[PATCH] confdefs: Fix uniprocessor configuration
Sebastian Huber
Mon Jul 30 05:39:37 UTC 2018
Introduce a new internal define _CONFIGURE_MAXIMUM_PROCESSORS and ensure
that it is _CONFIGURE_MAXIMUM_PROCESSORS > 1 only in SMP configurations.
This avoids to allocate data structures for non-existing additional
processors in uniprocessor configuration.
Update #3459.
cpukit/include/rtems/confdefs.h | 85 ++++++++++++++--------------
cpukit/libmisc/dummy/default-configuration.c | 2 -
2 files changed, 44 insertions(+), 43 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index e56826af5a..850e5258e8 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -178,8 +178,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
#endif
-#ifndef CONFIGURE_MAXIMUM_PROCESSORS
- #define CONFIGURE_MAXIMUM_PROCESSORS 1
+/* Ensure that _CONFIGURE_MAXIMUM_PROCESSORS > 1 only in SMP configurations */
+#if !defined(CONFIGURE_MAXIMUM_PROCESSORS) && defined(RTEMS_SMP)
+ #define _CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_MAXIMUM_PROCESSORS
+#else
+ #define _CONFIGURE_MAXIMUM_PROCESSORS 1
#endif
@@ -189,7 +192,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#ifdef RTEMS_SMP
#if !defined(CONFIGURE_DISABLE_SMP_CONFIGURATION)
#define _CONFIGURE_SMP_APPLICATION
- #elif CONFIGURE_MAXIMUM_PROCESSORS > 1
+ #elif _CONFIGURE_MAXIMUM_PROCESSORS > 1
#error "CONFIGURE_DISABLE_SMP_CONFIGURATION and CONFIGURE_MAXIMUM_PROCESSORS > 1 makes no sense"
#endif
#endif
@@ -739,7 +742,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
!defined(CONFIGURE_SCHEDULER_EDF) && \
!defined(CONFIGURE_SCHEDULER_EDF_SMP) && \
!defined(CONFIGURE_SCHEDULER_CBS)
- #if defined(RTEMS_SMP) && CONFIGURE_MAXIMUM_PROCESSORS > 1
+ #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
* If no scheduler is specified in an SMP configuration, the
* EDF scheduler is default.
@@ -924,7 +927,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#if !defined(CONFIGURE_SCHEDULER_TABLE_ENTRIES)
/** Configure the context needed by the scheduler instance */
#define CONFIGURE_SCHEDULER \
- RTEMS_SCHEDULER_EDF_SMP(dflt, CONFIGURE_MAXIMUM_PROCESSORS)
+ RTEMS_SCHEDULER_EDF_SMP(dflt, _CONFIGURE_MAXIMUM_PROCESSORS)
/** Configure the controls for this scheduler instance */
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
@@ -991,97 +994,97 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
_CONFIGURE_SCHEDULER_ASSIGN
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 2
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 2
, _CONFIGURE_SCHEDULER_ASSIGN
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 3
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 3
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 4
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 4
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 5
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 5
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 6
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 6
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 7
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 7
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 8
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 8
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 9
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 9
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 10
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 10
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 11
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 11
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 12
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 12
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 13
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 13
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 14
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 14
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 15
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 15
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 16
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 16
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 17
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 17
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 18
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 18
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 19
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 19
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 20
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 20
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 21
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 21
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 22
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 22
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 23
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 23
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 24
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 24
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 25
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 25
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 26
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 26
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 27
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 27
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 28
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 28
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 29
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 29
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 30
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 30
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 31
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 31
#endif
- #if CONFIGURE_MAXIMUM_PROCESSORS >= 32
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 32
#endif
#undef _CONFIGURE_SCHEDULER_ASSIGN
@@ -1089,7 +1092,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
RTEMS_STATIC_ASSERT(
- CONFIGURE_MAXIMUM_PROCESSORS
+ _CONFIGURE_MAXIMUM_PROCESSORS
== RTEMS_ARRAY_SIZE( _Scheduler_Initial_assignments ),
@@ -1208,7 +1211,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
char _Configuration_Interrupt_stack_area_begin[
- CONFIGURE_MAXIMUM_PROCESSORS * CONFIGURE_INTERRUPT_STACK_SIZE
+ _CONFIGURE_MAXIMUM_PROCESSORS * CONFIGURE_INTERRUPT_STACK_SIZE
] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
RTEMS_SECTION( ".rtemsstack.interrupt.begin" );
@@ -2702,7 +2705,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This calculates the amount of memory reserved for the IDLE tasks.
* In an SMP system, each CPU core has its own idle task.
-#define _CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_MAXIMUM_PROCESSORS
+#define _CONFIGURE_IDLE_TASKS_COUNT _CONFIGURE_MAXIMUM_PROCESSORS
* This defines the formula used to compute the amount of memory
@@ -3102,7 +3105,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
CONFIGURE_MULTIPROCESSING_TABLE, /* pointer to MP config table */
#endif
#ifdef RTEMS_SMP
- CONFIGURE_MAXIMUM_PROCESSORS,
+ _CONFIGURE_MAXIMUM_PROCESSORS,
#endif
#endif
@@ -3114,7 +3117,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Instantiate the Per CPU information based upon the user configuration.
#if defined(CONFIGURE_INIT)
- Per_CPU_Control_envelope _Per_CPU_Information[CONFIGURE_MAXIMUM_PROCESSORS];
+ Per_CPU_Control_envelope _Per_CPU_Information[_CONFIGURE_MAXIMUM_PROCESSORS];
#endif
#endif
diff --git a/cpukit/libmisc/dummy/default-configuration.c b/cpukit/libmisc/dummy/default-configuration.c
index c6ddfeb184..95db194470 100644
--- a/cpukit/libmisc/dummy/default-configuration.c
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -103,9 +103,7 @@ static void Init( rtems_task_argument arg )
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#if defined(RTEMS_SMP)
#define CONFIGURE_MAXIMUM_PROCESSORS CPU_MAXIMUM_PROCESSORS
-#endif
#define CONFIGURE_DISABLE_BSP_SETTINGS
2.13.7
