[PATCH 44/45] libfdt: Add necessary header padding in fdt_create()
    Sebastian Huber
    Wed Jul 18 07:35:53 UTC 2018
From: David Gibson <david at gibson.dropbear.id.au>
At present fdt_create() will succeed if there is exactly enough space to
put in the fdt header.  However, it sets the off_mem_rsvmap field, a few
bytes past that in order to align the memory reservation block.
Having block pointers pointing past the end of the fdt is pretty ugly, even
if it is just a transient state.  Worse, if fdt_resize() is called at
exactly the wrong time, it can end up accessing data past the blob's
allocated space because of this.
So, correct fdt_create() to ensure that there is sufficient space for the
alignment padding as well as the plain header.  For paranoia, also add a
check in fdt_resize() to make sure we don't copy data from outside the
blob's bounds.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_sw.c | 10 +++++++---
 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 024f4d85de..9fa4a94d83 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -143,9 +143,11 @@ static void *fdt_grab_space_(void *fdt, size_t len)
 int fdt_create(void *buf, int bufsize)
+	const size_t hdrsize = FDT_ALIGN(sizeof(struct fdt_header),
+					 sizeof(struct fdt_reserve_entry));
 	void *fdt = buf;
-	if (bufsize < sizeof(struct fdt_header))
+	if (bufsize < hdrsize)
 		return -FDT_ERR_NOSPACE;
 	memset(buf, 0, bufsize);
@@ -155,8 +157,7 @@ int fdt_create(void *buf, int bufsize)
 	fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION);
 	fdt_set_totalsize(fdt,  bufsize);
-	fdt_set_off_mem_rsvmap(fdt, FDT_ALIGN(sizeof(struct fdt_header),
-					      sizeof(struct fdt_reserve_entry)));
+	fdt_set_off_mem_rsvmap(fdt, hdrsize);
 	fdt_set_off_dt_struct(fdt, fdt_off_mem_rsvmap(fdt));
 	fdt_set_off_dt_strings(fdt, 0);
@@ -173,6 +174,9 @@ int fdt_resize(void *fdt, void *buf, int bufsize)
 	headsize = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt);
 	tailsize = fdt_size_dt_strings(fdt);
+	if ((headsize + tailsize) > fdt_totalsize(fdt))
+		return -FDT_ERR_INTERNAL;
 	if ((headsize + tailsize) > bufsize)
2.13.7
