[PATCH v3] tester: Add script to generate html coverage report from covoar output
Joel Sherrill
joel at rtems.org
Wed Jun 6 00:52:35 UTC 2018
On Tue, Jun 5, 2018, 7:22 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 6 June 2018 at 03:57, Joel Sherrill <joel at rtems.org> wrote:
>> I think everything is pushed. Is there any patch outstanding?
>> Thank you.
> No outstanding patch, everything on my side is squashed into it. :)
So we can (finally) switch to the RTEMS.org repos to as the baseline?
On Mon, Jun 4, 2018 at 3:44 PM, Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> Add support in tester to run covoar and generate an html report to
>>> display
>>> the summary of the coverage reports generated from covoar.
>>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> .gitignore | 1 +
>>> tester/rt/coverage.py | 385
>>> tester/rt/test.py | 34 ++-
>>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>>> tester/rtems/testing/qemu.cfg | 4 +-
>>> 6 files changed, 450 insertions(+), 13 deletions(-)
>>> create mode 100644 tester/rt/coverage.py
>>> create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>> diff --git a/.gitignore b/.gitignore
>>> index 6ab3709..93cb5d2 100644
>>> --- a/.gitignore
>>> +++ b/.gitignore
>>> @@ -9,3 +9,4 @@ waf3-*
>>> .lock-waf*
>>> build
>>> VERSION*
>>> +*symbols.ini
>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>> new file mode 100644
>>> index 0000000..54933d5
>>> --- /dev/null
>>> +++ b/tester/rt/coverage.py
>>> @@ -0,0 +1,385 @@
>>> +# RTEMS Tools Project (http://www.rtems.org/)
>>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>>> +# All rights reserved.
>>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>> +# Redistribution and use in source and binary forms, with or without
>>> +# modification, are permitted provided that the following conditions
>>> are met:
>>> +# 1. Redistributions of source code must retain the above copyright
>>> notice,
>>> +# this list of conditions and the following disclaimer.
>>> +# 2. Redistributions in binary form must reproduce the above copyright
>>> notice,
>>> +# this list of conditions and the following disclaimer in the
>>> documentation
>>> +# and/or other materials provided with the distribution.
>>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>> 'AS IS'
>>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>>> THE
>>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> PURPOSE
>>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>> CONTRIBUTORS BE
>>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> BUSINESS
>>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>>> IN
>>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> OTHERWISE)
>>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>> OF THE
>>> +# POSSIBILITY OF SUCH DAMAGE.
>>> +from rtemstoolkit import error
>>> +from rtemstoolkit import path
>>> +from rtemstoolkit import log
>>> +from rtemstoolkit import execute
>>> +from rtemstoolkit import macros
>>> +from datetime import datetime
>>> +from . import options
>>> +import shutil
>>> +import os
>>> +try:
>>> + import configparser
>>> +except:
>>> + import ConfigParser as configparser
>>> +class summary:
>>> + def __init__(self, p_summary_dir):
>>> + self.summary_file_path = path.join(p_summary_dir, 'summary.txt')
>>> + self.index_file_path = path.join(p_summary_dir, 'index.html')
>>> + self.bytes_analyzed = 0
>>> + self.bytes_not_executed = 0
>>> + self.percentage_executed = 0.0
>>> + self.percentage_not_executed = 100.0
>>> + self.ranges_uncovered = 0
>>> + self.branches_uncovered = 0
>>> + self.branches_total = 0
>>> + self.branches_always_taken = 0
>>> + self.branches_never_taken = 0
>>> + self.percentage_branches_covered = 0.0
>>> + self.is_failure = False
>>> + def parse(self):
>>> + if(not path.exists(self.summary_file_path)):
>>> + log.notice('summary file %s does not exist!' %
>>> + self.is_failure = True
>>> + return
>>> + with open(self.summary_file_path,'r') as summary_file:
