[PATCH v3] tester: Add script to generate html coverage report from covoar output
Joel Sherrill
joel at rtems.org
Tue Jun 5 22:27:57 UTC 2018
I think everything is pushed. Is there any patch outstanding?
On Mon, Jun 4, 2018 at 3:44 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Add support in tester to run covoar and generate an html report to display
> the summary of the coverage reports generated from covoar.
> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
> .gitignore | 1 +
> tester/rt/coverage.py | 385
> tester/rt/test.py | 34 ++-
> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
> tester/rtems/testing/qemu.cfg | 4 +-
> 6 files changed, 450 insertions(+), 13 deletions(-)
> create mode 100644 tester/rt/coverage.py
> create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
> diff --git a/.gitignore b/.gitignore
> index 6ab3709..93cb5d2 100644
> --- a/.gitignore
> +++ b/.gitignore
> @@ -9,3 +9,4 @@ waf3-*
> .lock-waf*
> build
> VERSION*
> +*symbols.ini
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> new file mode 100644
> index 0000000..54933d5
> --- /dev/null
> +++ b/tester/rt/coverage.py
> @@ -0,0 +1,385 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS 'AS
> IS'
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +from rtemstoolkit import error
> +from rtemstoolkit import path
> +from rtemstoolkit import log
> +from rtemstoolkit import execute
> +from rtemstoolkit import macros
> +from datetime import datetime
> +from . import options
> +import shutil
> +import os
> +try:
> + import configparser
> +except:
> + import ConfigParser as configparser
> +class summary:
> + def __init__(self, p_summary_dir):
> + self.summary_file_path = path.join(p_summary_dir, 'summary.txt')
> + self.index_file_path = path.join(p_summary_dir, 'index.html')
> + self.bytes_analyzed = 0
> + self.bytes_not_executed = 0
> + self.percentage_executed = 0.0
> + self.percentage_not_executed = 100.0
> + self.ranges_uncovered = 0
> + self.branches_uncovered = 0
> + self.branches_total = 0
> + self.branches_always_taken = 0
> + self.branches_never_taken = 0
> + self.percentage_branches_covered = 0.0
> + self.is_failure = False
> + def parse(self):
> + if(not path.exists(self.summary_file_path)):
> + log.notice('summary file %s does not exist!' %
> + self.is_failure = True
> + return
> + with open(self.summary_file_path,'r') as summary_file:
> + self.bytes_analyzed = self._get_next_with_colon(summary_file)
> + self.bytes_not_executed = self._get_next_with_colon(
> summary_file)
> + self.percentage_executed = self._get_next_with_colon(
> summary_file)
> + self.percentage_not_executed = self._get_next_with_colon(
> summary_file)
> + self.ranges_uncovered = self._get_next_with_colon(
> summary_file)
> + self.branches_total = self._get_next_with_colon(summary_file)
> + self.branches_uncovered = self._get_next_with_colon(
> summary_file)
> + self.branches_always_taken = self._get_next_without_colon(
> summary_file)
> + self.branches_never_taken = self._get_next_without_colon(
> summary_file)
> + if len(self.branches_uncovered) > 0 and len(self.branches_total)
> > 0:
> + self.percentage_branches_covered = \
> + 1 - (float(self.branches_uncovered) /
> float(self.branches_total))
> + else:
> + return
> + def _get_next_with_colon(self, summary_file):
> + line = summary_file.readline()
> + if ':' in line:
> + return line.split(':')[1].strip()
> + else:
> + return ''
> + def _get_next_without_colon(self, summary_file):
> + return line.strip().split(' ')[0]
> +class report_gen_html:
> + def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
> + self.symbol_sets_list = ['score']
> + self.build_dir = build_dir
> + self.partial_reports_files = list(["index.html", "summary.txt"])
> + self.number_of_columns = 1
> + self.covoar_src_path = path.join(rtdir, 'covoar')
> + self.bsp = bsp
> + def _find_partial_reports(self):
> + partial_reports = {}
> + for symbol_set in self.symbol_sets_list:
> + set_summary = summary(path.join(self.build_dir,
> + self.bsp + "-coverage",
> + symbol_set))
> + set_summary.parse()
> + partial_reports[symbol_set] = set_summary
> + return partial_reports
> + def _prepare_head_section(self):
> + head_section = '''
> + <head>
> + <title>RTEMS coverage report</title>
> + <style type="text/css">
> + progress[value] {
> + -webkit-appearance: none;
> + appearance: none;
> + width: 150px;
> + height: 15px;
> + </style>
> + </head>'''
> + return head_section
> + def _prepare_index_content(self, partial_reports):
> + header = "<h1> RTEMS coverage analysis report </h1>"
> + header += "<h3>Coverage reports by symbols sets:</h3>"
> + table = "<table>"
> + table += self._header_row()
> + for symbol_set in partial_reports:
> + table += self._row(symbol_set, partial_reports[symbol_set])
> + table += "</table> </br>"
> + timestamp = "Analysis performed on " + datetime.now().ctime()
> + return "<body>\n" + header + table + timestamp + "\n</body>"
> + def _row(self, symbol_set, summary):
> + row = "<tr>"
> + row += "<td>" + symbol_set + "</td>"
> + if summary.is_failure:
> + row += ' <td colspan="' + str(self.number_of_columns-1) \
> + + '" style="background-color:red">FAILURE</td>'
> + else:
> + row += " <td>" + self._link(summary.index_file_path,"Index")
> + + "</td>"
> + row += " <td>" + self._link(summary.summary_file_path,"Summary")
> + + "</td>"
> + row += " <td>" + summary.bytes_analyzed + "</td>"
> + row += " <td>" + summary.bytes_not_executed + "</td>"
> + row += " <td>" + summary.ranges_uncovered + "</td>"
> + row += " <td>" + summary.percentage_executed + "%</td>"
> + row += " <td>" + summary.percentage_not_executed + "%</td>"
> + row += ' <td><progress value="' + summary.percentage_executed
> + + '" max="100"></progress></td>'
> + row += " <td>" + summary.branches_uncovered + "</td>"
> + row += " <td>" + summary.branches_total + "</td>"
> + row += " <td> {:.3%} </td>".format(summary.
