[PATCH v2 1/2] Coverage: Add support to generate separate reports for each symbol-set
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Jul 28 16:42:57 UTC 2018
ping. :)
On 25 July 2018 at 21:10, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Invoke covoar multiple times from the script to generate separate
> reports for each symbol-set.
> tester/rt/coverage.py | 42 ++++++++++++++++++++----------------------
> 1 file changed, 20 insertions(+), 22 deletions(-)
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> index 7dd5002..fe92d0a 100644
> --- a/tester/rt/coverage.py
> +++ b/tester/rt/coverage.py
> @@ -100,7 +100,7 @@ class summary:
> class report_gen_html:
> def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
> - self.symbol_sets_list = ['score']
> + self.symbol_sets_list = p_symbol_sets_list
> self.build_dir = build_dir
> self.partial_reports_files = list(['index.html', 'summary.txt'])
> self.number_of_columns = 1
> @@ -250,41 +250,37 @@ class symbol_parser(object):
> self.symbol_sets = {}
> self.symbol_set = symbol_set
> - self.ssets = []
> + self.symbol_set_list = []
> def parse(self):
> config = configparser.ConfigParser()
> try:
> config.read(self.symbol_file)
> if self.symbol_set is not None:
> - self.ssets = self.symbol_set.split(',')
> + self.symbol_set_list = self.symbol_set.split(',')
> else:
> - self.ssets = config.get('symbol-sets', 'sets').split(',')
> - self.ssets = [sset.encode('utf-8') for sset in self.ssets]
> - for sset in self.ssets:
> + self.symbol_set_list = config.get('symbol-sets',
> 'sets').split(',')
> + self.symbol_set_list = [sset.encode('utf-8') for sset in
> self.symbol_set_list]
> + for sset in self.symbol_set_list:
> lib = path.join(self.build_dir, config.get('libraries',
> sset))
> self.symbol_sets[sset] = lib.encode('utf-8')
> + return self.symbol_set_list
> except:
> raise error.general('Symbol set parsing failed')
> - def _write_ini(self):
> + def write_ini(self, symbol_set):
> try:
> - sets = ', '.join(self.symbol_sets.keys())
> + sset = symbol_set
> config.add_section('symbol-sets')
> - config.set('symbol-sets', 'sets', sets)
> - for key in self.symbol_sets.keys():
> - config.add_section(key)
> - config.set(key, 'libraries', self.symbol_sets[key])
> + config.set('symbol-sets', 'sets', sset)
> + config.add_section(sset)
> + config.set(sset, 'libraries', self.symbol_sets[sset])
> with open(self.symbol_select_file, 'w') as conf:
> config.write(conf)
> except:
> raise error.general('symbol parser write failed')
> - def run(self):
> - self.parse()
> - self._write_ini()
> class covoar(object):
> Covoar runner
> @@ -371,20 +367,22 @@ class coverage_run(object):
> self.symbol_select_path,
> self.symbol_set,
> build_dir)
> - parser.run()
> - covoar_runner = covoar(self.test_dir, self.symbol_select_path,
> + symbol_set_list = parser.parse()
> + for sset in symbol_set_list:
> + parser.write_ini(sset)
> + covoar_runner = covoar(self.test_dir,
> self.executables,
> self.explanations_txt,
> self.trace)
> - covoar_runner.run('score', self.symbol_select_path)
> - self._generate_reports();
> + covoar_runner.run(sset, self.symbol_select_path)
> + self._generate_reports(symbol_set_list);
> self._summarize();
> finally:
> self._cleanup();
> - def _generate_reports(self):
> + def _generate_reports(self, symbol_sets):
> log.notice('Coverage generating reports')
> if self.report_format == 'html':
> - report = report_gen_html(self.symbol_sets,
> + report = report_gen_html(symbol_sets,
> self.build_dir,
> self.rtdir,
> self.macros['bsp'])
> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180728/12793ee8/attachment.html>