>>> + self.bytes_analyzed = self._get_next_with_colon(summary_file)
>>> + self.branches_total = self._get_next_with_colon(summary_file)
>>> self._get_next_without_colon(summary_file)
>>> + if len(self.branches_uncovered) > 0 and
>>> len(self.branches_total) > 0:
>>> + self.percentage_branches_covered = \
>>> + 1 - (float(self.branches_uncovered) /
>>> float(self.branches_total))
>>> + else:
>>> + return
>>> + def _get_next_with_colon(self, summary_file):
>>> + line = summary_file.readline()
>>> + if ':' in line:
>>> + return line.split(':')[1].strip()
>>> + else:
>>> + return ''
>>> + def _get_next_without_colon(self, summary_file):
>>> + return line.strip().split(' ')[0]
>>> +class report_gen_html:
>>> + def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
>>> + self.symbol_sets_list = ['score']
>>> + self.build_dir = build_dir
>>> + self.partial_reports_files = list(["index.html", "summary.txt"])
>>> + self.number_of_columns = 1
>>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>>> + self.bsp = bsp
>>> + def _find_partial_reports(self):
>>> + partial_reports = {}
>>> + for symbol_set in self.symbol_sets_list:
>>> + set_summary = summary(path.join(self.build_dir,
>>> + self.bsp + "-coverage",
>>> + symbol_set))
>>> + set_summary.parse()
>>> + partial_reports[symbol_set] = set_summary
>>> + return partial_reports
>>> + def _prepare_head_section(self):
>>> + head_section = '''
>>> + <head>
>>> + <title>RTEMS coverage report</title>
>>> + <style type="text/css">
>>> + progress[value] {
>>> + -webkit-appearance: none;
>>> + appearance: none;
>>> + width: 150px;
>>> + height: 15px;
>>> + </style>
>>> + </head>'''
>>> + return head_section
>>> + def _prepare_index_content(self, partial_reports):
>>> + header = "<h1> RTEMS coverage analysis report </h1>"
>>> + header += "<h3>Coverage reports by symbols sets:</h3>"
>>> + table = "<table>"
>>> + table += self._header_row()
>>> + for symbol_set in partial_reports:
>>> + table += self._row(symbol_set, partial_reports[symbol_set])
>>> + table += "</table> </br>"
>>> + timestamp = "Analysis performed on " + datetime.now().ctime()
>>> + return "<body>\n" + header + table + timestamp + "\n</body>"
>>> + def _row(self, symbol_set, summary):
>>> + row = "<tr>"
>>> + row += "<td>" + symbol_set + "</td>"
>>> + if summary.is_failure:
>>> + row += ' <td colspan="' + str(self.number_of_columns-1) \
>>> + + '" style="background-color:red">FAILURE</td>'
>>> + else:
>>> + row += " <td>" +
>>> self._link(summary.index_file_path,"Index") \
>>> + + "</td>"
>>> + row += " <td>" +
>>> self._link(summary.summary_file_path,"Summary") \
>>> + + "</td>"
>>> + row += " <td>" + summary.bytes_analyzed + "</td>"
>>> + row += " <td>" + summary.bytes_not_executed + "</td>"
>>> + row += " <td>" + summary.ranges_uncovered + "</td>"
>>> + row += " <td>" + summary.percentage_executed + "%</td>"
>>> + row += " <td>" + summary.percentage_not_executed + "%</td>"
>>> + row += ' <td><progress value="' +
>>> summary.percentage_executed \
>>> + + '" max="100"></progress></td>'
>>> + row += " <td>" + summary.branches_uncovered + "</td>"
>>> + row += " <td>" + summary.branches_total + "</td>"
>>> + row += " <td> {:.3%}
>>> </td>".format(summary.percentage_branches_covered)
>>> + row += ' <td><progress value="{:.3}"
>>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>> + row += "</tr>\n"
>>> + return row
>>> + def _header_row(self):
>>> + row = "<tr>"
>>> + row += "<th> Symbols set name </th>"
>>> + row += "<th> Index file </th>"
>>> + row += "<th> Summary file </th>"
>>> + row += "<th> Bytes analyzed </th>"
>>> + row += "<th> Bytes not executed </th>"
>>> + row += "<th> Uncovered ranges </th>"
>>> + row += "<th> Percentage covered </th>"
>>> + row += "<th> Percentage uncovered </th>"
>>> + row += "<th> Instruction coverage </th>"
>>> + row += "<th> Branches uncovered </th>"
>>> + row += "<th> Branches total </th>"
>>> + row += "<th> Branches covered percentage </th>"
>>> + row += "<th> Branches coverage </th>"
>>> + row += "</tr>\n"
