RISCV Testing was Fwd: [rtems-test] riscv64/rv64imafd_medany: RTEMS_POSIX_API, RTEMS_SMP: Passed:599 Failed:3 Timeout:10 Invalid:0 Wrong:6
Wed Jul 25 13:34:09 UTC 2018
Does this BSP and configuration need to be added to the tiers file?
What tier should RISCV be at now?
---------- Forwarded message ----------
Date: Wed, Jul 25, 2018 at 7:15 AM
Subject: [rtems-test] riscv64/rv64imafd_medany: RTEMS_POSIX_API, RTEMS_SMP:
To: build at rtems.org
Testing time     : 0:06:28.588131
Average test time: 0:00:00.626755
Host
Linux-4.4.138-59-default-x86_64-with-SuSE-42.3-x86_64 (Linux huber-nb-linux
4.4.138-59-default #1 SMP Mon Jun 18 13:48:42 UTC 2018 (f0b8f6b) x86_64
x86_64)
Configuration
Version: 5.0.0.829bf32be17c56597b7bbcdc5d42610e78eb16a6
Build  : RTEMS_POSIX_API,RTEMS_SMP
Tools  : 9.0.0 20180725 (experimental) [master revision
cc1dd160e7a:699e4bf4f66:b3000498acc756b29e019c90a15415c93a4324cf]
Summary
Passed:        599
Failed:          3
User Input:      0
Expected Fail:   0
Indeterminate:   0
Benchmark:       2
Timeout:        10
Invalid:         0
Wrong Version:   0
Wrong Build:     6
Wrong Tools:     0
Total:         620
Failures:
 sp71.exe
 psx12.exe
 psxtimes01.exe
Benchmark:
 dhrystone.exe
 whetstone.exe
Timeouts:
 spintrcritical11.exe
 spintrcritical13.exe
 spintrcritical15.exe
 psxintrcritical01.exe
 spintrcritical07.exe
 spintrcritical18.exe
 spintrcritical06.exe
 spintrcritical12.exe
 spintrcritical14.exe
 spintrcritical24.exe
Wrong Build:
 top.exe
 linpack.exe
 monitor.exe
 termios.exe
 capture.exe
 fileio.exe
Log
RTEMS Testing - Tester, 5.not_released
 Command Line: /build/rtems/5/bin/rtems-test --rtems-bsp=rv64imafd_medany
--rtems-tools=/build/rtems/5 /build/git-build/b-rv64imafd_medany --mail
 Python: 2.7.13 (default, Jan 03 2017, 17:41:54) [GCC]
Host: Linux-4.4.138-59-default-x86_64-with-SuSE-42.3-x86_64 (Linux
huber-nb-linux 4.4.138-59-default #1 SMP Mon Jun 18 13:48:42 UTC 2018
(f0b8f6b) x86_64 x86_64)
[  1/620] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
riscv64/rv64imafd_medany: dhrystone.exe
[  2/620] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
riscv64/rv64imafd_medany: linpack.exe
Result: wrong-build Time: 0:00:01.075545 linpack.exe
=>  run: qemu-system-riscv64 -no-reboot -nographic -net none -machine virt
-m 64M -kernel /build/git-build/b-rv64imafd_medany/riscv-rtems5/c/
rv64imafd_medany/testsuites/benchmarks/linpack.exe
=>  test start: LINPACK
] *** BEGIN OF TEST LINPACK ***
] *** TEST VERSION: 5.0.0.829bf32be17c56597b7bbcdc5d42610e78eb16a6
] *** TEST STATE: BENCHMARK
] *** TEST BUILD: R
[  3/620] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
riscv64/rv64imafd_medany: whetstone.exe
 <<skipping passes>>
[106/620] p:91  f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:1   |
riscv64/rv64imafd_medany: monitor.exe
Result: wrong-build Time: 0:00:01.009003 monitor.exe
rv64imafd_medany/testsuites/libtests/monitor.exe
=>  test start: MONITOR
] *** BEGIN OF TEST MONITOR ***
] *** TEST STATE: USER_INPUT
] *** TEST BUILD: RTEMS_POSIX_API RTEM
[107/620] p:93  f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:1   |
riscv64/rv64imafd_medany: monitor02.exe
 <<skipping passes>>
[125/620] p:109 f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:2   |
riscv64/rv64imafd_medany: termios.exe
Result: wrong-build Time: 0:00:01.041907 termios.exe
rv64imafd_medany/testsuites/libtests/termios.exe
=>  test start: TERMIOS
] *** BEGIN OF TEST TERMIOS ***
[126/620] p:111 f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:2   |
riscv64/rv64imafd_medany: termios01.exe
 <<skipping passes>>
[135/620] p:118 f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:3   |
riscv64/rv64imafd_medany: top.exe
Result: wrong-build Time: 0:00:01.011781 top.exe
rv64imafd_medany/testsuites/libtests/top.exe
=>  test start: TOP
] *** BEGIN OF TEST TOP ***
[136/620] p:119 f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:3   |
riscv64/rv64imafd_medany: tztest.exe
 <<skipping passes>>
