[PATCH 2/2] x86_64/console: Add NS16550 polled console driver
Joel Sherrill
joel at rtems.org
Wed Jul 11 20:44:15 UTC 2018
After discussion with Chris and a confirmation from Amaan, I have pushed
this patch set which means we now have x86_64 and the amd64 BSP.
Amaan would be the first to tell you that it needs more love but it
does run hello world and is far enough along where others can
begin to experiment with and enhance it.
Thanks Amaan. We all look forward to you guiding this port and
BSP to maturity. :)
--joel
On Mon, Jul 9, 2018 at 6:12 AM, Amaan Cheval <amaan.cheval at gmail.com> wrote:
> This addition allows us to successfully run the sample hello.exe test.
> Updates #2898.
> bsps/x86_64/amd64/console/console.c | 123
> c/src/lib/libbsp/x86_64/amd64/Makefile.am | 2 +
> .../score/cpu/x86_64/include/rtems/score/cpuimpl.h | 14 +++
> .../score/cpu/x86_64/include/rtems/score/x86_64.h | 3 +
> 4 files changed, 49 insertions(+), 93 deletions(-)
> diff --git a/bsps/x86_64/amd64/console/console.c
> b/bsps/x86_64/amd64/console/console.c
> index b272b679d7..5408c57fe7 100644
> --- a/bsps/x86_64/amd64/console/console.c
> +++ b/bsps/x86_64/amd64/console/console.c
> @@ -24,112 +24,49 @@
> * SUCH DAMAGE.
> -#include <bsp.h>
> +#include <libchip/ns16550.h>
> #include <rtems/bspIo.h>
> -#include <rtems/libio.h>
> -/* console_initialize
> - * This routine initializes the console IO driver.
> - * Input parameters: NONE
> - * Output parameters: NONE
> - * Return values:
> +#include <bsp.h>
> +#include <bsp/console-termios.h>
> +#include <rtems/score/cpuimpl.h>
> -rtems_device_driver console_initialize(
> - rtems_device_major_number major,
> - rtems_device_minor_number minor,
> - void *arg
> +static uint8_t amd64_uart_get_register(uintptr_t addr, uint8_t i)
> - (void) major;
> - (void) minor;
> - (void) arg;
> - return RTEMS_SUCCESSFUL;
> + return inport_byte(addr + i);
> - * Open entry point
> -rtems_device_driver console_open(
> - void * arg
> +static void amd64_uart_set_register(uintptr_t addr, uint8_t i, uint8_t
> val)
> - (void) major;
> - (void) minor;
> - (void) arg;
> + outport_byte(addr + i, val);
> - * Close entry point
> -rtems_device_driver console_close(
> - void * arg
> - (void) major;
> - (void) minor;
> - (void) arg;
> +static ns16550_context amd64_uart_context = {
> + .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("UART"),
> + .get_reg = amd64_uart_get_register,
> + .set_reg = amd64_uart_set_register,
> + .port = (uintptr_t) COM1_BASE_IO,
> + .initial_baud = COM1_CLOCK_RATE
> - * read bytes from the serial port. We only have stdin.
> + * XXX: We should use the interrupt based handler once interrupts are
> supported
> +const console_device console_device_table[] = {
> + .device_file = "/dev/console",
> + .probe = console_device_probe_default,
> + .handler = &ns16550_handler_polled,
> + .context = &amd64_uart_context.base
> +const size_t console_device_count = RTEMS_ARRAY_SIZE(console_
> device_table);
> -rtems_device_driver console_read(
> - void * arg
> +static void output_char(char c)
> - (void) major;
> - (void) minor;
> - (void) arg;
> + rtems_termios_device_context *ctx = console_device_table[0].context;
> - * write bytes to the serial port. Stdout and stderr are the same.
> -rtems_device_driver console_write(
> - void * arg
> - (void) major;
> - (void) minor;
> - (void) arg;
> - return 0;
> - * IO Control entry point
> -rtems_device_driver console_control(
> - void * arg
> - (void) major;
> - (void) minor;
> - (void) arg;
> + ns16550_polled_putchar(ctx, c);
> -BSP_output_char_function_type BSP_output_char = NULL;
> -BSP_polling_getchar_function_type BSP_poll_char = NULL;
> +BSP_output_char_function_type BSP_output_char = output_char;
> +BSP_polling_getchar_function_type BSP_poll_char = NULL;
> diff --git a/c/src/lib/libbsp/x86_64/amd64/Makefile.am
> b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
> index f05b40f3f9..aa40f6224f 100644
> --- a/c/src/lib/libbsp/x86_64/amd64/Makefile.am
> +++ b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
> @@ -29,6 +29,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/
> start/bspreset-empty.c
> # clock
> dev/clock/clock-simidle.c
> # console
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/
> dev/serial/console-termios-init.c
> dev/serial/console-termios.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/
> # timer
> dev/btimer/btimer-stub.c
> diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> index bac092c320..67fe712a32 100644
> --- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> @@ -28,6 +28,20 @@
> extern "C" {
> #endif
> +static inline uint8_t inport_byte(uint16_t port)
> + uint8_t ret;
> + __asm__ volatile ( "inb %1, %0"
> + : "=a" (ret)
> + : "Nd" (port) );
> + return ret;
> +static inline void outport_byte(uint16_t port, uint8_t val)
> + __asm__ volatile ( "outb %0, %1" : : "a" (val), "Nd" (port) );
> #ifdef __cplusplus
> #endif
> diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
> b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
> index 237d95de98..853e45ab5d 100644
> --- a/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
> +++ b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
> @@ -34,6 +34,9 @@ extern "C" {
> #define CPU_NAME "x86-64"
> #define CPU_MODEL_NAME "XXX: x86-64 generic"
> +#define COM1_BASE_IO 0x3F8
> +#define COM1_CLOCK_RATE (115200 * 16)
> #ifdef __cplusplus
> #endif
> 2.15.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180711/0ee664ce/attachment-0002.html>
