[PATCH v4] Coverage: Add support to generate separate reports for each symbol-set
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Jul 30 16:40:03 UTC 2018
Invoke covoar multiple times from the script to generate separate
reports for each symbol-set.
tester/rt/coverage.py | 38 ++++++++++++++++++--------------------
1 file changed, 18 insertions(+), 20 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index 7dd5002..c979332 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -99,8 +99,8 @@ class summary:
return line.strip().split(' ')[0]
class report_gen_html:
- def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
- self.symbol_sets_list = ['score']
+ def __init__(self, symbol_sets, build_dir, rtdir, bsp):
+ self.symbol_sets = symbol_sets
self.build_dir = build_dir
self.partial_reports_files = list(['index.html', 'summary.txt'])
self.number_of_columns = 1
@@ -109,7 +109,7 @@ class report_gen_html:
def _find_partial_reports(self):
partial_reports = {}
- for symbol_set in self.symbol_sets_list:
+ for symbol_set in self.symbol_sets:
set_summary = summary(path.join(self.bsp + "-coverage",
symbol_set))
set_summary.parse()
@@ -204,7 +204,7 @@ class report_gen_html:
def add_covoar_src_path(self):
table_js_path = path.join(self.covoar_src_path, 'table.js')
covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
symbol_set_dir = path.join(self.build_dir,
self.bsp + '-coverage', symbol_set)
html_files = os.listdir(symbol_set_dir)
@@ -264,27 +264,23 @@ class symbol_parser(object):
for sset in self.ssets:
lib = path.join(self.build_dir, config.get('libraries', sset))
self.symbol_sets[sset] = lib.encode('utf-8')
+ return self.ssets
except:
raise error.general('Symbol set parsing failed')
- def _write_ini(self):
+ def write_ini(self, symbol_set):
config = configparser.ConfigParser()
try:
- sets = ', '.join(self.symbol_sets.keys())
+ sset = symbol_set
config.add_section('symbol-sets')
- config.set('symbol-sets', 'sets', sets)
- for key in self.symbol_sets.keys():
- config.add_section(key)
- config.set(key, 'libraries', self.symbol_sets[key])
+ config.set('symbol-sets', 'sets', sset)
+ config.add_section(sset)
+ config.set(sset, 'libraries', self.symbol_sets[sset])
with open(self.symbol_select_file, 'w') as conf:
config.write(conf)
except:
raise error.general('symbol parser write failed')
- def run(self):
- self.parse()
- self._write_ini()
class covoar(object):
Covoar runner
@@ -371,20 +367,22 @@ class coverage_run(object):
self.symbol_select_path,
self.symbol_set,
build_dir)
- parser.run()
- covoar_runner = covoar(self.test_dir, self.symbol_select_path,
+ symbol_sets = parser.parse()
+ for sset in symbol_sets:
+ parser.write_ini(sset)
+ covoar_runner = covoar(self.test_dir, self.symbol_select_path,
self.executables, self.explanations_txt,
self.trace)
- covoar_runner.run('score', self.symbol_select_path)
- self._generate_reports();
+ covoar_runner.run(sset, self.symbol_select_path)
+ self._generate_reports(symbol_sets);
self._summarize();
finally:
self._cleanup();
- def _generate_reports(self):
+ def _generate_reports(self, symbol_sets):
log.notice('Coverage generating reports')
if self.report_format == 'html':
- report = report_gen_html(self.symbol_sets,
+ report = report_gen_html(symbol_sets,
self.build_dir,
self.rtdir,
self.macros['bsp'])
2.14.4
