[PATCH 3/4] 5: Update RISC-V Binutils
Wed Jun 6 09:45:34 UTC 2018
This includes the following bug fix:
https://sourceware.org/bugzilla/show_bug.cgi?id=23244
 rtems/config/5/rtems-riscv32.bset                  |  2 +-
 rtems/config/5/rtems-riscv64.bset                  |  2 +-
 ...ls-773ff7907c05313aebbcd5e8319e5b869ac4f792.cfg | 29 ++++++++++++++++++++++
 3 files changed, 31 insertions(+), 2 deletions(-)
 create mode 100644 rtems/config/tools/rtems-binutils-773ff7907c05313aebbcd5e8319e5b869ac4f792.cfg
diff --git a/rtems/config/5/rtems-riscv32.bset b/rtems/config/5/rtems-riscv32.bset
index c4e99f2..f19adcd 100644
--- a/rtems/config/5/rtems-riscv32.bset
+++ b/rtems/config/5/rtems-riscv32.bset
@@ -10,7 +10,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-binutils-2.30
+tools/rtems-binutils-773ff7907c05313aebbcd5e8319e5b869ac4f792
 tools/rtems-gcc-7.3.0-newlib-3.0.0
 tools/rtems-tools-5-1
 tools/rtems-kernel-5
diff --git a/rtems/config/5/rtems-riscv64.bset b/rtems/config/5/rtems-riscv64.bset
index c2fb727..feb693e 100644
--- a/rtems/config/5/rtems-riscv64.bset
+++ b/rtems/config/5/rtems-riscv64.bset
@@ -10,7 +10,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
diff --git a/rtems/config/tools/rtems-binutils-773ff7907c05313aebbcd5e8319e5b869ac4f792.cfg b/rtems/config/tools/rtems-binutils-773ff7907c05313aebbcd5e8319e5b869ac4f792.cfg
new file mode 100644
index 0000000..cc045a3
--- /dev/null
+++ b/rtems/config/tools/rtems-binutils-773ff7907c05313aebbcd5e8319e5b869ac4f792.cfg
@@ -0,0 +1,29 @@
+# Binutils
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%define binutils_version 773ff7907c05313aebbcd5e8319e5b869ac4f792
+%define binutils_external 1
+%define binutils_expand_name binutils-gdb-%{binutils_version}
+%source set binutils --rsb-file=%{binutils_expand_name}.tar.gz https://github.com/bminor/binutils-gdb/archive/%{binutils_version}.tar.gz
+%hash sha512 %{binutils_expand_name}.tar.gz 64ae16e9da89f0e150c1d95cf0aa2c1ff5df4fe9ecefcf9ed702f2fffe66fb194ae50642b13f4e3724db3dfd598710b1f1877ed39d06cb6c5903dad9ddcddcc3
+# Enable deterministic archives by default. This will be the default
+# there all tools using this binutils will create deterministic
+# archives.
+%define with_deterministic_archives 1
+# Enable 64-bit BFD support
+%define with_64_bit_bfd 1
+# The binutils build instructions. We use 2.xx Release 1.
+%include %{_configdir}/binutils-2-1.cfg
2.13.7