>>> + self.number_of_columns = row.count('<th>')
>>> + return row
>>> + def _link(self, address, text):
>>> + return '<a href="' + address + '">' + text + '</a>'
>>> + def _create_index_file(self, head_section, content):
>>> + with open(path.join(self.build_dir,
>>> + self.bsp + "-report.html"),'w') as f:
>>> + f.write(head_section)
>>> + f.write(content)
>>> + def generate(self):
>>> + partial_reports = self._find_partial_reports()
>>> + head_section = self._prepare_head_section()
>>> + index_content = self._prepare_index_content(partial_reports)
>>> + self._create_index_file(head_section,index_content)
>>> + def add_covoar_src_path(self):
>>> + table_js_path = path.join(self.covoar_src_path, 'table.js')
>>> + covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
>>> + symbol_set_dir = path.join(self.build_dir,
>>> + self.bsp + '-coverage',
>>> symbol_set)
>>> + html_files = os.listdir(symbol_set_dir)
>>> + for html_file in html_files:
>>> + html_file = path.join(symbol_set_dir, html_file)
>>> + if path.exists(html_file) and 'html' in html_file:
>>> + with open(html_file, 'r') as f:
>>> + file_data = f.read()
>>> + file_data = file_data.replace('table.js',
>>> table_js_path)
>>> + file_data = file_data.replace('covoar.css',
>>> + covoar_css_path)
>>> + with open(html_file, 'w') as f:
>>> + f.write(file_data)
>>> +class build_path_generator(object):
>>> + Generates the build path from the path to executables
>>> + def __init__(self, executables, target):
>>> + self.executables = executables
>>> + self.target = target
>>> + def run(self):
>>> + build_path = '/'
>>> + Path = self.executables[0].split('/')
>>> + for P in Path:
>>> + if P == self.target:
>>> + break;
>>> + else:
>>> + build_path = path.join(build_path, P)
>>> + return build_path
>>> +class symbol_parser(object):
>>> + Parse the symbol sets ini and create custom ini file for covoar
>>> + def __init__(self, symbol_config_path,
>>> + symbol_select_path, coverage_arg, build_dir):
>>> + self.symbol_select_file = symbol_select_path
>>> + self.symbol_file = symbol_config_path
>>> + self.symbol_sets = {}
>>> + self.cov_arg = coverage_arg
>>> + self.ssets = []
>>> + def parse(self):
>>> + config = configparser.ConfigParser()
>>> + try:
>>> + config.read(self.symbol_file)
>>> + if self.cov_arg:
>>> + self.ssets = self.cov_arg.split(',')
>>> + else:
>>> + self.ssets = config.get('symbol-sets',
>>> 'sets').split(',')
>>> + self.ssets = [ sset.encode('utf-8') for sset in
>>> self.ssets]
>>> + for sset in self.ssets:
>>> + lib = path.join(self.build_dir,
>>> + config.get('libraries', sset))
>>> + self.symbol_sets[sset] = lib.encode('utf-8')
>>> + except:
>>> + raise error.general('Symbol set parsing failed')
>>> + def _write_ini(self):
>>> + try:
>>> + sets = ', '.join(self.symbol_sets.keys())
>>> + config.add_section('symbol-sets')
>>> + config.set('symbol-sets', 'sets', sets)
>>> + for key in self.symbol_sets.keys():
>>> + config.add_section(key)
>>> + config.set(key, 'libraries', self.symbol_sets[key])
>>> + with open(self.symbol_select_file, 'w') as conf:
>>> + config.write(conf)
>>> + except:
>>> + raise error.general('write failed')
>>> + def run(self):
>>> + self.parse()
>>> + self._write_ini()
>>> +class covoar(object):
>>> + Covoar runner
>>> + def __init__(self, base_result_dir, config_dir, executables,
>>> explanations_txt):
>>> + self.base_result_dir = base_result_dir
>>> + self.config_dir = config_dir
>>> + self.executables = ' '.join(executables)
>>> + self.explanations_txt = explanations_txt
>>> + self.project_name = 'RTEMS-5'
>>> + def run(self, set_name, symbol_file):
>>> + covoar_result_dir = path.join(self.base_result_dir, set_name)
>>> + if (not path.exists(covoar_result_dir)):
>>> + path.mkdir(covoar_result_dir)
>>> + if (not path.exists(symbol_file)):
>>> + raise error.general('symbol set file: coverage %s was not
>>> created for covoar, skipping %s'% (symbol_file, set_name))
>>> + command = ('covoar -S ' + symbol_file
>>> + + ' -O ' + covoar_result_dir
