[PATCH] Updating trace buffer configuration
Fri Jun 1 21:15:14 UTC 2018
On 31/5/18 1:35 am, Amaan Cheval wrote> Minor, but in most other places in
RTEMS, I've seen pointers declared
> with the asterisk on the variable not on the type ("int *ptr;" instead
> of "int* ptr;").
I write code with the '*' on the type, after all it is an integer pointer (int*
v;) and not a pointer variable of some type (int *v;) and when you use C++ it is
a type reference, ie 'int& v', and not the address of a variable, ie 'int &v;'.
As a result I prefer to be consistent across C and C++.
Please do not touch the existing coding model used here. I will not accept
changes of that nature.
