[GSoC - x86_64 BSP] Using fPIC to compile RTEMS as a shared library
Amaan Cheval amaan.cheval at gmail.com
Mon Jun 4 10:20:47 UTC 2018
That's a good idea. That way based on the multilib variant, Newlib would be
compiled using fPIC, yes?
Then I could simply figure out how to solve the crtbegin and crtend dilemma
(which I believe should be easier), and use those to have a dynamic/shared
RTEMS kernel + user application.
If that sounds right, I'll look into that first. Not familiar with the GCC
source yet, but it should be doable.
On Mon, Jun 4, 2018, 3:43 PM Sebastian Huber <
> Hello Amaan,
> can't you add a new multilib variant which includes -fPIC to the GCC
> configuration for RTEMS?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180604/526b77d9/attachment.html>
