[PATCH v3] coverage : Add support to run coverage in supported bsp without extra options
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Jul 10 15:18:57 UTC 2018
On 10 July 2018 at 20:47, Gedare Bloom <gedare at rtems.org> wrote:
> I don't see any problem with it, but I prefer to let Chris decide on
> merging...
> Thank you for the feedback :)
> On Tue, Jul 10, 2018 at 8:11 AM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > ping :)
> > On 6 July 2018 at 02:08, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> > wrote:
> >> Hello Chris,
> >> If you find some time, please review this patch.
> >> It's a small patch but it's important since it affects how the command
> >> will look like.
> >> please review if this patch is alright or we need to have a different
> >> approach.
> >> Thanks
> >> On 3 July 2018 at 20:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
> >> wrote:
> >>> Close #3440
> >>>  tester/rt/test.py                            | 21
> >>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini |  1 +
> >>>  2 files changed, 15 insertions(+), 7 deletions(-)
> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
> >>> index 9214ad6..5d25d82 100644
> >>> --- a/tester/rt/test.py
> >>> +++ b/tester/rt/test.py
> >>> @@ -232,7 +232,7 @@ def run(command_path = None):
> >>>                      '--filter':         'Glob that executables must
> >>> match to run (default: ' +
> >>>                                default_exefilter + ')',
> >>>                      '--stacktrace':     'Dump a stack trace on a user
> >>> termination (^C)',
> >>> -                    '--coverage':       'Perform coverage analysis of
> >>> test executables.'}
> >>> +                    '--coverage-sets':  'Perform coverage analysis for
> >>> specific sets.'}
> >>>          mailer.append_options(optargs)
> >>>          opts = options.load(sys.argv,
> >>>                              optargs = optargs,
> >>> @@ -283,14 +283,21 @@ def run(command_path = None):
> >>>              raise error.general('RTEMS BSP not provided or an invalid
> >>> option')
> >>>          bsp = config.load(bsp[1], opts)
> >>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
> >>> -        coverage_enabled = opts.find_arg('--coverage')
> >>> +        coverage_sets = opts.find_arg('--coverage-sets')
> >>> +        try:
> >>> +            coverage_enabled = opts.defaults.get('coverage')
> >>> +        except:
> >>> +            coverage_enabled = False
> >>>          if coverage_enabled:
> >>>              cov_trace = 'cov' in debug_trace.split(',')
> >>> -            if len(coverage_enabled) == 2:
> >>> -                coverage_runner = coverage.coverage_run(opts.
> defaults,
> >>> -                                                        executables,
> >>> -                                                        symbol_set =
> >>> coverage_enabled[1],
> >>> -                                                        trace =
> >>> cov_trace)
> >>> +            if coverage_sets:
> >>> +                if len(coverage_sets) != 2:
> >>> +                    raise error.general('No sets provided in
> >>> --coverage-sets')
> >>> +                else:
> >>> +                    coverage_runner =
> >>> coverage.coverage_run(opts.defaults,
> executables,
> symbol_set =
> >>> coverage_sets[1],
> >>> +                                                            trace =
> >>> cov_trace)
> >>>              else:
> defaults,
> >>>                                                          executables,
> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> index 2f89117..6462448 100644
> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> @@ -38,3 +38,4 @@ target            = sparc-rtems5
> >>>  tester            = %{_rtscripts}/qemu.cfg
> >>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
> >>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
> >>> +coverage          = True
> >>> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180710/a1877a95/attachment-0002.html>
