[PATCH] Adding tracing documentation in user manual
Vidushi Vashishth
reachvidu at gmail.com
Wed Jun 6 09:24:33 UTC 2018
I am just sending a revised version with incorporations of your
>> suggestions. I will create a fresh version 2 patch after everyone has
>> reviewed.
> If you send revised version, then please send them as a separate patch
> with a new version. You can mention in the commit message what you changed
> in a particular version of the patch. For example:
> https://lists.gnu.org/archive/html/qemu-devel/2018-05/msg06269.html
> There should be a section which tells me which tools I have to install.
> The new files need a proper copyright message mentioning the copyright
> owner.
Okay I will make these changes.
In contrast to the other documents the stuff in user uses subdirectories
> and separate files at a low section level. Is this practical?
I didn't quite understand this.
Also what are you thoughts on my idea of accomplishing function tracing
using CTF? Do you think its a viable approach? This is written in the
function tracing use case below:
+Requirements
+The current tracing framework provides this functionality with
:ref:`tracebuffering`. The output is
+provided in the form of printing on console or saving the buffer in the
form of a bin file. In order to
+develop this use case using CTF we need to be able to convert either the
bin file or console output to CTF.
+The saved bin file must also first be transported to the host from the
target for this purpose. On the other
+hand console output could be written to a text file which can then be
converted to CTF.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180606/128c0824/attachment.html>
