question about rtc command
Mon Jun 4 14:51:31 UTC 2018
----- Am 4. Jun 2018 um 16:43 schrieb joel joel at rtems.org:
> On Mon, Jun 4, 2018 at 9:36 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> ----- Am 4. Jun 2018 um 16:27 schrieb joel joel at rtems.org:
>> > On Mon, Jun 4, 2018 at 9:14 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> Indeed, this 'rtc' shell command seems to be a bit of a misnomer. It
>> >> conflates access to two different clocks, the tod and rtc. Probably,
>> >> it would be better to provide a separate 'tod' command that
>> >> reads/writes the tod values, and refactor this 'rtc' to read/write the
>> >> rtc. I'm not quite sure about the correctness of writing to the rtc
>> >> without updating the tod, though.
>> > Speaking from RTEMS history here. We tended to use Time of Day
>> > to refer to what RTEMS was maintaining and Real-Time Clock to
>> > review to battery backed clocks that are ICs. This matches Wikipedia's
>> > definition and example of a DS1307.
>> > The driver framework in RTEMS is referred to as RTC but some BSPs
>> > call the driver TOD and name files and directories accordingly.
>> > Renaming TOD drivers to RTC derived names has been on my wish
>> > list for a long time.
>> All the RTC drivers should be now in an "rtc" directory.
> Great! Did you rename the files at the same time? There were some
> todcfg.c files as I recall and other variants.
No, I didn't look at the file names.