> percentage_branches_covered)
> + row += ' <td><progress value="{:.3}"
> max="100"></progress></td>'.format(100*summary.percentage_
> branches_covered)
> + row += "</tr>\n"
> + return row
> + def _header_row(self):
> + row = "<tr>"
> + row += "<th> Symbols set name </th>"
> + row += "<th> Index file </th>"
> + row += "<th> Summary file </th>"
> + row += "<th> Bytes analyzed </th>"
> + row += "<th> Bytes not executed </th>"
> + row += "<th> Uncovered ranges </th>"
> + row += "<th> Percentage covered </th>"
> + row += "<th> Percentage uncovered </th>"
> + row += "<th> Instruction coverage </th>"
> + row += "<th> Branches uncovered </th>"
> + row += "<th> Branches total </th>"
> + row += "<th> Branches covered percentage </th>"
> + row += "<th> Branches coverage </th>"
> + row += "</tr>\n"
> + self.number_of_columns = row.count('<th>')
> + return row
> + def _link(self, address, text):
> + return '<a href="' + address + '">' + text + '</a>'
> + def _create_index_file(self, head_section, content):
> + with open(path.join(self.build_dir,
> + self.bsp + "-report.html"),'w') as f:
> + f.write(head_section)
> + f.write(content)
> + def generate(self):
> + partial_reports = self._find_partial_reports()
> + head_section = self._prepare_head_section()
> + index_content = self._prepare_index_content(partial_reports)
> + self._create_index_file(head_section,index_content)
> + def add_covoar_src_path(self):
> + table_js_path = path.join(self.covoar_src_path, 'table.js')
> + covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
> + symbol_set_dir = path.join(self.build_dir,
> + self.bsp + '-coverage', symbol_set)
> + html_files = os.listdir(symbol_set_dir)
> + for html_file in html_files:
> + html_file = path.join(symbol_set_dir, html_file)
> + if path.exists(html_file) and 'html' in html_file:
> + with open(html_file, 'r') as f:
> + file_data = f.read()
> + file_data = file_data.replace('table.js',
> table_js_path)
> + file_data = file_data.replace('covoar.css',
> + covoar_css_path)
> + with open(html_file, 'w') as f:
> + f.write(file_data)
> +class build_path_generator(object):
> + Generates the build path from the path to executables
> + def __init__(self, executables, target):
> + self.executables = executables
> + self.target = target
> + def run(self):
> + build_path = '/'
> + Path = self.executables[0].split('/')
> + for P in Path:
> + if P == self.target:
> + break;
> + else:
> + build_path = path.join(build_path, P)
> + return build_path
> +class symbol_parser(object):
> + Parse the symbol sets ini and create custom ini file for covoar
> + def __init__(self, symbol_config_path,
> + symbol_select_path, coverage_arg, build_dir):
> + self.symbol_select_file = symbol_select_path
> + self.symbol_file = symbol_config_path
> + self.symbol_sets = {}
> + self.cov_arg = coverage_arg
> + self.ssets = []
> + def parse(self):
> + config = configparser.ConfigParser()
> + try:
> + config.read(self.symbol_file)
> + if self.cov_arg:
> + self.ssets = self.cov_arg.split(',')
> + else:
> + self.ssets = config.get('symbol-sets', 'sets').split(',')
> + self.ssets = [ sset.encode('utf-8') for sset in
> self.ssets]
> + for sset in self.ssets:
> + lib = path.join(self.build_dir,
