Many ARM Test Build Failures
Joel Sherrill
joel at rtems.org
Mon Jul 30 16:38:35 UTC 2018
As of this morning, it looks like the failures I was seeing are still
present.
>From arm/csb336:
/data/home/joel/rtems-work/tools/5/bin/../lib/gcc/arm-rtems5/7.3.0/../../../../arm-rtems5/bin/ld:
sptimecounter02.exe section `.rtemsstack' will not fit in region `SRAM'
sptimecounter03.exe section `.rtemsstack' will not fit in region `SRAM'
tmcontext01.exe section `.rtemsstack' will not fit in region `SRAM'
flashdisk01.exe section `.rtemsstack' will not fit in region `SRAM'
There were similar failures in many arm BSPs. These seem to be specific to
the .rtemsstack region.
Some random ones from different BSP families: lm3s6965, raspberrypi,
lpc24xx_ncs_ram, rtl22xx
--joel
On Mon, Jul 30, 2018 at 12:40 AM, Sebastian Huber <
> Hello,
> this was a bug in confdefs.h:
> https://lists.rtems.org/pipermail/devel/2018-July/022599.html
> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180730/7dcb4216/attachment.html>
