[PATCH 3/6] shgen: Import from RTEMS
Thu Jun 7 05:39:04 UTC 2018
Corresponding RTEMS commit is 75933d5d25cd50f80162b7a0d2f66a5534e1763f.
Update #3443.
 misc/shgen/AUTHORS |   3 +
 misc/shgen/COPYING | 340 +++++++++++++++++++++++++++++++++++++++++++++++++++++
 misc/shgen/TODO    |  13 ++
 misc/shgen/sci.c   | 177 ++++++++++++++++++++++++++++
 misc/shgen/sci.h   |  11 ++
 misc/shgen/shgen.c | 114 ++++++++++++++++++
 misc/wscript       |   9 ++
 7 files changed, 667 insertions(+)
 create mode 100644 misc/shgen/AUTHORS
 create mode 100644 misc/shgen/COPYING
 create mode 100644 misc/shgen/TODO
 create mode 100644 misc/shgen/sci.c
 create mode 100644 misc/shgen/sci.h
 create mode 100644 misc/shgen/shgen.c
diff --git a/misc/shgen/AUTHORS b/misc/shgen/AUTHORS
new file mode 100644
index 0000000..225c2fa
--- /dev/null
+++ b/misc/shgen/AUTHORS
@@ -0,0 +1,3 @@
+Ralf Corsepius (corsepiu at faw.uni-ulm.de)
+	* Initial implementation
+	* generator for sci bitrate table
diff --git a/misc/shgen/COPYING b/misc/shgen/COPYING
index 0000000..8cc2ef7
--- /dev/null
+++ b/misc/shgen/COPYING
@@ -0,0 +1,340 @@
+		    GNU GENERAL PUBLIC LICENSE
+		       Version 2, June 1991
+ Copyright (C) 1989, 1991 Free Software Foundation, Inc.
+ 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
+ Everyone is permitted to copy and distribute verbatim copies
+ of this license document, but changing it is not allowed.
+			    Preamble
+  The licenses for most software are designed to take away your
+freedom to share and change it.  By contrast, the GNU General Public
+License is intended to guarantee your freedom to share and change free
+software--to make sure the software is free for all its users.  This
+General Public License applies to most of the Free Software
+Foundation's software and to any other program whose authors commit to
+using it.  (Some other Free Software Foundation software is covered by
+the GNU Library General Public License instead.)  You can apply it to
+your programs, too.
+  When we speak of free software, we are referring to freedom, not
+price.  Our General Public Licenses are designed to make sure that you
+have the freedom to distribute copies of free software (and charge for
+this service if you wish), that you receive source code or can get it
+if you want it, that you can change the software or use pieces of it
+in new free programs; and that you know you can do these things.
+  To protect your rights, we need to make restrictions that forbid
+anyone to deny you these rights or to ask you to surrender the rights.
+These restrictions translate to certain responsibilities for you if you
+distribute copies of the software, or if you modify it.
+  For example, if you distribute copies of such a program, whether
+gratis or for a fee, you must give the recipients all the rights that
+you have.  You must make sure that they, too, receive or can get the
+source code.  And you must show them these terms so they know their
+rights.
+  We protect your rights with two steps: (1) copyright the software, and
+(2) offer you this license which gives you legal permission to copy,
+distribute and/or modify the software.
+  Also, for each author's protection and ours, we want to make certain
+that everyone understands that there is no warranty for this free
+software.  If the software is modified by someone else and passed on, we
+want its recipients to know that what they have is not the original, so
+that any problems introduced by others will not reflect on the original
+authors' reputations.
+  Finally, any free program is threatened constantly by software
+patents.  We wish to avoid the danger that redistributors of a free
+program will individually obtain patent licenses, in effect making the
+program proprietary.  To prevent this, we have made it clear that any
+patent must be licensed for everyone's free use or not licensed at all.
+  The precise terms and conditions for copying, distribution and
+modification follow.
+   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
+  0. This License applies to any program or other work which contains
+a notice placed by the copyright holder saying it may be distributed
+under the terms of this General Public License.  The "Program", below,
+refers to any such program or work, and a "work based on the Program"
+means either the Program or any derivative work under copyright law:
+that is to say, a work containing the Program or a portion of it,
+either verbatim or with modifications and/or translated into another
+language.  (Hereinafter, translation is included without limitation in
+the term "modification".)  Each licensee is addressed as "you".
