[PATCH 1/6] nios2gen: Import from RTEMS
Sebastian Huber
Thu Jun 7 05:39:02 UTC 2018
Corresponding RTEMS commit is 75933d5d25cd50f80162b7a0d2f66a5534e1763f.
Update #3444.
misc/nios2gen/LICENSE | 20 ++
misc/nios2gen/README | 146 ++++++++
misc/nios2gen/bridges.c | 112 +++++++
misc/nios2gen/bridges.h | 29 ++
misc/nios2gen/clocks.c | 75 +++++
misc/nios2gen/clocks.h | 26 ++
misc/nios2gen/devices.c | 130 +++++++
misc/nios2gen/devices.h | 30 ++
misc/nios2gen/linkcmds.c | 120 +++++++
misc/nios2gen/linkcmds.h | 23 ++
misc/nios2gen/memory.c | 101 ++++++
misc/nios2gen/memory.h | 27 ++
misc/nios2gen/nios2gen.c | 492 +++++++++++++++++++++++++++
misc/nios2gen/output.c | 193 +++++++++++
misc/nios2gen/output.h | 25 ++
misc/nios2gen/ptf.c | 857 +++++++++++++++++++++++++++++++++++++++++++++++
misc/nios2gen/ptf.h | 69 ++++
misc/nios2gen/sample.ptf | 462 +++++++++++++++++++++++++
misc/wscript | 70 ++++
wscript | 1 +
20 files changed, 3008 insertions(+)
create mode 100644 misc/nios2gen/LICENSE
create mode 100644 misc/nios2gen/README
create mode 100644 misc/nios2gen/bridges.c
create mode 100644 misc/nios2gen/bridges.h
create mode 100644 misc/nios2gen/clocks.c
create mode 100644 misc/nios2gen/clocks.h
create mode 100644 misc/nios2gen/devices.c
create mode 100644 misc/nios2gen/devices.h
create mode 100644 misc/nios2gen/linkcmds.c
create mode 100644 misc/nios2gen/linkcmds.h
create mode 100644 misc/nios2gen/memory.c
create mode 100644 misc/nios2gen/memory.h
create mode 100644 misc/nios2gen/nios2gen.c
create mode 100644 misc/nios2gen/output.c
create mode 100644 misc/nios2gen/output.h
create mode 100644 misc/nios2gen/ptf.c
create mode 100644 misc/nios2gen/ptf.h
create mode 100644 misc/nios2gen/sample.ptf
create mode 100644 misc/wscript
diff --git a/misc/nios2gen/LICENSE b/misc/nios2gen/LICENSE
new file mode 100644
index 0000000..1d85bbf
--- /dev/null
+++ b/misc/nios2gen/LICENSE
@@ -0,0 +1,20 @@
+ LICENSE INFORMATION
+RTEMS is free software; you can redistribute it and/or modify it under
+terms of the GNU General Public License as published by the
+Free Software Foundation; either version 2, or (at your option) any
+later version. RTEMS is distributed in the hope that it will be useful,
+but WITHOUT ANY WARRANTY; without even the implied warranty of
+MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+General Public License for more details. You should have received
+a copy of the GNU General Public License along with RTEMS; see
+file COPYING. If not, write to the Free Software Foundation, 675
+Mass Ave, Cambridge, MA 02139, USA.
+As a special exception, including RTEMS header files in a file,
+instantiating RTEMS generics or templates, or linking other files
+with RTEMS objects to produce an executable application, does not
+by itself cause the resulting executable application to be covered
+by the GNU General Public License. This exception does not
+however invalidate any other reasons why the executable file might be
+covered by the GNU Public License.
diff --git a/misc/nios2gen/README b/misc/nios2gen/README
index 0000000..1edcdb6
--- /dev/null
+++ b/misc/nios2gen/README
@@ -0,0 +1,146 @@
+nios2gen:
+ Tool to generate BSP data for boards utilizing NIOS2 soft core processor.
+What it does
+It creates a sopc.h and linkcmds file for RTEMS nios2 BSPs from one or more inputs:
+1. SOPC System Description PTF
+As an output from SOPC Builder you get a file with extension ".ptf" that fully
+describes the SOPC, including all CPUs, memory and integrated peripherals.
+(PTF simply means "plain-text file").
+2. BSP Configuration PTF
+This file, using the same format as the SOPC System Description PTF, describes
+which components of the SOPC shall be used by the BSP. For example, there may
+be several timers, but a BSP wants at least one named "CLOCK" and optionally
+another named "TIMER". This mapping can be specified in the BSP.
+Contents of the configuration PTF
+There can be definitions of ...
+HEADER: This is written to sopc.h before anything else. Example:
+ HEADER = "
+ #ifndef __SOPC_H
+ #define __SOPC_H 1
+EPILOG: This is written to sopc.h after anything else. Example:
+ EPILOG = "
+ #endif
+CLOCKS section: Used to specify names for clocks to be used in definitions in
+the sopc.h. The default name (if none is specified here) is the uppercased name
+as in the system description PTF. Specify the name you want on the left, the
+name in the sopc PTF on the right! Example:
+ CLOCKS
+ GLOBAL_CLOCK = "sys_clk";
+MODULES section: Same as clocks but for modules / peripherals. As a special definition,
+if the PTF contains more than one nios2 CPU, it /must/ define a CPU to use. Example to
+select cpu_0 and rename timer_0 to CLOCK and timer_1 to TIMER:
+ MODULES
+ CPU = "cpu_0";
+ CLOCK = "timer_0";
+ TIMER = "timer_1";
+CLASS xyz sections: These specify what you want in the sopc.h, and how the definitions
+shall be named. Actually, the CLASS xyz should look exactly like the corresponding MODULE
+specification in the system description PTF of modules belonging to that class; e.g. a
+a JTAG UART is originally described like this:
+ MODULE jtag_uart_0
+ class = "altera_avalon_jtag_uart";
+ class_version = "1.0";
+ iss_model_name = "altera_avalon_jtag_uart";
+ SLAVE avalon_jtag_slave
+ SYSTEM_BUILDER_INFO
+ Bus_Type = "avalon";
+ Is_Printable_Device = "1";
+ Address_Alignment = "native";
+ Address_Width = "1";
+ Data_Width = "32";
+ Has_IRQ = "1";
+ Read_Wait_States = "peripheral_controlled";
+ Write_Wait_States = "peripheral_controlled";
+ JTAG_Hub_Base_Id = "0x04006E";
+ JTAG_Hub_Instance_Id = "0";
+ MASTERED_BY cpu_0/data_master
+ priority = "1";
+ IRQ_MASTER cpu_0/data_master
+ IRQ_Number = "2";
+ Base_Address = "0x08000000";
+If you want to have definitions about its base address and irq number in your sopc.h,
+define a CLASS for altera_avalon_jtag_uart that matches the MODULE description above,
+but instead of values for the items you specify names to be used in your sopc.h (You
+can omit items from the MODULE as you like, but the section nesting must match; and
+section names (such as avalon_jtag_slave for the SLAVE section) also have to match)
+ CLASS altera_avalon_jtag_uart
+ Base_Address = "BASE_ADDR";
+ IRQ_MASTER { IRQ_Number = "IRQ"; }
+The output for jtag_uart_0 will be:
+ #define JTAG_UART_BASE_ADDR 0x021208D0
+ #define JTAG_UART_IRQ 1
+There are some values with special meaning to nios2gen,
+N2G_CLOCKREF_CLOCK: This should be used whereever the value in the SOPC PTF
+specifies the name of a clock. nios2gen will use whatever you configured for
+the selected clock in your CLOCKS section.