>>> + + ' -E ' + self.explanations_txt
>>> + + ' -p ' + self.project_name + ' ' + self.executables)
>>> + log.notice('Running covoar for %s' % (set_name))
>>> + print( 'covoar results directory:\n' + covoar_result_dir )
>>> + executor = execute.execute(verbose = True, output =
>>> self.output_handler)
>>> + exit_code = executor.shell(command, cwd=os.getcwd())
>>> + if (exit_code[0] != 0):
>>> + raise error.general('covoar failure exit code: %d' %
>>> (exit_code[0]))
>>> + log.notice('Coverage run for %s finished successfully.' %
>>> (set_name))
>>> + log.notice('-----------------------------------------------')
>>> + def output_handler(self, text):
>>> + log.notice('%s' % (text))
>>> +class coverage_run(object):
>>> + Coverage analysis support for rtems-test
>>> + def __init__(self, p_macros, coverage_arg, executables):
>>> + Constructor
>>> + self.macros = p_macros
>>> + self.build_dir = self.macros['_cwd']
>>> self.macros.expand(self.macros['cov_explanations'])
>>> + self.test_dir = path.join(self.build_dir, self.macros['bsp'] +
>>> '-coverage')
>>> + if (not path.exists(self.test_dir)):
>>> + path.mkdir(self.test_dir)
>>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>>> + self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
>>> + self.coverage_config_path = path.join(self.rtscripts,
>>> 'coverage')
>>> + self.symbol_config_path = path.join(self.coverage_config_path,
>>> + 'symbol-sets.ini')
>>> + self.symbol_select_path = path.join(self.coverage_config_path,
>>> + self.macros['bsp'] +
>>> '-symbols.ini')
>>> + self.symbol_sets = []
>>> + self.no_clean = int(self.macros['_no_clean'])
>>> + self.report_format = self.macros['cov_report_format']
>>> + self.coverage_arg = coverage_arg
>>> + self.target = self.macros['target']
>>> + def run(self):
>>> + try:
>>> + if self.executables is None:
>>> + raise error.general('no test executables provided.')
>>> + build_dir = build_path_generator(self.executables,
>>> self.target).run()
>>> + parser = symbol_parser(self.symbol_config_path,
>>> + self.symbol_select_path,
>>> + self.coverage_arg,
>>> + build_dir)
>>> + parser.run()
>>> + covoar_runner = covoar(self.test_dir,
>>> + self.executables,
>>> self.explanations_txt)
>>> + covoar_runner.run('score', self.symbol_select_path)
>>> + self._generate_reports();
>>> + self._summarize();
>>> + finally:
>>> + self._cleanup();
>>> + def _generate_reports(self):
>>> + log.notice('Generating reports')
>>> + if self.report_format == 'html':
>>> + report = report_gen_html(self.symbol_sets,
>>> + self.build_dir,
>>> + self.rtdir,
>>> + self.macros['bsp'])
>>> + report.generate()
>>> + report.add_covoar_src_path()
>>> + def _cleanup(self):
>>> + if not self.no_clean:
>>> + log.notice('***Cleaning tempfiles***')
>>> + for exe in self.executables:
>>> + trace_file = exe + '.cov'
>>> + if path.exists(trace_file):
>>> + os.remove(trace_file)
>>> + os.remove(self.symbol_select_path)
>>> + def _summarize(self):
>>> + log.notice('Coverage analysis finished. You can find results in
>>> %s' % (self.build_dir))
>>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>> index f4d9b5c..0e744cd 100644
>>> --- a/tester/rt/test.py
>>> +++ b/tester/rt/test.py
>>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>> from rtemstoolkit import reraise
>>> from rtemstoolkit import stacktraces
>>> from rtemstoolkit import version
>>> +from rtemstoolkit import check
>>> from . import bsps
>>> from . import config
>>> from . import console
>>> from . import report
>>> +from . import coverage
>>> class log_capture(object):
>>> def __init__(self):
>>> @@ -147,7 +149,7 @@ class test_run(object):
>>> def run(self):
>>> self.thread = threading.Thread(target = self.runner,
>>> - name = 'test[%s]' %
>>> path.basename(self.executable))
>>> + name = 'test[%s]' %
>>> self.thread.start()
>>> def is_alive(self):
>>> @@ -221,15 +223,16 @@ def run(command_path = None):
>>> opts = None
>>> default_exefilter = '*.exe'
>>> try:
>>> - optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>> - '--rtems-bsp': 'The RTEMS BSP to run the test on',