+Activities other than copying, distribution and modification are not
+covered by this License; they are outside its scope.  The act of
+running the Program is not restricted, and the output from the Program
+is covered only if its contents constitute a work based on the
+Program (independent of having been made by running the Program).
+Whether that is true depends on what the Program does.
+  1. You may copy and distribute verbatim copies of the Program's
+source code as you receive it, in any medium, provided that you
+conspicuously and appropriately publish on each copy an appropriate
+copyright notice and disclaimer of warranty; keep intact all the
+notices that refer to this License and to the absence of any warranty;
+and give any other recipients of the Program a copy of this License
+along with the Program.
+You may charge a fee for the physical act of transferring a copy, and
+you may at your option offer warranty protection in exchange for a fee.
+  2. You may modify your copy or copies of the Program or any portion
+of it, thus forming a work based on the Program, and copy and
+distribute such modifications or work under the terms of Section 1
+above, provided that you also meet all of these conditions:
+    a) You must cause the modified files to carry prominent notices
+    stating that you changed the files and the date of any change.
+    b) You must cause any work that you distribute or publish, that in
+    whole or in part contains or is derived from the Program or any
+    part thereof, to be licensed as a whole at no charge to all third
+    parties under the terms of this License.
+    c) If the modified program normally reads commands interactively
+    when run, you must cause it, when started running for such
+    interactive use in the most ordinary way, to print or display an
+    announcement including an appropriate copyright notice and a
+    notice that there is no warranty (or else, saying that you provide
+    a warranty) and that users may redistribute the program under
+    these conditions, and telling the user how to view a copy of this
+    License.  (Exception: if the Program itself is interactive but
+    does not normally print such an announcement, your work based on
+    the Program is not required to print an announcement.)
+These requirements apply to the modified work as a whole.  If
+identifiable sections of that work are not derived from the Program,
+and can be reasonably considered independent and separate works in
+themselves, then this License, and its terms, do not apply to those
+sections when you distribute them as separate works.  But when you
+distribute the same sections as part of a whole which is a work based
+on the Program, the distribution of the whole must be on the terms of
+this License, whose permissions for other licensees extend to the
+entire whole, and thus to each and every part regardless of who wrote it.
+Thus, it is not the intent of this section to claim rights or contest
+your rights to work written entirely by you; rather, the intent is to
+exercise the right to control the distribution of derivative or
+collective works based on the Program.
+In addition, mere aggregation of another work not based on the Program
+with the Program (or with a work based on the Program) on a volume of
+a storage or distribution medium does not bring the other work under
+the scope of this License.
+  3. You may copy and distribute the Program (or a work based on it,
+under Section 2) in object code or executable form under the terms of
+Sections 1 and 2 above provided that you also do one of the following:
+    a) Accompany it with the complete corresponding machine-readable
+    source code, which must be distributed under the terms of Sections
+    1 and 2 above on a medium customarily used for software interchange; or,
+    b) Accompany it with a written offer, valid for at least three
+    years, to give any third party, for a charge no more than your
+    cost of physically performing source distribution, a complete
+    machine-readable copy of the corresponding source code, to be
+    distributed under the terms of Sections 1 and 2 above on a medium
+    customarily used for software interchange; or,
+    c) Accompany it with the information you received as to the offer
+    to distribute corresponding source code.  (This alternative is
+    allowed only for noncommercial distribution and only if you
+    received the program in object code or executable form with such
+    an offer, in accord with Subsection b above.)
+The source code for a work means the preferred form of the work for
+making modifications to it.  For an executable work, complete source
+code means all the source code for all modules it contains, plus any
+associated interface definition files, plus the scripts used to
+control compilation and installation of the executable.  However, as a
+special exception, the source code distributed need not include
+anything that is normally distributed (in either source or binary
+form) with the major components (compiler, kernel, and so on) of the
+operating system on which the executable runs, unless that component
+itself accompanies the executable.
+If distribution of executable or object code is made by offering
+access to copy from a designated place, then offering equivalent
+access to copy the source code from the same place counts as
+distribution of the source code, even though third parties are not
+compelled to copy the source along with the object code.
+  4. You may not copy, modify, sublicense, or distribute the Program
+except as expressly provided under this License.  Any attempt
+otherwise to copy, modify, sublicense or distribute the Program is
+void, and will automatically terminate your rights under this License.