+N2G_CLOCKREF_DEVICE: This should be used whereever the value in the SOPC PTF
+specifies the name of a module. nios2gen will use whatever you configured for
+the selected module in your MODULES section.
+Additionally, you can specify items in your CLASSes so that nios2gen will include
+constant definitions in the sopc.h whenever such CLASS is present. The format is
+ N2G_DEFINE_xyz = "123"
+and will result in
+#define MODULENAME_xyz 123
diff --git a/misc/nios2gen/bridges.c b/misc/nios2gen/bridges.c
index 0000000..feb90f9
--- /dev/null
+++ b/misc/nios2gen/bridges.c
@@ -0,0 +1,112 @@
+ * Copyright (c) 2006 Kolja Waschk rtemsdev/ixo.de
+/* Find bus bridges */
+/* This part of the program builds a list with pairs of bus
+ master port names (each is "device name/master port name").
+ It is then possible to find if a given master is actually
+ available under a different master port name through bridges.
+/* Typical example with external SRAM that is slave of
+ tristate_bridge_0/tristate_master, and
+ tristate_bridge_0 itself is slave of cpu0/data_master, the
+ bridge information would be stored as this bus_bridge_pair:
+ mastered_by = "cpu0/data_master" and
+ bridges_to = "tristate_bridge_0/tristate_master".
+ That allows to deduce that SRAM is actually mastered by
+ cpu0/data_master. If there were any address or bus width
+ translations, it should be noted in the bridges list... For
+ now we simply assume that bridges never translate anything.
+#include <string.h>
+#include <stdlib.h>
+#include "ptf.h"
+#include "bridges.h"
+int is_bridged(
+ char *cpu_master,
+ char *dev_master,
+ bus_bridge_pair *bridges)
+ char *curr_master;
+ bus_bridge_pair *bbp;
+ if(strcmp(cpu_master, dev_master) == 0) return 1; /* cpu directly masters dev */
+ for(bbp = bridges; bbp != NULL; bbp=bbp->next)
+ if(strcmp(cpu_master, bbp->mastered_by) == 0 &&
+ is_bridged(bbp->bridges_to, dev_master, bridges))
+ return 1; /* cpu masters dev via bridge */
+ return 0;
+void add_bridge_master(struct ptf_item *pi, void *arg)
+ struct { char *bt; bus_bridge_pair **bridges; } *binfo = arg;
+ bus_bridge_pair *new_pair;
+ if(binfo->bridges == 0) return;
+ new_pair = (bus_bridge_pair *)malloc(sizeof(bus_bridge_pair));
+ if(new_pair == NULL) return;
+ new_pair->bridges_to = binfo->bt;
+ new_pair->mastered_by = pi->item[pi->level]->value;
+ new_pair->next = *(binfo->bridges);
+ *(binfo->bridges) = new_pair;
+void add_bridge_dest(struct ptf_item *pi, void *arg)
+ struct ptf maby_section = { section, "MASTERED_BY", 0, 0, 0 };
+ struct ptf_item maby = { 1, &maby_section };
+ char *bridge_name = pi->item[1]->value;
+ char *bridge_dest = pi->item[pi->level]->value;
+ struct { char *bt; bus_bridge_pair **bridges; } binfo;
+ binfo.bridges = arg;
+ binfo.bt = (char*)malloc(strlen(bridge_name)+strlen(bridge_dest) + 2);
+ strcpy(binfo.bt, bridge_name);
+ strcat(binfo.bt, "/");
+ strcat(binfo.bt, bridge_dest);
+ ptf_match(pi->item[pi->level-1]->sub, &maby, add_bridge_master, &binfo);
+ /* binfo.bt is NOT freed here */
+bus_bridge_pair *find_bridges(struct ptf *p)
+ bus_bridge_pair *bridges = 0;
+ struct ptf system = { section, "SYSTEM", 0, 0, 0 };
+ struct ptf module = { section, "MODULE", 0, 0, 0 };
+ struct ptf slave = { section, "SLAVE", 0, 0, 0 };
+ struct ptf syb = { section, "SYSTEM_BUILDER_INFO", 0, 0, 0 };
+ struct ptf to = { item, "Bridges_To", 0, 0, 0 };
+ struct ptf_item brdg = { 5, &system, &module, &slave, &syb, &to };
+ ptf_match(p, &brdg, add_bridge_dest, &bridges);
+ return bridges;
diff --git a/misc/nios2gen/bridges.h b/misc/nios2gen/bridges.h
index 0000000..7c2b851
--- /dev/null
+++ b/misc/nios2gen/bridges.h
@@ -0,0 +1,29 @@
+#ifndef __NIOS2GEN_BRIDGES_H
+#define __NIOS2GEN_BRIDGES_H 1
+typedef struct bus_bridge_pair
+ char *mastered_by;
+ char *bridges_to;
+ struct bus_bridge_pair *next;
+bus_bridge_pair;
+bus_bridge_pair *find_bridges(struct ptf *p);
+int is_bridged(
+ char *cpu_master,
+ char *dev_master,
+ bus_bridge_pair *bridges);
+#endif
diff --git a/misc/nios2gen/clocks.c b/misc/nios2gen/clocks.c
index 0000000..cb2befa
--- /dev/null
+++ b/misc/nios2gen/clocks.c
@@ -0,0 +1,75 @@
+#include "ptf.h"
