[PATCH 1/1] user: Add x86_64 BSP chapter
    Joel Sherrill
    joel at rtems.org
    Wed Jul 18 17:48:50 UTC 2018
Thanks Gedare. It is pushed now. Just had to find it.
On Wed, Jul 18, 2018 at 12:40 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Ping -- joel
> On Fri, Jul 13, 2018 at 9:19 AM, Gedare Bloom <gedare at rtems.org> wrote:
> > This looks fine to push
> > On Fri, Jul 13, 2018 at 3:32 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
> >>  user/bsps/bsps-x86_64.rst | 143 ++++++++++++++++++++++++++++++
> >>  1 file changed, 142 insertions(+), 1 deletion(-)
> >> diff --git a/user/bsps/bsps-x86_64.rst b/user/bsps/bsps-x86_64.rst
> >> index 18f80d2..19c4461 100644
> >> --- a/user/bsps/bsps-x86_64.rst
> >> +++ b/user/bsps/bsps-x86_64.rst
> >> @@ -1,7 +1,148 @@
> >>  .. comment SPDX-License-Identifier: CC-BY-SA-4.0
> >> +.. comment Copyright (c) 2018 Amaan Cheval <amaan.cheval at gmail.com>
> >>  .. comment Copyright (c) 2018 embedded brains GmbH
> >>  x86_64
> >> -There are no x86_64 BSPs yet.
> >> +amd64
> >> +This BSP offers only one variant, ``amd64``. The BSP can run on
> UEFI-capable
> >> +systems by using FreeBSD's bootloader, which then loads the RTEMS
> executable (an
> >> +ELF image).
> >> +Currently only the console driver and context initialization and
> switching are
> >> +functional (to a bare minimum), but this is enough to run the
> ``hello.exe`` sample
> >> +in the RTEMS testsuite.
> >> +Build Configuration Options
> >> +There are no options available to ``configure`` at build time, at the
> moment.
> >> +Testing with QEMU
> >> +To test with QEMU, we need to:
> >> +- Build / install QEMU (most distributions should have it available on
> the
> >> +  package manager).
> >> +- Build UEFI firmware that QEMU can use to simulate an x86-64 system
> capable of
> >> +  booting a UEFI-aware kernel, through the ``--bios`` flag.
> >> +Building TianoCore's UEFI firmware, OVMF
> >> +Complete detailed instructions are available at `TianoCore's Github's
> wiki
> >> +<https://github.com/tianocore/tianocore.github.io/
> wiki/How-to-build-OVMF>`_.
> >> +Quick instructions (which may fall out of date) are:
> >> +.. code-block:: shell
> >> +    $ git clone git://github.com/tianocore/edk2.git
> >> +    $ cd edk2
> >> +    $ make -C BaseTools
> >> +    $ . edksetup.sh
> >> +Then edit ``Conf/target.txt`` to set:
> >> +    ACTIVE_PLATFORM       = OvmfPkg/OvmfPkgX64.dsc
> >> +    TARGET                = DEBUG
> >> +    TARGET_ARCH           = X64
> >> +    # You can use GCC46 as well, if you'd prefer
> >> +    TOOL_CHAIN_TAG        = GCC5
> >> +Then run ``build`` in the ``edk2`` directory - the output should list
> the
> >> +location of the ``OVMF.fd`` file, which can be used with QEMU to boot
> into a UEFI
> >> +shell.
> >> +You can find the ``OVMF.fd`` file like this as well in the edk2
> directory:
> >> +    $ find . -name "*.fd"
> >> +    ./Build/OvmfX64/DEBUG_GCC5/FV/MEMFD.fd
> >> +    ./Build/OvmfX64/DEBUG_GCC5/FV/OVMF.fd <-- the file we're looking
> for
> >> +    ./Build/OvmfX64/DEBUG_GCC5/FV/OVMF_CODE.fd
> >> +    ./Build/OvmfX64/DEBUG_GCC5/FV/OVMF_VARS.fd
> >> +Boot RTEMS via FreeBSD's bootloader
> >> +The RTEMS executable produced (an ELF file) needs to be placed in the
> FreeBSD's
> >> +``/boot/kernel/kernel``'s place.
> >> +To do that, we first need a hard-disk image with FreeBSD installed on
> >> +it. `Download FreeBSD's installer "memstick" image for amd64
> >> +<https://www.freebsd.org/where.html>`_ and then run the following
> commands,
> >> +replacing paths as appropriate.
> >> +   $ qemu-img create freebsd.img 8G
> >> +   $ OVMF_LOCATION=/path/to/ovmf/OVMF.fd
> >> +   $ FREEBSD_MEMSTICK=/path/to/FreeBSD-11.2-amd64-memstick.img
> >> +   $ qemu-system-x86_64 -m 1024 -serial stdio --bios $OVMF_LOCATION \
> >> +       -drive format=raw,file=freebsd.img \
> >> +       -drive format=raw,file=$FREEBSD_MEMSTICK
> >> +The first time you do this, continue through and install FreeBSD.
> `FreeBSD's
> >> +installation guide may prove useful
> >> +<https://www.freebsd.org/doc/handbook/bsdinstall-start.html>`_ if
> required.
> >> +Once installed, build your RTEMS executable (an ELF file), for
> >> +eg. ``hello.exe``. We need to transfer this executable into
> ``freebsd.img``'s
> >> +filesystem, at either ``/boot/kernel/kernel`` or
> ``/boot/kernel.old/kernel`` (or
> >> +elsewhere, if you don't mind user FreeBSD's ``loader``'s prompt to
> boot your
> >> +custom kernel).
> >> +If your host system supports mounting UFS filesystems as read-write
> >> +(eg. FreeBSD), go ahead and:
> >> +1. Mount ``freebsd.img`` as read-write
> >> +2. Within the filesystem, back the existing FreeBSD kernel up (i.e.
> effectively
> >> +   ``cp -r /boot/kernel /boot/kernel.old``).
> >> +3. Place your RTEMS executable at ``/boot/kernel/kernel``
> >> +If your host doesn't support mounting UFS filesystems (eg. most Linux
> kernels),
> >> +do something to the effect of the following.
> >> +On the host
> >> +   # Upload hello.exe anywhere accessible within the host
> >> +   $ curl --upload-file hello.exe https://transfer.sh/rtems
> >> +Then on the guest (FreeBSD), login with ``root`` and
> >> +   # Back the FreeBSD kernel up
> >> +   $ cp -r /boot/kernel/ /boot/kernel.old
> >> +   # Bring networking online if it isn't already
> >> +   $ dhclient em0
> >> +   # You may need to add the --no-verify-peer depending on your server
> >> +   $ fetch https://host.com/path/to/rtems/hello.exe
> >> +   # Replace default kernel
> >> +   $ cp hello.exe /boot/kernel/kernel
> >> +   $ reboot
> >> +After rebooting, the RTEMS kernel should run after the UEFI firmware
> and
> >> +FreeBSD's bootloader. The ``-serial stdio`` QEMU flag will let the
> RTEMS console
> >> +send its output to the host's ``stdio`` stream.
> >> +Clock Driver
> >> +The clock driver currently uses the idle thread clock driver.
> >> +Console Driver
> >> +The console driver defaults to using the ``COM1`` UART port (at I/O
> port
> >> +``0x3F8``), using the ``NS16550`` polled driver.
> >> 2.16.0.rc0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180718/8e0ced91/attachment-0002.html>