+However, parties who have received copies, or rights, from you under
+this License will not have their licenses terminated so long as such
+parties remain in full compliance.
+  5. You are not required to accept this License, since you have not
+signed it.  However, nothing else grants you permission to modify or
+distribute the Program or its derivative works.  These actions are
+prohibited by law if you do not accept this License.  Therefore, by
+modifying or distributing the Program (or any work based on the
+Program), you indicate your acceptance of this License to do so, and
+all its terms and conditions for copying, distributing or modifying
+the Program or works based on it.
+  6. Each time you redistribute the Program (or any work based on the
+Program), the recipient automatically receives a license from the
+original licensor to copy, distribute or modify the Program subject to
+these terms and conditions.  You may not impose any further
+restrictions on the recipients' exercise of the rights granted herein.
+You are not responsible for enforcing compliance by third parties to
+this License.
+  7. If, as a consequence of a court judgment or allegation of patent
+infringement or for any other reason (not limited to patent issues),
+conditions are imposed on you (whether by court order, agreement or
+otherwise) that contradict the conditions of this License, they do not
+excuse you from the conditions of this License.  If you cannot
+distribute so as to satisfy simultaneously your obligations under this
+License and any other pertinent obligations, then as a consequence you
+may not distribute the Program at all.  For example, if a patent
+license would not permit royalty-free redistribution of the Program by
+all those who receive copies directly or indirectly through you, then
+the only way you could satisfy both it and this License would be to
+refrain entirely from distribution of the Program.
+If any portion of this section is held invalid or unenforceable under
+any particular circumstance, the balance of the section is intended to
+apply and the section as a whole is intended to apply in other
+circumstances.
+It is not the purpose of this section to induce you to infringe any
+patents or other property right claims or to contest validity of any
+such claims; this section has the sole purpose of protecting the
+integrity of the free software distribution system, which is
+implemented by public license practices.  Many people have made
+generous contributions to the wide range of software distributed
+through that system in reliance on consistent application of that
+system; it is up to the author/donor to decide if he or she is willing
+to distribute software through any other system and a licensee cannot
+impose that choice.
+This section is intended to make thoroughly clear what is believed to
+be a consequence of the rest of this License.
+  8. If the distribution and/or use of the Program is restricted in
+certain countries either by patents or by copyrighted interfaces, the
+original copyright holder who places the Program under this License
+may add an explicit geographical distribution limitation excluding
+those countries, so that distribution is permitted only in or among
+countries not thus excluded.  In such case, this License incorporates
+the limitation as if written in the body of this License.
+  9. The Free Software Foundation may publish revised and/or new versions
+of the General Public License from time to time.  Such new versions will
+be similar in spirit to the present version, but may differ in detail to
+address new problems or concerns.
+Each version is given a distinguishing version number.  If the Program
+specifies a version number of this License which applies to it and "any
+later version", you have the option of following the terms and conditions
+either of that version or of any later version published by the Free
+Software Foundation.  If the Program does not specify a version number of
+this License, you may choose any version ever published by the Free Software
+Foundation.
+  10. If you wish to incorporate parts of the Program into other free
+programs whose distribution conditions are different, write to the author
+to ask for permission.  For software which is copyrighted by the Free
+Software Foundation, write to the Free Software Foundation; we sometimes
+make exceptions for this.  Our decision will be guided by the two goals
+of preserving the free status of all derivatives of our free software and
+of promoting the sharing and reuse of software generally.
+			    NO WARRANTY
+  11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY
+FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW.  EXCEPT WHEN
+OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
+PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED
+OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.  THE ENTIRE RISK AS
+TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU.  SHOULD THE
+PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING,
+REPAIR OR CORRECTION.
+  12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
+WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR
+REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES,
+INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING
+OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED
+TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY
+YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER
+PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE
+POSSIBILITY OF SUCH DAMAGES.
+		     END OF TERMS AND CONDITIONS
+	Appendix: How to Apply These Terms to Your New Programs
+  If you develop a new program, and you want it to be of the greatest
+possible use to the public, the best way to achieve this is to make it
+free software which everyone can redistribute and change under these terms.