> + config.get('libraries', sset))
> + self.symbol_sets[sset] = lib.encode('utf-8')
> + except:
> + raise error.general('Symbol set parsing failed')
> + def _write_ini(self):
> + try:
> + sets = ', '.join(self.symbol_sets.keys())
> + config.add_section('symbol-sets')
> + config.set('symbol-sets', 'sets', sets)
> + for key in self.symbol_sets.keys():
> + config.add_section(key)
> + config.set(key, 'libraries', self.symbol_sets[key])
> + with open(self.symbol_select_file, 'w') as conf:
> + config.write(conf)
> + except:
> + raise error.general('write failed')
> + def run(self):
> + self.parse()
> + self._write_ini()
> +class covoar(object):
> + Covoar runner
> + def __init__(self, base_result_dir, config_dir, executables,
> explanations_txt):
> + self.base_result_dir = base_result_dir
> + self.config_dir = config_dir
> + self.executables = ' '.join(executables)
> + self.explanations_txt = explanations_txt
> + self.project_name = 'RTEMS-5'
> + def run(self, set_name, symbol_file):
> + covoar_result_dir = path.join(self.base_result_dir, set_name)
> + if (not path.exists(covoar_result_dir)):
> + path.mkdir(covoar_result_dir)
> + if (not path.exists(symbol_file)):
> + raise error.general('symbol set file: coverage %s was not
> created for covoar, skipping %s'% (symbol_file, set_name))
> + command = ('covoar -S ' + symbol_file
> + + ' -O ' + covoar_result_dir
> + + ' -E ' + self.explanations_txt
> + + ' -p ' + self.project_name + ' ' + self.executables)
> + log.notice('Running covoar for %s' % (set_name))
> + print( 'covoar results directory:\n' + covoar_result_dir )
> + executor = execute.execute(verbose = True, output =
> self.output_handler)
> + exit_code = executor.shell(command, cwd=os.getcwd())
> + if (exit_code[0] != 0):
> + raise error.general('covoar failure exit code: %d' %
> (exit_code[0]))
> + log.notice('Coverage run for %s finished successfully.' %
> (set_name))
> + log.notice('-----------------------------------------------')
> + def output_handler(self, text):
> + log.notice('%s' % (text))
> +class coverage_run(object):
> + Coverage analysis support for rtems-test
> + def __init__(self, p_macros, coverage_arg, executables):
> + Constructor
> + self.macros = p_macros
> + self.build_dir = self.macros['_cwd']
> + self.explanations_txt = self.macros.expand(self.
> macros['cov_explanations'])
> + self.test_dir = path.join(self.build_dir, self.macros['bsp'] +
> '-coverage')
> + if (not path.exists(self.test_dir)):
> + path.mkdir(self.test_dir)
> + self.rtdir = path.abspath(self.macros['_rtdir'])
> + self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
> + self.coverage_config_path = path.join(self.rtscripts, 'coverage')
> + self.symbol_config_path = path.join(self.coverage_config_path,
> + 'symbol-sets.ini')
> + self.symbol_select_path = path.join(self.coverage_config_path,
> + self.macros['bsp'] +
> '-symbols.ini')
> + self.symbol_sets = []
> + self.no_clean = int(self.macros['_no_clean'])
> + self.report_format = self.macros['cov_report_format']
> + self.coverage_arg = coverage_arg
> + self.target = self.macros['target']
> + def run(self):
> + try:
> + if self.executables is None:
> + raise error.general('no test executables provided.')