+#include "clocks.h"
+void add_clock_spec(struct ptf_item *pi, void *arg)
+ clock_desc **clocks = arg;
+ clock_desc *new_clock;
+ unsigned long freq;
+ new_clock = (clock_desc*)malloc(sizeof(clock_desc));
+ if(new_clock == NULL) return;
+ new_clock->freq = strtoul(pi->item[pi->level]->value, 0, 0);
+ new_clock->cfgname = NULL;
+ new_clock->name = pi->item[pi->level-1]->value;
+ new_clock->next = *clocks;
+ *clocks = new_clock;
+void set_clock_cfgname(struct ptf_item *pi, void *arg)
+ clock_desc *clock = arg;
+ clock->cfgname = pi->item[pi->level]->name;
+clock_desc *find_clocks( struct ptf *sopc, struct ptf *cfg )
+ clock_desc *clocks, *reverse;
+ struct ptf wizargs = { section, "WIZARD_SCRIPT_ARGUMENTS", 0, 0, 0 };
+ struct ptf all = { section, "CLOCKS", 0, 0, 0 };
+ struct ptf clock = { section, "CLOCK", 0, 0, 0 };
+ struct ptf freq = { item, "frequency", 0, 0, 0 };
+ struct ptf_item clk_spec = { 5, &system, &wizargs, &all, &clock, &freq };
+ struct ptf named = { item, 0, 0, 0, 0 };
+ struct ptf_item clk_cfg = { 2, &all, &named };
+ clocks = NULL;
+ ptf_match(sopc, &clk_spec, add_clock_spec, &clocks);
+ /* Reverse the linked list and look for configured names */
+ reverse = NULL;
+ while(clocks)
+ clock_desc *tmp = clocks;
+ clocks = clocks->next;
+ tmp->next = reverse;
+ reverse = tmp;
+ named.value = tmp->name;
+ ptf_match(cfg, &clk_cfg, set_clock_cfgname, tmp);
+ if(tmp->cfgname == NULL) tmp->cfgname = ptf_defused_name(tmp->name);
+ return reverse;
diff --git a/misc/nios2gen/clocks.h b/misc/nios2gen/clocks.h
index 0000000..9129c79
--- /dev/null
+++ b/misc/nios2gen/clocks.h
@@ -0,0 +1,26 @@
+#ifndef __NIOS2GEN_CLOCKS_H
+#define __NIOS2GEN_CLOCKS_H 1
+#include "ptf.h"
+typedef struct clockdsc
+ char *name;
+ char *cfgname;
+ struct clockdsc *next;
+clock_desc;
+clock_desc *find_clocks( struct ptf *ptf, struct ptf *cfg );
+#endif
diff --git a/misc/nios2gen/devices.c b/misc/nios2gen/devices.c
index 0000000..7894294
--- /dev/null
+++ b/misc/nios2gen/devices.c
@@ -0,0 +1,130 @@
+#include <stdio.h>
+#include "ptf.h"
+#include "devices.h"
+void add_device(device_desc **dl, struct ptf *dev)
+ device_desc *eds;
+ for(eds = *dl; eds; eds = eds->next)
+ if(eds->ptf == dev)
+ eds->slaves++;
+ return;
+ eds = (device_desc *)malloc(sizeof(device_desc));
+ eds->slaves = 1;
+ eds->ptf = dev;
+ eds->next = *dl;
+ *dl = eds;
+void check_and_add_device(struct ptf_item *pi, void *arg)
+ struct ptf *module = pi->item[pi->level-3];
+ struct ptf *sysinfo = pi->item[pi->level-2];
+ char *master_name = pi->item[pi->level]->value;
+ struct { char *dm; char *im; device_desc **dl; bus_bridge_pair *bridges; } *dinfo = arg;
+ if(is_bridged(dinfo->dm, master_name, dinfo->bridges) ||
+ is_bridged(dinfo->im, master_name, dinfo->bridges))
+ struct ptf *ni = ptf_alloc_item(item, "N2G_Selected", "1");
+ if(ni != NULL)
+ ni->next = sysinfo->sub;
+ sysinfo->sub = ni;
+ add_device(dinfo->dl, module);
+void set_dev_cfgname(struct ptf_item *pi, void *arg)
+ device_desc *dev = arg;
+ dev->cfgname = pi->item[pi->level]->name;
+device_desc *find_devices(
+ struct ptf *ptf,
+ struct ptf *cfg,
+ struct ptf *cpu,
+ struct ptf maby = { section, "MASTERED_BY", 0, 0, 0 };
+ struct ptf_item brdg = { 5, &system, &module, &slave, &syb, &maby };
+ struct ptf modules = { section, "MODULES", 0, 0, 0 };
+ struct ptf named = { item, 0, 0, 0, 0};
+ struct ptf_item devcf = { 2, &modules, &named };
+ struct { char *dm; char *im; device_desc **dl; bus_bridge_pair *bridges; } dinfo;
+ device_desc *found, *reverse;
+ found = NULL;
+ add_device(&found, cpu); /* The CPU is "self-connected", add it */
+ dinfo.dl = &found;
+ dinfo.bridges = bridges;
+ dinfo.dm = (char *)malloc(strlen(cpu->value)+13);
+ dinfo.im = (char *)malloc(strlen(cpu->value)+20);
+ strcpy(dinfo.im, cpu->value);
+ strcat(dinfo.im, "/");
+ strcpy(dinfo.dm, dinfo.im);
+ strcat(dinfo.dm, "data_master");
+ strcat(dinfo.im, "instruction_master");
+ /* "Available" is any MODULE with a SLAVE section that is MASTERED_BY
+ either instr_master or data_master of selected CPU, either directly
+ or through a bridge. See code above for more info about bridges.
