[PATCH v2 1/2] Coverage: Add support to generate separate reports for each symbol-set
Mon Jul 30 00:57:54 UTC 2018
On 26/07/2018 01:40, Vijay Kumar Banerjee wrote:
> Invoke covoar multiple times from the script to generate separate
> reports for each symbol-set.
>  tester/rt/coverage.py | 42 ++++++++++++++++++++----------------------
>  1 file changed, 20 insertions(+), 22 deletions(-)
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> index 7dd5002..fe92d0a 100644
> --- a/tester/rt/coverage.py
> +++ b/tester/rt/coverage.py
> @@ -100,7 +100,7 @@ class summary:
>  class report_gen_html:
>      def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
I am not a fan of adding type info to variable names, for example
'p_symbol_sets_list' where a design change may make this a dict. Please use
something else.
> -        self.symbol_sets_list = ['score']
> +        self.symbol_sets_list = p_symbol_sets_list
>          self.build_dir = build_dir
>          self.partial_reports_files = list(['index.html', 'summary.txt'])
>          self.number_of_columns = 1
> @@ -250,41 +250,37 @@ class symbol_parser(object):
>          self.symbol_sets = {}
>          self.symbol_set = symbol_set
> -        self.ssets = []
> +        self.symbol_set_list = []
Same here and so on in the patch. Also I do not think this last change is needed.
>      def parse(self):
>          config = configparser.ConfigParser()
>          try:
>              config.read(self.symbol_file)
>              if self.symbol_set is not None:
> -                self.ssets = self.symbol_set.split(',')
> +                self.symbol_set_list = self.symbol_set.split(',')
>              else:
> -                self.ssets = config.get('symbol-sets', 'sets').split(',')
> -                self.ssets = [sset.encode('utf-8') for sset in self.ssets]
> -            for sset in self.ssets:
> +                self.symbol_set_list = config.get('symbol-sets', 'sets').split(',')
> +                self.symbol_set_list = [sset.encode('utf-8') for sset in self.symbol_set_list]
> +            for sset in self.symbol_set_list:
>                  lib = path.join(self.build_dir, config.get('libraries', sset))
>                  self.symbol_sets[sset] = lib.encode('utf-8')
> +            return self.symbol_set_list
>          except:
>              raise error.general('Symbol set parsing failed')
> -    def _write_ini(self):
> +    def write_ini(self, symbol_set):
>          try:
> -            sets = ', '.join(self.symbol_sets.keys())
> +            sset = symbol_set
>              config.add_section('symbol-sets')
> -            config.set('symbol-sets', 'sets', sets)
> -            for key in self.symbol_sets.keys():
> -                config.add_section(key)
> -                config.set(key, 'libraries', self.symbol_sets[key])
> +            config.set('symbol-sets', 'sets', sset)
> +            config.add_section(sset)
> +            config.set(sset, 'libraries', self.symbol_sets[sset])
>              with open(self.symbol_select_file, 'w') as conf:
>                  config.write(conf)
>          except:
>              raise error.general('symbol parser write failed')
> -    def run(self):
> -        self.parse()
> -        self._write_ini()
>  class covoar(object):
>      Covoar runner
> @@ -371,20 +367,22 @@ class coverage_run(object):
>                                     self.symbol_select_path,
>                                     self.symbol_set,
>                                     build_dir)
> -            parser.run()
> -            covoar_runner = covoar(self.test_dir, self.symbol_select_path,
> +            symbol_set_list = parser.parse()
> +            for sset in symbol_set_list:
> +                parser.write_ini(sset)
> +                covoar_runner = covoar(self.test_dir, self.symbol_select_path,
>                                     self.executables, self.explanations_txt,
>                                     self.trace)
> -            covoar_runner.run('score', self.symbol_select_path)
> -            self._generate_reports();
> +                covoar_runner.run(sset, self.symbol_select_path)
> +            self._generate_reports(symbol_set_list);
>              self._summarize();
>          finally:
>              self._cleanup();
> -    def _generate_reports(self):
> +    def _generate_reports(self, symbol_sets):
>          log.notice('Coverage generating reports')
>          if self.report_format == 'html':
> -            report = report_gen_html(self.symbol_sets,
> +            report = report_gen_html(symbol_sets,
>                                       self.build_dir,
>                                       self.rtdir,
>                                       self.macros['bsp'])