[150/620] p:132 f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: psx12.exe
Result: failed     Time: 0:00:02.028519 psx12.exe
rv64imafd_medany/testsuites/psxtests/psx12.exe
=>  test start: PSX 12
] *** BEGIN OF TEST PSX 12 ***
] *** TEST STATE: EXPECTED-PASS
] *** TEST BUILD: RTEMS_POSIX_API RTEMS_SMP
] *** TEST TOOLS: 9.0.0 20180725 (experimental) [master revision
] Init's ID is 0x0b010001
] Init: pthread_attr_init - SUCCESSFUL
] Init: pthread_create - EINVAL (invalid scheduling policy)
] Init: set scheduling parameter attributes for sporadic server
] Init: pthread_create - EINVAL (replenish < budget)
] Init: pthread_create - EINVAL (invalid sched_ss_low_priority)
] Init: pthread_create - SUCCESSFUL
] Sporadic Server: exitting
] [0] H 100ms
] [0] L 199ms
] /home/EB/sebastian_h/git-rtems-5/c/src/../../testsuites/psxtests/psx12/init.c:
224 ctx->samples[ i ].low / SS_REPL_PERIOD_MS == i + 1
] *** FATAL ***
] fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
] fatal code: 0 (0x00000000)
] RTEMS version: 5.0.0.829bf32be17c56597b7bbcdc5d42610e78eb16a6
] RTEMS tools: 9.0.0 20180725 (experimental) [master revision
] executing thread ID: 0x08b010001
] executing thread name:
[151/620] p:133 f:0   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: psx13.exe
 <<skipping passes>>
[192/620] p:173 f:1   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: psxintrcritical01.exe
Result: timeout    Time: 0:03:00.177498 psxintrcritical01.exe
rv64imafd_medany/testsuites/psxtests/psxintrcritical01.exe
=>  test start: PSXINTRCRITICAL 1
] *** BEGIN OF TEST PSXINTRCRITICAL 1 ***
] Init - Trying to generate timer fire from ISR while firing
] Init - Variation is: POSIX Timer
] Init - There is no way for the test to know if it hits the case
] *** TIMEOUT TIMEOUT
[193/620] p:175 f:1   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: psxitimer.exe
 <<skipping passes>>
[238/620] p:219 f:1   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: psxtimes01.exe
Result: failed     Time: 0:00:01.103555 psxtimes01.exe
rv64imafd_medany/testsuites/psxtests/psxtimes01.exe
=>  test start: PSXTIMES 1
] *** BEGIN OF TEST PSXTIMES 1 ***
] times( NULL ) -- EFAULT
] _times_r( NULL, NULL ) -- EFAULT
] _times( &start_tm ) -- OK
] /home/EB/sebastian_h/git-rtems-5/c/src/../../testsuites/psxtests/psxtimes01/init.c:
57 now != 0
] *** FATAL ***
] executing thread ID: 0x08a010001
] executing thread name: UI1
[239/620] p:220 f:1   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: psxualarm.exe
 <<skipping passes>>
[297/620] p:277 f:2   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: capture.exe
Result: wrong-build Time: 0:00:01.011680 capture.exe
rv64imafd_medany/testsuites/samples/capture.exe
=>  test start: CAPTURE ENGINE
] *** BEGIN OF TEST CAPTURE ENGINE ***
[298/620] p:278 f:2   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: cdtest.exe
 <<skipping passes>>
[300/620] p:280 f:2   u:0   e:0   I:0   B:2   t:0   i:0   W:4   |
riscv64/rv64imafd_medany: fileio.exe
Result: wrong-build Time: 0:00:01.050435 fileio.exe
rv64imafd_medany/testsuites/samples/fileio.exe
=>  test start: FILE I/O
] *** BEGIN OF TEST FILE I/O ***
[301/620] p:280 f:2   u:0   e:0   I:0   B:2   t:0   i:0   W:5   |
riscv64/rv64imafd_medany: hello.exe
 <<skipping passes>>
[428/620] p:407 f:2   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: sp71.exe
Result: failed     Time: 0:00:01.012463 sp71.exe
rv64imafd_medany/testsuites/sptests/sp71.exe
=>  test start: SP 71
] *** BEGIN OF TEST SP 71 ***
] 40000 ports created using 8000 per allocation -- need 65535
] Test case NOT hit
] *** FATAL ***
[429/620] p:407 f:2   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: sp72.exe
 <<skipping passes>>
[502/620] p:480 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical06.exe
Result: timeout    Time: 0:03:00.176963 spintrcritical06.exe
rv64imafd_medany/testsuites/sptests/spintrcritical06.exe
=>  test start: SPINTRCRITICAL 6
