configure/make with multiple jobs error?
Thu Jun 7 03:12:12 UTC 2018
On 07/06/2018 03:55, Gedare Bloom wrote:
> On Tue, Jun 5, 2018 at 9:02 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 31/5/18 2:56 am, Gedare Bloom wrote:
>> Is this still only with a concurrent build?
> I think this was without concurrent build.
Then I suspect this is the space in the path.
>>> make[4]: Entering directory '/media/gedare/Seagate Expansion
>>> Drive/work/rtems/builds/b-erc32-5/sparc-rtems5/c/erc32/lib/libbsp'
>> I wonder if some of the internal shell script processing we have is safe with a
>> space in a path?
> It is possible. I've had problems before with spaces in the path using
> RSB and rtems-test tools. I haven't had trouble before with
> configure/make though.
The base autoconf and automake should be clean but we have a range of scripts
and m4 fragments that may not be.