>>> - '--user-config': 'Path to your local user
>>> configuration INI file',
>>> - '--report-mode': 'Reporting modes, failures
>>> (default),all,none',
>>> - '--list-bsps': 'List the supported BSPs',
>>> - '--debug-trace': 'Debug trace based on specific
>>> flags',
>>> - '--filter': 'Glob that executables must match
>>> to run (default: ' +
>>> + optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>> + '--rtems-bsp': 'The RTEMS BSP to run the test
>>> on',
>>> + '--user-config': 'Path to your local user
>>> + '--report-mode': 'Reporting modes, failures
>>> + '--list-bsps': 'List the supported BSPs',
>>> + '--debug-trace': 'Debug trace based on specific
>>> flags',
>>> + '--filter': 'Glob that executables must
>>> match to run (default: ' +
>>> default_exefilter + ')',
>>> - '--stacktrace': 'Dump a stack trace on a user
>>> termination (^C)' }
>>> + '--stacktrace': 'Dump a stack trace on a user
>>> termination (^C)',
>>> + '--coverage': 'Perform coverage analysis of
>>> test executables.'}
>>> mailer.append_options(optargs)
>>> opts = options.load(sys.argv,
>>> optargs = optargs,
>>> @@ -257,6 +260,7 @@ def run(command_path = None):
>>> exe_filter = default_exefilter
>>> opts.log_info()
>>> log.output('Host: ' + host.label(mode = 'all'))
>>> + executables = find_executables(opts.params(), exe_filter)
>>> debug_trace = opts.find_arg('--debug-trace')
>>> if debug_trace:
>>> if len(debug_trace) != 1:
>>> @@ -279,6 +283,15 @@ def run(command_path = None):
>>> raise error.general('RTEMS BSP not provided or an invalid
>>> option')
>>> bsp = config.load(bsp[1], opts)
>>> bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>> + coverage_enabled = opts.find_arg('--coverage')
>>> + if coverage_enabled:
>>> + if len(coverage_enabled) == 2:
>>> + coverage_runner = coverage.coverage_run(opts.defaults,
>>> + coverage_enabled[1],
>>> + executables)
>>> + else:
>>> 0,
>>> + executables)
>>> report_mode = opts.find_arg('--report-mode')
>>> if report_mode:
>>> if report_mode[1] != 'failures' and \
>>> @@ -288,7 +301,6 @@ def run(command_path = None):
>>> report_mode = report_mode[1]
>>> else:
>>> report_mode = 'failures'
>>> - executables = find_executables(opts.params(), exe_filter)
>>> if len(executables) == 0:
>>> raise error.general('no executables supplied')
>>> start_time = datetime.datetime.now()
>>> @@ -365,6 +377,8 @@ def run(command_path = None):
>>> reports.failures(),
>>> 'Log', '===', ''] + output.get()
>>> mail.send(to_addr, subject, os.linesep.join(body))
>>> + coverage_runner.run()
>>> except error.general as gerr:
>>> print(gerr)
>>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> index 6b5e7e6..2f89117 100644
>>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> @@ -31,9 +31,10 @@
>>> # The Leon 3 QEMU BSP
>>> -[leon3-qemu]
>>> +[leon3-qemu-cov]
>>> bsp = leon3-qemu
>>> arch = sparc
>>> +target = sparc-rtems5
>>> tester = %{_rtscripts}/qemu.cfg
>>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>> index 0000000..a2ec7bc
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>> @@ -0,0 +1,36 @@
>>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>> are met:
>>> notice,
>>> notice,
>>> documentation
>>> "AS IS"
>>> THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +[symbol-sets]
>>> +sets = score,rtems
>>> +[libraries]
>>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>> qemu.cfg
>>> index bfcd2f5..52a3752 100644
>>> --- a/tester/rtems/testing/qemu.cfg
>>> +++ b/tester/rtems/testing/qemu.cfg
>>> @@ -51,8 +51,8 @@
>>> # Qemu common option patterns.
>>> -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> -nographic
>>> -%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> -nographic
>>> +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> -nographic
>>> +#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> -nographic
>>> %define qemu_opts_no_net -net none
>>> 2.14.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180605/1d17cf74/attachment-0001.html>