+ ptf_match(ptf, &brdg, check_and_add_device, &dinfo);
+ free(dinfo.dm);
+ free(dinfo.im);
+ /* Reverse the linked list */
+ reverse = NULL;
+ while(found)
+ device_desc *tmp = found;
+ found = found->next;
+ reverse = tmp;
+ named.value = tmp->ptf->value;
+ tmp->cfgname = NULL;
+ ptf_match(cfg, &devcf, set_dev_cfgname, tmp);
+ if(tmp->cfgname == NULL) tmp->cfgname = ptf_defused_name(tmp->ptf->value);
+ return reverse;
diff --git a/misc/nios2gen/devices.h b/misc/nios2gen/devices.h
index 0000000..f0e8208
--- /dev/null
+++ b/misc/nios2gen/devices.h
@@ -0,0 +1,30 @@
+#ifndef __NIOS2GEN_DEVICES_H
+#define __NIOS2GEN_DEVICES_H 1
+#include "ptf.h"
+typedef struct dev_descr
+ int slaves;
+ char *cfgname;
+ struct ptf *ptf;
+ struct dev_descr *next;
+device_desc;
+ struct ptf *ptf,
+ struct ptf *cfg,
+ struct ptf *cpu,
+#endif
diff --git a/misc/nios2gen/linkcmds.c b/misc/nios2gen/linkcmds.c
index 0000000..8ed0ddb
--- /dev/null
+++ b/misc/nios2gen/linkcmds.c
@@ -0,0 +1,120 @@
+#include <stdio.h>
+#include "ptf.h"
+#include "output.h" /* is_not_connected, fwrite_value, etc */
+#include "memory.h"
+#include "linkcmds.h"
+typedef struct
+ FILE *file;
+ struct ptf *cfg, *cpu;
+ device_desc *devices;
+ memory_desc *memory;
+lcmd_desc;
+void fwrite_lcmds_section(struct ptf_item *pi, void *arg)
+ lcmd_desc *li = (lcmd_desc *)arg;
+ struct ptf *p;
+ struct ptf_item lpi;
+ char *location = NULL;
+ char *section_name = pi->item[1]->value;
+ if(section_name == 0)
+ fprintf(stderr, "Found a LINKER/SECTION without name, ignoring it.\n");
+ return;
+ p = ptf_find(pi->item[1]->sub, &lpi, item, "LOCATION", 0);
+ if(p)
+ location = p->value;
+ else
+ if(strcmp(section_name, "entry") == 0)
+ p = ptf_find(li->cpu, &lpi, item, "reset_slave", 0);
+ else if(strcmp(section_name, "exceptions") == 0)
+ p = ptf_find(li->cpu, &lpi, item, "exc_slave", 0);
+ if(p) location = p->value;
+ /* TODO: This doesn't work yet, parse full slave address, translate into our naming */
+ if(location == 0)
+ fprintf(stderr, "No LOCATION configured for section '%s'!\n", pi->item[1]->value);
+ return;
+ fprintf(li->file, " .%s :\n {\n", pi->item[1]->value);
+ fprintf(li->file, pi->item[2]->value);
+ fprintf(li->file, " } > %s\n\n", location);
+void fwrite_linkcmds_file(FILE *file, struct ptf *cfg, struct ptf *cpu, device_desc *devices, memory_desc *memory)
+ struct ptf *p;
+ struct ptf_item pi;
+ memory_desc *tmd;
+ lcmd_desc linfo;
+ struct ptf ptlink = { section, "LINKCMDS", 0, 0, 0 };
+ struct ptf ptleadtext = { item, "LEADTEXT", 0, 0, 0 };
+ struct ptf ptepilog = { item, "EPILOG", 0, 0, 0 };
+ struct ptf_item malihead = { 2, &ptlink, &ptleadtext };
+ struct ptf_item maliepil = { 2, &ptlink, &ptepilog };
+ struct ptf ptsect = { section, "SECTION", 0, 0, 0 };
+ struct ptf ptcmds = { item, "COMMANDS", 0, 0, 0 };
+ struct ptf ptstabs = { item, "STABS", 0, 0, 0 };
+ struct ptf_item malisect = { 3, &ptlink, &ptsect, &ptcmds };
+ struct ptf_item malistabs = { 2, &ptlink, &ptstabs };
+ linfo.cfg = cfg;
+ linfo.cpu = cpu;
+ linfo.file = file;
+ linfo.devices = devices;
+ linfo.memory = memory;
+ ptf_match(cfg, &malihead, fwrite_value, file);
+ fprintf(file, "MEMORY\n{\n");
+ for(tmd = linfo.memory; tmd; tmd = tmd->next)
+ fprintf(file, " %s : ORIGIN = 0x%08X, LENGTH = 0x%08X\n", tmd->dev->cfgname, tmd->base, tmd->size);
+ fprintf(file, "}\n\nSECTIONS\n{\n");
+ ptf_match(cfg, &malisect, fwrite_lcmds_section, &linfo);
+ ptf_match(cfg, &malistabs, fwrite_value, file);
+ fprintf(file, "}\n\n");
+ ptf_match(cfg, &maliepil, fwrite_value, file);
diff --git a/misc/nios2gen/linkcmds.h b/misc/nios2gen/linkcmds.h
index 0000000..9d34124
--- /dev/null
+++ b/misc/nios2gen/linkcmds.h
@@ -0,0 +1,23 @@
+#ifndef __LINKCMDS_H
+#define __LINKCMDS_H 1
+#include <stdio.h>
+#include "ptf.h"
+void fwrite_linkcmds_file(FILE *file, struct ptf *cfg, struct ptf *cpu, device_desc *devices, memory_desc *memory);
+#endif
diff --git a/misc/nios2gen/memory.c b/misc/nios2gen/memory.c
index 0000000..cb1ea7f
--- /dev/null
+++ b/misc/nios2gen/memory.c
@@ -0,0 +1,101 @@
+#include <stdio.h>
+#include "ptf.h"
+memory_desc *find_memory(device_desc *devices)
+ struct ptf *p;
+ memory_desc *tmd;
+ memory_desc *memory = NULL;
+ /* Check which of the devices are memory, sort by size */
+ if(devices)
+ struct ptf *p, *s;
+ device_desc *dd;
+ for(dd = devices; dd; dd=dd->next)
+ p = ptf_find(dd->ptf->sub, &pi, item, "Is_Memory_Device", "1");
+ if(p != NULL && pi.level>0)
+ s = pi.item[pi.level-1];
+ p = ptf_find(s, &pi, item, "Base_Address", 0);
+ if(p != NULL)
+ tmd = (memory_desc*)malloc(sizeof(memory_desc));
+ if(tmd != NULL)
+ tmd->base = strtoul(p->value, 0, 0);
+ p = ptf_find(s, &pi, item, "Address_Span", 0);
+ if(p != 0)
+ tmd->size = strtoul(p->value, 0, 0);
+ else
+ tmd->size = 0;
+ p = ptf_find(s, &pi, item, "Address_Width", 0);
+ if(p) tmd->size = 1 << strtoul(p->value, 0, 0);
+ p = ptf_find(s, &pi, item, "Data_Width", 0);
+ if(p) tmd->size *= (strtoul(p->value, 0, 0) >> 3);