] *** BEGIN OF TEST SPINTRCRITICAL 6 ***
] Init - Trying to generate semaphore release from ISR while blocking
] Init - Variation is: Priority/Restart Search Task (Forward)
[503/620] p:480 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical07.exe
Result: timeout    Time: 0:03:00.182224 spintrcritical07.exe
rv64imafd_medany/testsuites/sptests/spintrcritical07.exe
=>  test start: SPINTRCRITICAL 7
] *** BEGIN OF TEST SPINTRCRITICAL 7 ***
] Init - Variation is: Priority/Restart Search Task (Backward)
[504/620] p:481 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical08.exe
 <<skipping passes>>
[507/620] p:484 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical11.exe
Result: timeout    Time: 0:03:00.170734 spintrcritical11.exe
rv64imafd_medany/testsuites/sptests/spintrcritical11.exe
=>  test start: SPINTRCRITICAL 11
] *** BEGIN OF TEST SPINTRCRITICAL 11 ***
] Init - Test may not be able to detect case is hit reliably
] Init - Trying to generate event send from ISR while blocking
] Init - Variation is: Event Any condition
[508/620] p:486 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical12.exe
Result: timeout    Time: 0:03:00.176247 spintrcritical12.exe
rv64imafd_medany/testsuites/sptests/spintrcritical12.exe
=>  test start: SPINTRCRITICAL 12
] *** BEGIN OF TEST SPINTRCRITICAL 12 ***
] Init - Variation is: Event All condition
[509/620] p:486 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical13.exe
Result: timeout    Time: 0:03:00.168397 spintrcritical13.exe
rv64imafd_medany/testsuites/sptests/spintrcritical13.exe
=>  test start: SPINTRCRITICAL 13
] *** BEGIN OF TEST SPINTRCRITICAL 13 ***
] Init - Variation is: Timer Fire After
] Init - rtems_timer_create - OK
[510/620] p:487 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical14.exe
Result: timeout    Time: 0:03:00.171100 spintrcritical14.exe
rv64imafd_medany/testsuites/sptests/spintrcritical14.exe
=>  test start: SPINTRCRITICAL 14
] *** BEGIN OF TEST SPINTRCRITICAL 14 ***
] Init - Variation is: Timer Server Fire After
[511/620] p:488 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical15.exe
Result: timeout    Time: 0:03:00.182713 spintrcritical15.exe
rv64imafd_medany/testsuites/sptests/spintrcritical15.exe
=>  test start: SPINTRCRITICAL 15
] *** BEGIN OF TEST SPINTRCRITICAL 15 ***
] Init - Trying to generate timeout of a thread while another is blocking
] Init -   on the same thread queue
] Init - rtems_semaphore_create - OK
] Init - rtems_task_create - OK
[512/620] p:489 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical16.exe
[513/620] p:490 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical18.exe
Result: timeout    Time: 0:03:00.168865 spintrcritical18.exe
rv64imafd_medany/testsuites/sptests/spintrcritical18.exe
=>  test start: SPINTRCRITICAL 18
] *** BEGIN OF TEST SPINTRCRITICAL 18 ***
[514/620] p:491 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical20.exe
 <<skipping passes>>
[518/620] p:495 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: spintrcritical24.exe
Result: timeout    Time: 0:03:00.173587 spintrcritical24.exe
rv64imafd_medany/testsuites/sptests/spintrcritical24.exe
=>  test start: SPINTRCRITICAL 24
] *** BEGIN OF TEST SPINTRCRITICAL 24 ***
[519/620] p:496 f:3   u:0   e:0   I:0   B:2   t:0   i:0   W:6   |
riscv64/rv64imafd_medany: splinkersets01.exe
 <<skipping passes>>
[620/620] p:596 f:3   u:0   e:0   I:0   B:2   t:1   i:0   W:6   |
riscv64/rv64imafd_medany: tmtimer01.exe
Passed:        599
Failed:          3
User Input:      0
Expected Fail:   0
Indeterminate:   0
Benchmark:       2
Timeout:        10
Invalid:         0
Wrong Version:   0
Wrong Build:     6
Wrong Tools:     0
Total:         620
Failures:
 sp71.exe
 psx12.exe
 psxtimes01.exe
Benchmark:
 dhrystone.exe
 whetstone.exe
Timeouts:
Wrong Build:
 top.exe
 linpack.exe
 monitor.exe
 termios.exe
 capture.exe
 fileio.exe
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180725/b67e538e/attachment-0001.html>
