[PATCH 1/4] Build only the Binutils
Sebastian Huber
Wed Jun 6 09:45:32 UTC 2018
The Binutils and GDB share a repository. In order to build the Binutils
from a repository snapshot some components must be disabled.
source-builder/config/binutils-2-1.cfg | 1 +
1 file changed, 1 insertion(+)
diff --git a/source-builder/config/binutils-2-1.cfg b/source-builder/config/binutils-2-1.cfg
index 0b4101d..5eefd0f 100644
--- a/source-builder/config/binutils-2-1.cfg
+++ b/source-builder/config/binutils-2-1.cfg
@@ -69,6 +69,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
--build=%{_build} --host=%{_host} \
--target=%{_target} \
--verbose --disable-nls \
+ --disable-gdb --disable-libdecnumber --disable-readline --disable-sim \
%{?with_deterministic_archives:--enable-deterministic-archives} \
%{?with_64_bit_bfd:--enable-64-bit-bfd} \
%{?with_gold:--enable-gold=yes} \
2.13.7
