use an illegal instruction
Fri Jul 20 15:41:54 UTC 2018
----- Am 20. Jul 2018 um 17:35 schrieb joel joel at rtems.org:
> On Fri, Jul 20, 2018 at 10:22 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
>> On Fri, Jul 20, 2018 at 12:18 AM, Joel Sherrill <joel at rtems.org> wrote:
>> - How our GCC toolchains implicitly have "-lrtemsbsp -lrtemscpu" for
>> when -qrtems is used[1]
>> [1] https://github.com/gcc-mirror/gcc/blob/master/gcc/config/rtems.h#L41
> I think this is not so bad but non-obvious.
> The inconsistent and hacky use of bsp_specs needs to disappear.
The issue with the autoconf link-time feature detection during the GCC build is still not solved.
