question about rtc command
Gedare Bloom
gedare at rtems.org
Mon Jun 4 14:14:47 UTC 2018
Indeed, this 'rtc' shell command seems to be a bit of a misnomer. It
conflates access to two different clocks, the tod and rtc. Probably,
it would be better to provide a separate 'tod' command that
reads/writes the tod values, and refactor this 'rtc' to read/write the
rtc. I'm not quite sure about the correctness of writing to the rtc
without updating the tod, though.
On Mon, May 28, 2018 at 3:22 AM, jameszxj <jameszxj at gmail.com> wrote:
> hi all,
> rtc command return the current time of day, it seems unreasonable. I
> think it should return the time of real time clock.
> Any other reasons to do so?
> devel mailing list
> devel at rtems.org