+ if(tmd->size == 0)
+ free(tmd);
+ else
+ tmd->dev = dd;
+ if(memory == NULL)
+ tmd->next = NULL;
+ memory = tmd;
+ else
+ if(tmd->size > memory->size)
+ tmd->next = memory;
+ memory = tmd;
+ else
+ memory_desc *uplink = memory;
+ while(uplink->next != NULL && uplink->next->size > tmd->size) uplink=uplink->next;
+ tmd->next = uplink->next;
+ uplink->next = tmd;
+ return memory;
diff --git a/misc/nios2gen/memory.h b/misc/nios2gen/memory.h
index 0000000..43c2078
--- /dev/null
+++ b/misc/nios2gen/memory.h
@@ -0,0 +1,27 @@
+#ifndef __MEMORY_H
+#define __MEMORY_H 1
+typedef struct memdsc
+ unsigned long base;
+ unsigned long size;
+ device_desc *dev;
+ struct memdsc *next;
+memory_desc;
+memory_desc *find_memory(device_desc *devices);
+#endif
diff --git a/misc/nios2gen/nios2gen.c b/misc/nios2gen/nios2gen.c
index 0000000..688038a
--- /dev/null
+++ b/misc/nios2gen/nios2gen.c
@@ -0,0 +1,492 @@
+#include <stdio.h>
+#include "ptf.h"
+#define NIOS2GEN_PACKAGE "rtems-nios2gen"
+#include "getopt.h"
+void store_ptf_parent(struct ptf_item *pi, void *arg)
+ struct ptf *p = pi->item[pi->level-1];
+ *(struct ptf **)arg = p;
+void store_ptf_ptr(struct ptf_item *pi, void *arg)
+ struct ptf *p = pi->item[pi->level];
+void printf_ptf_value(struct ptf_item *pi, void *arg)
+ printf(*(char **)arg, p->value);
+void read_include_file(struct ptf_item *pi, void *arg)
+ struct ptf *inc, *next;
+ inc = ptf_parse_file(p->value);
+ if(inc == NULL)
+ fprintf(stderr, "Warning: couldn't parse included '%s'.\n", p->value);
+ return;
+ printf("Successfully read included PTF file %s.\n", p->value);
+ next = p->next;
+ for(p->next = inc; p->next != NULL; p = p->next);
+ p->next = next;
+void version(FILE *f)
+fprintf(f,
+ NIOS2GEN_PACKAGE " (" RTEMS_RELEASE ")\n"
+ " Copyright (c) 2006 Kolja Waschk rtemsdev/ixo.de\n"
+ "\n"
+ " The license and distribution terms for this file may be\n"
+ " found in the file LICENSE in this distribution or at\n"
+ " http://www.rtems.org/license/LICENSE.\n"
+void usage (FILE *f, char *errmsg)
+ char *info = "Purpose:\n Create RTEMS nios2 BSP configuration from Altera SOPC description\n";
+ if(errmsg) info=errmsg;
+ version(f);
+ fprintf(f,"\n%s\nUsage: " NIOS2GEN_PACKAGE " [OPTIONS] <SOPC PTF> [CONFIG PTF] [CONFIG PTF]...\n", info);
+ fprintf(f," -h --help Print help and exit\n");
+ fprintf(f," -V --version Print version and exit\n");
+ fprintf(f," -bFILENAME --bspheader=FILENAME Output BSP configuration header file (default='sopc.h')\n");
+ fprintf(f," -B --no-bspheader Do not output BSP configuration header file\n");
+ fprintf(f," -lFILENAME --linkcmds=FILENAME Output linker script (default='linkcmds')\n");
+ fprintf(f," -L --no-linkcmds Do not output linker script\n");
+ fprintf(f," -pFILENAME --parsed=FILENAME Output PTF contents as long list (default: don't)\n");
+ fprintf(f," -P --no-parsed Do not output PTF contents as long list\n");
+ fprintf(f," -q --quiet Do not print progress info to stdout\n\n");
+ fprintf(f,"Using \"-\" as the FILENAME means standard output (stdout).\n");
+int main(int argc, char *argv[])
+ struct ptf *sopc, *cfg, *p, *cpu;
+ bus_bridge_pair *bridges;
+ clock_desc *clocks;
+ int verbose = 1;
+ int output_order = 127;
+ char *parsed_filename = NULL;
+ int output_parsed = 0;
+ char *bspheader_filename = "sopc.h";
+ int output_bspheader = 1;
+ char *linkcmds_filename = "linkcmds";
+ int output_linkcmds = 2;
+ optarg = 0;
+ optind = 1;
+ opterr = 1;
+ optopt = '?';
+ if(argc > 126)
+ usage(stderr,"Too many commandline arguments!\n");
+ return -1;
+ while(1)
+ int c, long_index = 0;
+ static char *optstring = "hVBb:Ll:Pp:q";
+ static struct option long_options[] =
+ { "help", 0, NULL, 'h' },
+ { "version", 0, NULL, 'V' },
+ { "no-bspheader", 0, NULL, 'B' },
+ { "bspheader", 1, NULL, 'b' },
+ { "no-linkcmds", 0, NULL, 'L' },
+ { "linkcmds", 1, NULL, 'l' },
+ { "no-parsed", 0, NULL, 'P' },
+ { "parsed", 1, NULL, 'p' },
+ { "quiet", 0, NULL, 'q' },
+ { NULL, 0, NULL, 0 }
+ c = getopt_long (argc, argv, optstring, long_options, &long_index);
+ if(c == -1) break; /* Exit from while(1) loop */
+ switch(c)
+ case 'q': /* Be quiet */
+ verbose = 0;
+ break;
+ case 'h': /* Print help and exit */
+ usage(stdout,NULL);
+ return 0;
+ case 'V': /* Print version and exit */
+ version(stdout);
+ return 0;
+ case 'B': /* Do not output BSP configuration header file */
+ output_bspheader = 0;
+ break;
+ case 'b': /* Output BSP configuration header file */
+ bspheader_filename = optarg;
+ output_bspheader = output_order;
+ output_order--;
+ break;
+ case 'L': /* Do not output linker script */
+ output_linkcmds = 0;
+ break;
+ case 'l': /* Output linker script */
+ linkcmds_filename = optarg;
+ output_linkcmds = output_order;
+ output_order--;
+ break;
+ case 'P': /* Do not output PTF contents */
+ output_parsed = 0;
+ break;
+ case 'p': /* Output PTF contents as long list */
+ parsed_filename = optarg;
+ output_parsed = output_order;
+ output_order--;
+ break;
+ case 0:
+ case '?':
+ return -1;
+ default:
+ fprintf(stderr, NIOS2GEN_PACKAGE ": unknown option: %c\n", c);
+ if(optind >= argc)
+ usage(stderr,"No PTF specified!\n");
+ return -1;
+ sopc = ptf_parse_file(argv[optind]);
+ if(sopc == NULL)
+ fprintf(stderr, "Could not parse system description PTF '%s'.\n", argv[optind]);
+ return -1;
+ if(verbose) printf("Successfully read SOPC PTF file %s.\n", argv[optind]);
+ cfg = NULL;
+ for(optind++;optind<argc;optind++)
+ struct ptf *morecfg = ptf_parse_file(argv[optind]);
+ if(morecfg == NULL)
+ fprintf(stderr, "Couldn't parse '%s'.\n", argv[optind]);
+ return -1;
+ if(verbose) printf("Successfully read config PTF file %s.\n", argv[optind]);
+ cfg = ptf_concat(cfg, morecfg);
+ /* Pull in include files specified in the configs; */
+ /* Only one level is read; included files are not */
+ /* checked for further INCLUDEs */
+ struct ptf include_item = { item, "INCLUDE", 0, 0, 0 };
+ struct ptf_item inc_file_spec = { 1, &include_item };
+ ptf_match(cfg, &inc_file_spec, read_include_file, NULL);
+ /* Find CPU */
+ if(verbose) printf("Looking for usable CPUs...\n");
+ /* Check if a CPU has been specified in the config PTF */
+ struct ptf cpu_def = { item, "CPU", 0, 0, 0 };
+ struct ptf_item cpu_spec = { 2, &modules, &cpu_def };
+ ptf_match(cfg, &cpu_spec, store_ptf_ptr, &cpu);
+ /* Look for CPUs in system description PTF */
+ int cpu_count;
+ struct ptf nios2_cpu_class = { item, "class", "altera_nios2", 0, 0 };
+ struct ptf_item class_spec = { 3, &system, &module, &nios2_cpu_class };
+ if(cpu) if(cpu->value) class_spec.item[1]->value = cpu->value;
+ cpu_count = ptf_match(sopc, &class_spec, store_ptf_parent, &cpu);
+ if(cpu_count > 1)
+ fprintf(stderr, "There is more than one CPU. Please specify the one\n");
+ fprintf(stderr, "you want to use with this BSP in your config file.\n");
+ fprintf(stderr, "The available CPUs are named as follows:\n");
+ ptf_match(sopc, &class_spec, printf_ptf_value, " %s\n");
+ return -1;
+ if(cpu_count == 0)
+ fprintf(stderr, "There is no NIOS2 cpu in the system.\n");
+ return -1;
+ if(verbose)
+ printf("Using NIOS II CPU '%s'.\n", cpu->value);
+ printf("Only modules mastered by this CPU are considered now.\n");
+ /* Find Bridges */
+ if(verbose) printf("Looking for bus bridges...\n");
+ bridges = find_bridges(sopc);
+ if(verbose)
+ if(bridges)
+ for(bbp = bridges; bbp; bbp=bbp->next)
+ printf("Found bridge: %s\n", bbp->mastered_by);
+ printf(" \\_%s\n", bbp->bridges_to);
+ else
+ printf("No bridges present.\n");
+ /* Find clocks */
+ if(verbose) printf("Looking for clock definitions...\n");
+ clocks = find_clocks(sopc, cfg);
+ if(verbose)
+ if(clocks)
+ clock_desc *cs;
+ for(cs = clocks; cs; cs = cs->next)
+ printf("Found clock \"%s\" (%lu Hz), naming it %s\n", cs->name, cs->freq, cs->cfgname);
+ else
+ printf("No clocks present.\n");
+ /* Find other devices available to the selected CPU */
+ if(verbose) printf("Looking for devices...\n");
+ devices = find_devices(sopc, cfg, cpu, bridges);
+ if(verbose)
+ if(devices)
+ device_desc *dd;
+ printf("Found device \"%s\", naming it %s\n", dd->ptf->value, dd->cfgname);
+ else
+ printf("No devices present.\n");
+ /* Find out which devices are actually memory */
+ if(verbose) printf("Looking for memory...\n");
+ memory = find_memory(devices);
+ if(verbose)
+ if(memory)
+ memory_desc *md;
+ for(md = memory; md; md=md->next)
+ printf("Found memory in \"%s\", base=0x%08X, size=%lu bytes\n",
+ md->dev->cfgname,
+ md->base, md->size);
+ else
+ printf("None of the devices seems to provide memory?!\n");
+ /* Output files in the order they were specified
+ on the command line */
+ int i;
+ for(i=0;i<3;i++)
+ if(output_bspheader>0
+ && output_bspheader>=output_linkcmds
+ && output_bspheader>=output_parsed)
+ if(bspheader_filename == NULL || (bspheader_filename[0]=='-' && bspheader_filename[1]==0))
+ fwrite_header_file(stdout, cfg, devices, clocks);
+ else
+ FILE *f = fopen(bspheader_filename, "w");
+ if(!f)
+ perror(bspheader_filename);
+ return -1;
+ else
+ fwrite_header_file(f, cfg, devices, clocks);
+ fclose(f);
+ if(output_linkcmds>0
+ && output_linkcmds>=output_bspheader
+ && output_linkcmds>=output_parsed)
+ if(linkcmds_filename == NULL || (linkcmds_filename[0]=='-' && linkcmds_filename[1]==0))
+ fwrite_linkcmds_file(stdout, cfg, cpu, devices, memory);
+ else
+ FILE *f = fopen(linkcmds_filename, "w");
+ if(!f)
+ perror(linkcmds_filename);
+ return -1;
+ else
+ fwrite_linkcmds_file(f, cfg, cpu, devices, memory);
+ fclose(f);
+ if(output_parsed>0
+ && output_parsed>=output_linkcmds
+ && output_parsed>=output_bspheader)
+ if(parsed_filename == NULL || (parsed_filename[0]=='-' && parsed_filename[1]==0))
+ ptf_printf(stdout, sopc, "");
+ else
+ FILE *f = fopen(parsed_filename, "w");
+ if(!f)
+ perror(parsed_filename);
+ return -1;
+ else
+ ptf_printf(f, sopc, "");
+ fclose(f);
+ if(verbose) printf("Done.\n");
+ return 0;
+/* vi:ts=4:
diff --git a/misc/nios2gen/output.c b/misc/nios2gen/output.c