> + build_dir = build_path_generator(self.executables,
> self.target).run()
> + parser = symbol_parser(self.symbol_config_path,
> + self.symbol_select_path,
> + self.coverage_arg,
> + build_dir)
> + parser.run()
> + covoar_runner = covoar(self.test_dir, self.symbol_select_path,
> + self.executables,
> self.explanations_txt)
> + covoar_runner.run('score', self.symbol_select_path)
> + self._generate_reports();
> + self._summarize();
> + finally:
> + self._cleanup();
> + def _generate_reports(self):
> + log.notice('Generating reports')
> + if self.report_format == 'html':
> + report = report_gen_html(self.symbol_sets,
> + self.build_dir,
> + self.rtdir,
> + self.macros['bsp'])
> + report.generate()
> + report.add_covoar_src_path()
> + def _cleanup(self):
> + if not self.no_clean:
> + log.notice('***Cleaning tempfiles***')
> + for exe in self.executables:
> + trace_file = exe + '.cov'
> + if path.exists(trace_file):
> + os.remove(trace_file)
> + os.remove(self.symbol_select_path)
> + def _summarize(self):
> + log.notice('Coverage analysis finished. You can find results in
> %s' % (self.build_dir))
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index f4d9b5c..0e744cd 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
> from rtemstoolkit import reraise
> from rtemstoolkit import stacktraces
> from rtemstoolkit import version
> +from rtemstoolkit import check
> from . import bsps
> from . import config
> from . import console
> from . import report
> +from . import coverage
> class log_capture(object):
> def __init__(self):
> @@ -147,7 +149,7 @@ class test_run(object):
> def run(self):
> self.thread = threading.Thread(target = self.runner,
> - name = 'test[%s]' %
> path.basename(self.executable))
> + name = 'test[%s]' %
> self.thread.start()
> def is_alive(self):
> @@ -221,15 +223,16 @@ def run(command_path = None):
> opts = None
> default_exefilter = '*.exe'
> try:
> - optargs = { '--rtems-tools': 'The path to the RTEMS tools',
> - '--rtems-bsp': 'The RTEMS BSP to run the test on',
> - '--user-config': 'Path to your local user
> configuration INI file',
> - '--report-mode': 'Reporting modes, failures
> (default),all,none',
> - '--list-bsps': 'List the supported BSPs',
> - '--debug-trace': 'Debug trace based on specific
> flags',
> - '--filter': 'Glob that executables must match to
> run (default: ' +
> + optargs = { '--rtems-tools': 'The path to the RTEMS tools',
> + '--rtems-bsp': 'The RTEMS BSP to run the test
> on',
> + '--user-config': 'Path to your local user
> + '--report-mode': 'Reporting modes, failures
> + '--list-bsps': 'List the supported BSPs',
> + '--debug-trace': 'Debug trace based on specific
> flags',
> + '--filter': 'Glob that executables must match
> to run (default: ' +
> default_exefilter + ')',
> - '--stacktrace': 'Dump a stack trace on a user
> termination (^C)' }
> + '--stacktrace': 'Dump a stack trace on a user
> termination (^C)',
> + '--coverage': 'Perform coverage analysis of
> test executables.'}
> mailer.append_options(optargs)
> opts = options.load(sys.argv,
> optargs = optargs,
> @@ -257,6 +260,7 @@ def run(command_path = None):
> exe_filter = default_exefilter
> opts.log_info()
> log.output('Host: ' + host.label(mode = 'all'))
> + executables = find_executables(opts.params(), exe_filter)
> debug_trace = opts.find_arg('--debug-trace')
> if debug_trace:
> if len(debug_trace) != 1:
> @@ -279,6 +283,15 @@ def run(command_path = None):
> raise error.general('RTEMS BSP not provided or an invalid
> option')
> bsp = config.load(bsp[1], opts)
> bsp_config = opts.defaults.expand(opts.defaults['tester'])
> + coverage_enabled = opts.find_arg('--coverage')
> + if coverage_enabled:
> + if len(coverage_enabled) == 2:
> + coverage_runner = coverage.coverage_run(opts.defaults,
> + coverage_enabled[1],
> + executables)
> + else:
> + coverage_runner = coverage.coverage_run(opts.defaults, 0,
> + executables)
> report_mode = opts.find_arg('--report-mode')
> if report_mode:
> if report_mode[1] != 'failures' and \
> @@ -288,7 +301,6 @@ def run(command_path = None):
> report_mode = report_mode[1]
> else:
> report_mode = 'failures'
> - executables = find_executables(opts.params(), exe_filter)
> if len(executables) == 0:
> raise error.general('no executables supplied')
> start_time = datetime.datetime.now()
> @@ -365,6 +377,8 @@ def run(command_path = None):
> reports.failures(),
> 'Log', '===', ''] + output.get()
> mail.send(to_addr, subject, os.linesep.join(body))
> + coverage_runner.run()
> except error.general as gerr:
> print(gerr)
> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> index 6b5e7e6..2f89117 100644
> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> @@ -31,9 +31,10 @@
> # The Leon 3 QEMU BSP
> -[leon3-qemu]
> +[leon3-qemu-cov]
> bsp = leon3-qemu
> arch = sparc
> +target = sparc-rtems5
> tester = %{_rtscripts}/qemu.cfg
> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
> b/tester/rtems/testing/coverage/symbol-sets.ini
> index 0000000..a2ec7bc
> --- /dev/null
> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> @@ -0,0 +1,36 @@
> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
> met:
> notice,
> notice,
> documentation
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> THE
> PURPOSE
> BE
> THE
> +[symbol-sets]
> +sets = score,rtems
> +[libraries]
> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
> index bfcd2f5..52a3752 100644
> --- a/tester/rtems/testing/qemu.cfg
> +++ b/tester/rtems/testing/qemu.cfg
> @@ -51,8 +51,8 @@
> # Qemu common option patterns.
> -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
> -nographic
> -%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
> -nographic
> +%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
> +#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
> -nographic
> %define qemu_opts_no_net -net none
> 2.14.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180605/528142b9/attachment-0001.html>
