[PATCH] Coverage: Add support to generate separate reports for each symbol-set
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Jul 25 02:37:54 UTC 2018
Invoke covoar multiple times from the script to generate separate
reports for each symbol-set.
tester/rt/coverage.py | 32 +++++++++++++--------------
tester/rtems/testing/coverage/symbol-sets.ini | 11 ++++++---
2 files changed, 23 insertions(+), 20 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index 7dd5002..e2f4dca 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -100,7 +100,7 @@ class summary:
class report_gen_html:
def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
- self.symbol_sets_list = ['score']
+ self.symbol_sets_list = p_symbol_sets_list
self.build_dir = build_dir
self.partial_reports_files = list(['index.html', 'summary.txt'])
self.number_of_columns = 1
@@ -267,24 +267,19 @@ class symbol_parser(object):
except:
raise error.general('Symbol set parsing failed')
- def _write_ini(self):
+ def write_ini(self, symbol_set):
config = configparser.ConfigParser()
try:
- sets = ', '.join(self.symbol_sets.keys())
+ sset = symbol_set
config.add_section('symbol-sets')
- config.set('symbol-sets', 'sets', sets)
- for key in self.symbol_sets.keys():
- config.add_section(key)
- config.set(key, 'libraries', self.symbol_sets[key])
+ config.set('symbol-sets', 'sets', sset)
+ config.add_section(sset)
+ config.set(sset, 'libraries', self.symbol_sets[sset])
with open(self.symbol_select_file, 'w') as conf:
config.write(conf)
except:
raise error.general('symbol parser write failed')
- def run(self):
- self.parse()
- self._write_ini()
class covoar(object):
Covoar runner
@@ -371,20 +366,23 @@ class coverage_run(object):
self.symbol_select_path,
self.symbol_set,
build_dir)
- parser.run()
- covoar_runner = covoar(self.test_dir, self.symbol_select_path,
+ parser.parse()
+ ssets = parser.symbol_sets.keys()
+ for sset in ssets:
+ parser.write_ini(sset)
+ covoar_runner = covoar(self.test_dir, self.symbol_select_path,
self.executables, self.explanations_txt,
self.trace)
- covoar_runner.run('score', self.symbol_select_path)
- self._generate_reports();
+ covoar_runner.run(sset, self.symbol_select_path)
+ self._generate_reports(ssets);
self._summarize();
finally:
self._cleanup();
- def _generate_reports(self):
+ def _generate_reports(self, symbol_sets):
log.notice('Coverage generating reports')
if self.report_format == 'html':
- report = report_gen_html(self.symbol_sets,
+ report = report_gen_html(symbol_sets,
self.build_dir,
self.rtdir,
self.macros['bsp'])
diff --git a/tester/rtems/testing/coverage/symbol-sets.ini b/tester/rtems/testing/coverage/symbol-sets.ini
index a2ec7bc..3900f14 100644
--- a/tester/rtems/testing/coverage/symbol-sets.ini
+++ b/tester/rtems/testing/coverage/symbol-sets.ini
@@ -29,8 +29,13 @@
[symbol-sets]
-sets = score,rtems
+sets = score,rtems,libblock,libcrypt,libcsupport,libmd,libnetworking
[libraries]
-score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
-rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
+score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
+rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
+libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
+libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
+libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/libcsupport.a
+libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
+libnetworking = @BUILD-TARGET@/c/@BSP@/cpukit/libnetworking/libnetworking.a
2.14.2
