[PATCH v2] tester: Add script to generate html coverage report from covoar output
Fri Jun 1 15:00:11 UTC 2018
On Fri, Jun 1, 2018 at 10:28 AM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> On 1 June 2018 at 19:24, Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Jun 1, 2018 at 2:46 AM, Vijay Kumar Banerjee
>>> Here's the list of Ideas for improvements:
>>> 1. Include the section coverage in the bsp config file.
>>>     If the section is not found then the script will show
>>>     proper error showing coverage is not supported for the
>>>     provided bsp config file.
>>> 2. Update covoar to add support for separate coverage report
>>>     for each symbol set.
>>> 3. Add a method somewhere in covoar to get the size of an instruction
>>>     and fix the hard coded size 4 in ObjdumpProcessor.cc
>> What about a single XXX_run command? What about that suggestion?
> The suggestion was to turn test_run and coverage_run into a single command.
> I have kept them separate so that there's a possibility to just run the
> test.
> If we want to run coverage everytime we run the test. we can do it.
> Then I think the --coverage option can be changed to --coverage-sets
> to mention the sets.
> If that's what we're looking for then I don't think a separate ticket is
> needed,
> I can try to do it within tomorrow and submit an updated patch.
>> Will there be an update to this patch?
> This patch is working an showing results. I don't have any work
> going related to this patch currently.
> If there are any suggestions, I'll try to include all the suggested updates
> as soon as possible and submit. So that we can get it merged.
I get confused by the similarity between test_run() and coverage_run()
names, and now I'm also seeing some confusion because there is a
function coverage_run() and a class coverage_run. I suggest you remove
this function coverage_run(), and make either coverage_run.__init__()
or coverage_run.run() take the executables as a parameter directly.
-Gedare