+  To do so, attach the following notices to the program.  It is safest
+to attach them to the start of each source file to most effectively
+convey the exclusion of warranty; and each file should have at least
+the "copyright" line and a pointer to where the full notice is found.
+    <one line to give the program's name and a brief idea of what it does.>
+    Copyright (C) 19yy  <name of author>
+    This program is free software; you can redistribute it and/or modify
+    it under the terms of the GNU General Public License as published by
+    the Free Software Foundation; either version 2 of the License, or
+    (at your option) any later version.
+    This program is distributed in the hope that it will be useful,
+    but WITHOUT ANY WARRANTY; without even the implied warranty of
+    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+    GNU General Public License for more details.
+    You should have received a copy of the GNU General Public License
+    along with this program; if not, write to the Free Software
+    Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
+Also add information on how to contact you by electronic and paper mail.
+If the program is interactive, make it output a short notice like this
+when it starts in an interactive mode:
+    Gnomovision version 69, Copyright (C) 19yy name of author
+    Gnomovision comes with ABSOLUTELY NO WARRANTY; for details type `show w'.
+    This is free software, and you are welcome to redistribute it
+    under certain conditions; type `show c' for details.
+The hypothetical commands `show w' and `show c' should show the appropriate
+parts of the General Public License.  Of course, the commands you use may
+be called something other than `show w' and `show c'; they could even be
+mouse-clicks or menu items--whatever suits your program.
+You should also get your employer (if you work as a programmer) or your
+school, if any, to sign a "copyright disclaimer" for the program, if
+necessary.  Here is a sample; alter the names:
+  Yoyodyne, Inc., hereby disclaims all copyright interest in the program
+  `Gnomovision' (which makes passes at compilers) written by James Hacker.
+  <signature of Ty Coon>, 1 April 1989
+  Ty Coon, President of Vice
+This General Public License does not permit incorporating your program into
+proprietary programs.  If your program is a subroutine library, you may
+consider it more useful to permit linking proprietary applications with the
+library.  If this is what you want to do, use the GNU Library General
+Public License instead of this License.
diff --git a/misc/shgen/TODO b/misc/shgen/TODO
index 0000000..bcdd1bf
--- /dev/null
+++ b/misc/shgen/TODO
@@ -0,0 +1,13 @@
+* Add support for more drivers to shgen !!!!
+* shgen relies on having a gnu-compatible getopt, which should be
+  available on all hosts using gcc/egcs/binutils.
+  Using other getopt-variants may produce faulty results or shgen may also
+  refuse to compile. Probably the easiest solution to this problem would be
+  to integrate libiberty into rtems.
+* shgen uses floating point mathematics. Therefore Makefile.in contains a
+  reference to libm. In case the host doesn't have its floating point
+  support in libm, shgen will fail to compile. If we should ever meet such
+  a host, checks for floating point libraries have to be added to rtems'
+  autoconf support.
diff --git a/misc/shgen/sci.c b/misc/shgen/sci.c
index 0000000..2b68612
--- /dev/null
+++ b/misc/shgen/sci.c
@@ -0,0 +1,177 @@
+ * Copyright (c) 1998 Ralf Corsepius (corsepiu at faw.uni-ulm.de)
+ * See the file COPYING for copyright notice.
