[PATCH] Adding tracing documentation in user manual
Wed Jun 6 07:08:37 UTC 2018
On 05/06/18 22:39, Vidushi Vashishth wrote:
> I am just sending a revised version with incorporations of your
> suggestions. I will create a fresh version 2 patch after everyone has
> reviewed.
If you send revised version, then please send them as a separate patch
with a new version. You can mention in the commit message what you
changed in a particular version of the patch. For example:
https://lists.gnu.org/archive/html/qemu-devel/2018-05/msg06269.html
There should be a section which tells me which tools I have to install.
The new files need a proper copyright message mentioning the copyright
owner.
In contrast to the other documents the stuff in user uses subdirectories
and separate files at a low section level. Is this practical?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