index 0000000..088ebe8
--- /dev/null
+++ b/misc/nios2gen/output.c
@@ -0,0 +1,193 @@
+#include <stdio.h>
+#include "ptf.h"
+typedef struct
+ FILE *file;
+ device_desc *dev;
+ char *def_name;
+ char *orig_value;
+out_desc;
+int is_not_connected(struct ptf_item *pi)
+ if(pi->item[0] == NULL) return 0;
+ if(pi->item[0]->name == NULL) return 0;
+ if(strcmp(pi->item[0]->name, "SLAVE") == 0)
+ struct ptf *t;
+ struct ptf_item ti;
+ t = ptf_find(pi->item[0]->sub, &ti, item, "N2G_Selected", "1");
+ if(t == NULL) return 1;
+ return 0;
+void fwrite_devhead_def(struct ptf_item *pi, void *arg)
+ out_desc *dinfo = arg;
+ if(pi != NULL) if(is_not_connected(pi)) return;
+ fprintf(dinfo->file, "#define %s_%s %s\n",
+ dinfo->dev->cfgname, dinfo->def_name, dinfo->orig_value);
+void fwrite_devhead_line(struct ptf_item *pi, void *arg)
+ if(is_not_connected(pi)) return;
+ if(strncmp(dinfo->orig_value, "N2G_", 4)==0)
+ if(strncmp(dinfo->orig_value, "N2G_CLOCKREF_", 13)==0)
+ clock_desc *c;
+ for(c = dinfo->clocks; c; c=c->next)
+ if(strcmp(c->name, pi->item[pi->level]->value) == 0)
+ dinfo->dev->cfgname, dinfo->orig_value + 13, c->cfgname);
+ break;
+ else if(strncmp(dinfo->orig_value, "N2G_DEVICEREF_", 14)==0)
+ device_desc *d;
+ for(d = dinfo->devices; d; d=d->next)
+ if(strcmp(d->ptf->value, pi->item[pi->level]->value) == 0)
+ dinfo->dev->cfgname, dinfo->orig_value + 14, d->cfgname);
+ break;
+ else
+ dinfo->dev->cfgname, dinfo->orig_value,
+ pi->item[pi->level]->value);
+void fwrite_device_header(struct ptf_item *pi, void *arg)
+ struct ptf *f;
+ struct ptf_item fi;
+ /* This is called for every matching CLASS section in the
+ configuration. The following loop iterates through all
+ items in the CLASS section regardless of their nesting level */
+ f = ptf_find(pi->item[pi->level]->sub, &fi, item, 0, 0);
+ while(f != NULL)
+ dinfo->orig_value = f->value;
+ if(f->name && strncmp(f->name, "N2G_DEFINE_", 11)==0)
+ dinfo->def_name = f->name + 11;
+ if(fi.level >= 2)
+ fi.level--; /* match only the enclosing section */
+ ptf_match(dinfo->dev->ptf->sub, &fi, fwrite_devhead_def, dinfo);
+ fi.level++;
+ else
+ fwrite_devhead_def( 0, dinfo );
+ else
+ f->value = 0; /* Match ANY value */
+ ptf_match(dinfo->dev->ptf->sub, &fi, fwrite_devhead_line, dinfo);
+ f->value = dinfo->orig_value;
+ f = ptf_next(&fi, item, 0, 0);
+void fwrite_value(struct ptf_item *pi, void *arg)
+ FILE *file = arg;
+ fputs(pi->item[pi->level]->value, file);
+void fwrite_header_file( FILE *file, struct ptf *cfg, device_desc *devices, clock_desc *clocks)
+ struct ptf *p;
+ struct ptf aclass = { section, "CLASS", 0, 0, 0 };
+ struct ptf_item matchaclass = { 1, &aclass };
+ struct ptf bspsect = { section, "BSPHEADER", 0, 0, 0 };
+ struct ptf leadtext = { item, "LEADTEXT", 0, 0, 0 };
+ struct ptf_item matchleadtext = { 2, &bspsect, &leadtext };
+ struct ptf epilog = { item, "EPILOG", 0, 0, 0 };
+ struct ptf_item matchepilog = { 2, &bspsect, &epilog };
+ out_desc dinfo;
+ dinfo.file = file;
+ dinfo.clocks = clocks;
+ dinfo.devices = devices;
+ ptf_match(cfg, &matchleadtext, fwrite_value, file);
+ if(clocks)
+ clock_desc *cs;
+ fprintf(file, "#define %s_FREQ %luu\n", cs->cfgname, cs->freq);
+ if(devices)
+ for(dinfo.dev = devices; dinfo.dev; dinfo.dev=dinfo.dev->next)
+ /* fprintf(file, "\n#define SOPC_HAS_%s 1\n", dinfo.dev->cfgname); */
+ p = ptf_find(dinfo.dev->ptf, &pi, item, "class", 0);
+ if(p)
+ aclass.value = p->value;
+ ptf_match(cfg, &matchaclass, fwrite_device_header, &dinfo);
+ ptf_match(cfg, &matchepilog, fwrite_value, file);
diff --git a/misc/nios2gen/output.h b/misc/nios2gen/output.h
index 0000000..80a9bb0
--- /dev/null
+++ b/misc/nios2gen/output.h
@@ -0,0 +1,25 @@
+#ifndef __OUTPUT_H
+#define __OUTPUT_H 1
+#include <stdio.h>
+#include "ptf.h"
+void fwrite_value(struct ptf_item *pi, void *arg);
+void fwrite_header_file(FILE *file, struct ptf *cfg, device_desc *devices, clock_desc *clocks);
+#endif
diff --git a/misc/nios2gen/ptf.c b/misc/nios2gen/ptf.c
index 0000000..07d6183
--- /dev/null
+++ b/misc/nios2gen/ptf.c
@@ -0,0 +1,857 @@
+#include <stdio.h>
+#include <errno.h>
+#include <ctype.h>
+#include "ptf.h"
+#define PTFPARSER_MAXDEPTH 20
+#define PTFPARSER_NAMEBUFSIZE 1024
+#define PTFPARSER_VALUEBUFSIZE 4096
+#define DEBUG_EXPECTATIONS 1
+#define DEBUG_READVALUES 2
+#define DEBUG_FINDER 4
+#define DEBUG 0
+struct ptf_parser_state
+ struct ptf *tree;
+ struct ptf *current_in[PTFPARSER_MAXDEPTH];
+ struct ptf *current_item;
+ long line; /* starts with 1, increments whenever a LF (ASCII 10) passes */
+ int section_level; /* starts at 0, incremented at {, decremented at } */
+ char *filename;
+ char name_buffer[PTFPARSER_NAMEBUFSIZE];
+ int name_length;
+ char value_buffer[PTFPARSER_VALUEBUFSIZE];
+ int value_length;
+ struct
+ unsigned error:1;
+ unsigned escaped:1;
+ unsigned single_quoted:1;
+ unsigned double_quoted:1;
+ } flag;
+ enum
+ section_or_item_specification,
+ more_section_type_or_item_name_chars,