+#include <math.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include "sci.h"
+   n .. baudrate generator source 0,1,2,3
+   N .. BRR setting (0..255)
+   Phi .. processor baud rate
+   B .. bitrate
+typedef struct sci_tab {
+  unsigned int  B ;
+  unsigned int  n ;
+  int 		N ;
+  double        err ;
+  } sci_tab_t ;
+static unsigned int bitrate [] = {
+  50,
+  75,
+  110,
+  134,
+  150,
+  200,
+  300,
+  600,
+  1200,
+  1800,
+  2400,
+  4800,
+  9600,
+  19200,
+  38400,
+  7200,
+  14400,
+  28800,
+  57600,
+  76800,
+  115200,
+  230400,
+  460800,
+  921600
+static sci_tab_t test_array[4] ;
+static void Compute(
+  unsigned int n,
+  unsigned int B,
+  double   Phi,
+  struct sci_tab *entry )
+  int    a = ( 32 << ( 2 * n ) ) * B ;
+  entry->n = n ;
+  entry->B = B ;
+  entry->N = rint( ( Phi / a ) - 1.0 ) ;
+  if ( ( entry->N > 0 ) && ( entry->N < 256 ) )
+    entry->err =
+      ( ( Phi / ( (entry->N + 1) * a ) - 1.0 ) * 100.0 );
+  else
+    entry->err = 100.0 ;
+    entry->n = 255 ;
+    entry->N = 0 ;
+static sci_tab_t *SelectN(
+  unsigned int 	B,
+  double 	Phi )
+  unsigned int i ;
+  struct sci_tab* best = NULL ;
+  for ( i = 0 ; i < 4 ; i++ )
+    double err ;
+    Compute( i, B, Phi, &test_array[i] );
+    err = fabs( test_array[i].err );
+    if ( best )
+      if ( err < fabs( best->err ) )
+        best = &test_array[i] ;
+    else
+  return best ;
+int shgen_gensci(
+  FILE		*file,
+  double	Phi ) /* Processor frequency [Hz] */
+  unsigned int i ;
+  fprintf( file,
+    "/*\n * Bitrate table for the serial devices (sci) of the SH at %.3f MHz\n"
+    " */\n\n", Phi / 1000000.0 );
+  fprintf( file,
+    "/*\n"
+    " * n     .. SMR bits 0,1 : baud rate generator clock source\n"
+    " * N     .. BRR bits 0..7: setting for baud rate generator\n"
+    " * error .. percentual error to nominal bitrate\n"
+    " *   Hitachi's HW manual recommends bitrates with an error less than 1%%\n"
+    " *   We experienced values less than 2%% to be stable\n"
+    " */\n\n" );
+  fprintf( file, "#include <bsp.h>\n" );
+  fprintf( file, "#include <termios.h>\n\n" );
+  fprintf( file,
+    "static struct sci_bitrate_t {\n"
+    "  unsigned char n ;\n"
+    "  unsigned char N ;\n"
+    "  speed_t       B ;\n"
+    "} _sci_bitrates[] = {\n"
+    "/*  n    N      B      error */\n" );
+  for ( i = 0 ; i < sizeof(bitrate)/sizeof(int) ; i++ )
+    struct sci_tab* best = SelectN( bitrate[i], Phi );
+    if ( i > 0 )
+      fprintf( file, ",\n" );
+      fprintf( file, "  { %1d, %3d, %d } /* %+7.2f%% ; B%d ",
+      best->n,
+      best->N,
+      best->B,
+      best->err,
+      best->B );
+    if ( best->n > 3 )
+      fprintf( file, "(unusable) " );
+    fprintf( file, "*/" );
+  fprintf( file, "\n};\n\n" );
+  fprintf( file,
+    "int _sci_get_brparms( \n"
+    "  speed_t        spd,\n"
+    "  unsigned char *smr,\n"
+    "  unsigned char *brr )\n"
+    "{\n"
+    "  int offset = -1;\n"
+    "  int i;\n\n"
+    "  for(i = 0; i < sizeof(_sci_bitrates)/sizeof(_sci_bitrates[0]); i++) {\n"
+    "    if( _sci_bitrates[i].B == spd ) {\n"
+    "      offset = i;\n"
+    "      break;\n"
+    "    }\n"
+    "  }\n"
+    "  if ( offset == -1 ) return -1 ;\n"
+    "  if ( _sci_bitrates[offset].n > 3 )  return -1;\n\n"
+    "  *smr &= ~0x03;\n"
+    "  *smr |= _sci_bitrates[offset].n;\n"
+    "  *brr =  _sci_bitrates[offset].N;\n\n"
+    "  return 0;\n"
+    "}\n" );
+  return 0 ;
diff --git a/misc/shgen/sci.h b/misc/shgen/sci.h
index 0000000..b55bbfb
--- /dev/null
+++ b/misc/shgen/sci.h
@@ -0,0 +1,11 @@
+#ifndef _shgen_sci_h
+#define _shgen_sci_h
+#include <stdio.h>
+extern int shgen_gensci(
+  FILE		*file,
+  double	Phi /* Processor frequency [Hz] */
+#endif
diff --git a/misc/shgen/shgen.c b/misc/shgen/shgen.c
index 0000000..19e512b
--- /dev/null
+++ b/misc/shgen/shgen.c
@@ -0,0 +1,114 @@
+ * Copyright (c) 1998,1999,2000, 2006 Ralf Corsepius, Ulm Germany.
