[PATCH v2 2/2] coverage/symbol-sets.ini : Add symbol-sets and paths to respective libraries
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Jul 26 07:39:03 UTC 2018
I have added all the libs in cpukit and commented them out.
Please have a look at the attached file.
On 26 July 2018 at 04:50, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jul 25, 2018 at 10:41 AM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> tester/rtems/testing/coverage/symbol-sets.ini | 11 ++++++++---
>> 1 file changed, 8 insertions(+), 3 deletions(-)
>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>> b/tester/rtems/testing/coverage/symbol-sets.ini
>> index a2ec7bc..3900f14 100644
>> --- a/tester/rtems/testing/coverage/symbol-sets.ini
>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>> @@ -29,8 +29,13 @@
>> [symbol-sets]
>> -sets = score,rtems
>> +sets = score,rtems,libblock,libcrypt,libcsupport,libmd,libnetworking
>> [libraries]
>> -score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>> -rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>> +libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
>> +libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
>> +libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/libcsupport.a
>> +libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
>> +libnetworking = @BUILD-TARGET@/c/@BSP@/cpukit/
>> libnetworking/libnetworking.a
> To be at parity with the old reports but reported on finer granularity,
> follow the list at
> https://git.rtems.org/rtems-testing/tree/rtems-coverage/do_coverage#n507
> and check what is not listed there that is in cpukit now. For example,
> jffs2
> isn't listed in the above. But the things consciously skipped have a good
> reason. Add a list of the ones not included. It may make sense to
> have something like this for the ones deliberately skipped:
> # librpc = @....libXXX.a
> It will make auditing what's in the cpukit versus the ini file easier.
> That's why my old script has them in order and commented out the
> ones we were not ready to do or never would.
> But for sure, add posix, sapi, libdl, individual filesystem, and catch
> the libmisc subdirectories listed in the old script for inclusion. for new
> libmisc content, we can make a decision.
> Don't include libnetworking. As a general rule, we don't do coverage
> testing
> on networking or any (complex) third party software.
> I don't think dtc will get coverage either.
> That should get us closer. I expect you will find some libraries
> to ask questions on. :)
> --joel
>> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180726/6f0aabf8/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180726/6f0aabf8/attachment.obj>