+#include <stdio.h>
+#include <string.h>	/* strcmp, strerror */
+#include <stdlib.h>	/* exit */
+#include <errno.h>
+#include <getopt.h>
+#include "sci.h"
+static void usage( FILE* ofile, char *prog )
+  fprintf( ofile, "Usage: %s [options] driver\n", prog );
+  fprintf( ofile, "\nOptions:\n" );
+  fprintf( ofile, "Processor frequency (default 20MHz):\n") ;
+  fprintf( ofile, "\t-M Phi      .. processor frequency [MHz]\n" );
+  fprintf( ofile, "\t-K Phi      .. processor frequency [KHz]\n" );
+  fprintf( ofile, "\t-H Phi      .. processor frequency [Hz]\n" );
+  fprintf( ofile, "Driver:\n" );
+  fprintf( ofile, "\tsci         .. bitrate table for sci\n" );
+  fprintf( ofile, "\nWritten by Ralf Corsepius <corsepiu at faw.uni-ulm.de>\n" );
+  fprintf( ofile, "\nCopyright (c) 1998,1999,2000\tRalf Corsepius\n" );
+#if HAVE_GETOPT_LONG
+#define NOARG   0
+#define HASARG  1
+#define OPTARG  2
+static struct option long_options[] =
+  { "version",  	NOARG,  NULL, 'v' },
+  { "help",     	NOARG,  NULL, 'h' },
+  { "mega-hertz",       HASARG, NULL, 'M' },
+  { "kilo-hertz",       HASARG, NULL, 'K' },
+  { "hertz",  		HASARG, NULL, 'H' },
+  { 0, 0, 0, 0 }
+#endif
+static void shgen_header( FILE *file )
+  fprintf( file,
+    "/*\n * DO NOT EDIT - this file is automatically generated by shgen %s\n",
+    RTEMS_RELEASE );
+  fprintf( file,
+    " * Copyright (c) 1998,1999,2000 Ralf Corsepius (corsepiu at faw.uni-ulm.de)\n */\n" );
+  fprintf( file,
+    "\n/* This file is not copyrighted */\n\n" );
+int main( int argc, char *argv[] )
+  double 	Phi = 20000000.0 ;
+  int option_index = 0 ;
+  while( ( optopt = getopt_long( argc, argv, "M:K:H:hv",
+      long_options, &option_index ) ) > 0 )
+#else
+  while ( ( optopt = getopt( argc, argv, "M:K:H:hv" ) ) > 0 )
+#endif
+    switch ( optopt )
+    case 'M' :
+      sscanf( optarg, "%lf", &Phi );
+      Phi = Phi * 1000000.0;
+      break ;
+    case 'K' :
+      Phi = Phi * 1000.0;
+      break ;
+    case 'H' :
+      break ;
+    case 'h' :
+      usage( stdout, argv[0] );
+      exit(0);
+    case 'v' :
+      fprintf( stdout, "%s version %s\n", argv[0], RTEMS_RELEASE );
+      exit(0);
+    default  :
+      usage( stderr, argv[0] );
+      exit(1);
+      break ;
+  if ( argc - optind != 1 )
+    fprintf( stderr, "%s: Missing argument: driver\n", argv[0] );
+    exit(1);
+  shgen_header( stdout );
+  if ( strcmp( argv[optind], "sci" ) == 0 )
+    shgen_gensci( stdout, Phi );
+  else
+    fprintf( stderr, "%s: Invalid argument: driver\n", argv[0] );
+    exit(1);
+  return 0 ;
diff --git a/misc/wscript b/misc/wscript
index 2b1332e..5db9107 100644
--- a/misc/wscript
+++ b/misc/wscript
@@ -66,5 +66,14 @@ def build(bld):
                 cflags = conf['cflags'] + conf['warningflags'],
                 linkflags = conf['linkflags'])
+    # Build the shgen.
+    bld.program(target = 'rtems-shgen',
+                source = [ 'shgen/sci.c', 'shgen/shgen.c' ],
+                defines = defines,
+                cflags = conf['cflags'] + conf['warningflags'],
+                linkflags = conf['linkflags'])
 def tags(ctx):
     ctx.exec_command('etags $(find . -name \*.[sSch])', shell = True)
2.13.7