+ whitespace_after_section_specification,
+ whitespace_after_section_or_item_name,
+ whitespace_before_item_value,
+ more_section_name_chars,
+ more_item_value_chars,
+ } expectation;
+struct ptf *ptf_alloc_item(ptf_item_type t, char *name, char *value)
+ struct ptf *new_item;
+ new_item = (struct ptf *)malloc(sizeof(struct ptf));
+ if(!new_item) return NULL;
+ new_item->type = t;
+ new_item->sub = NULL;
+ new_item->next = NULL;
+ new_item->name = NULL;
+ new_item->value = NULL;
+ if(name != NULL)
+ int n = strlen(name);
+ if(n > 0)
+ new_item->name = (char *)malloc(n + 1);
+ if(new_item->name == NULL)
+ free(new_item);
+ return NULL;
+ strcpy(new_item->name, name);
+ if(value != NULL)
+ int n = strlen(value);
+ if(n > 0)
+ new_item->value = (char *)malloc(n + 1);
+ if(new_item->value == NULL)
+ if(name != NULL) free(new_item->name);
+ free(new_item);
+ return NULL;
+ strcpy(new_item->value, value);
+ return new_item;
+void add_ptf_item(struct ptf_parser_state *state, struct ptf *item)
+ if(state->current_item == NULL)
+ if(state->section_level > 0)
+ state->current_in[state->section_level-1]->sub = item;
+ else
+ state->tree = item;
+ else
+ state->current_item->next = item;
+void parse_error(struct ptf_parser_state *state, char *errmsg)
+ fprintf(stderr, "Error while parsing %s (line %lu): %s\n",
+ state->filename, state->line, errmsg);
+ state->flag.error = 1;
+void init_parser(struct ptf_parser_state *state, char *filename)
+ int i;
+ state->line = 1;
+ state->flag.error = 0;
+ state->flag.escaped = 0;
+ state->flag.double_quoted = 0;
+ state->flag.single_quoted = 0;
+ state->section_level = 0;
+ state->filename = (char *)malloc(strlen(filename)+1);
+ if(state->filename != NULL) strcpy(state->filename, filename);
+ state->expectation = section_or_item_specification;
+ state->tree = NULL;
+ state->current_item = NULL;
+ for(i=1; i<PTFPARSER_MAXDEPTH; i++) state->current_in[i] = NULL;
+void ptf_free(struct ptf *ptf)
+ struct ptf *this, *next;
+ for(this = ptf; this != NULL; this = next)
+ next = this->next;
+ if(this->value != NULL) free(this->value);
+ if(this->name != NULL) free(this->name);
+ if(this->type == section) ptf_free(this->sub);
+ free(this);
+void abort_parsing(struct ptf_parser_state *state)
+ if(state->filename != NULL) free(state->filename);
+ ptf_free(state->tree);
+int add_char_to_buffer(int *len, char *buf, int maxlen, char c)
+ if(*len >= maxlen) return 0;
+ buf[(*len)++] = c;
+ return 1;
+void parse_char(struct ptf_parser_state *state, int c)
+ int is_not_quoted;
+ int is_no_space;
+ enum { item_parsed, section_opened, section_closed, none } parser_event;
+ switch(c)
+ case '\\':
+ if(state->flag.escaped == 0)
+ state->flag.escaped = 1;
+ return;
+ break;
+ case '"':
+ if(!state->flag.escaped && !state->flag.single_quoted)
+ state->flag.double_quoted = 1 - state->flag.double_quoted;
+ return;
+ break;
+ case '\'':
+ if(!state->flag.escaped && !state->flag.double_quoted)
+ state->flag.single_quoted = 1 - state->flag.single_quoted;
+ return;
+ break;
+ case '\n':
+ state->line++;
+ break;
+ default:
+ break;
+ parser_event = none;
+ is_not_quoted = !(state->flag.escaped ||
+ state->flag.single_quoted || state->flag.double_quoted);
+ is_no_space = (!is_not_quoted || !isspace(c));
+ switch(state->expectation)
+ case section_or_item_specification:
+#if DEBUG&DEBUG_EXPECTATIONS
+ printf("Expectation: section_or_item_specification\n");
+#endif
+ if(is_not_quoted && c == '}')
+ parser_event = section_closed;
+ else if(is_no_space)
+ state->name_length = 1;
+ state->name_buffer[0] = c;
+ state->expectation = more_section_type_or_item_name_chars;
+ break;
+ case more_section_type_or_item_name_chars:
+ printf("Expectation: more_section_type_or_item_name_chars\n");
+#endif
+ /* Item name is stored in name_buffer */
+ /* Section type is stored in name_buffer */
+ if(is_no_space)
+ if(!add_char_to_buffer(&state->name_length, state->name_buffer, PTFPARSER_NAMEBUFSIZE, c))
+ parse_error(state, "First word is too long; I expected a shorter section type or item name");
+ else
+ state->expectation = whitespace_after_section_or_item_name;
+ break;
+ case whitespace_after_section_specification:
+ printf("Expectation: whitespace_after_section_specification\n");
+#endif
+ if(c == '{')
+ parser_event = section_opened;
+ parse_error(state, "Expected section content within brackets {...}");
+ break;
+ case whitespace_after_section_or_item_name:
+ printf("Expectation: whitespace_after_section_or_item_name\n");
+#endif
+ if(c == '{')
+ state->value_length = 0;
+ else if(c == '=')
+ state->expectation = whitespace_before_item_value;
+ state->value_length = 1;
+ state->value_buffer[0] = c;
+ state->expectation = more_section_name_chars;
+ break;
+ case more_section_name_chars:
+ printf("Expectation: more_section_name_chars\n");
+#endif
+ /* Section name is stored in value_buffer */
+ if(is_no_space)
+ if(!add_char_to_buffer(&state->value_length, state->value_buffer, PTFPARSER_VALUEBUFSIZE, c))
+ parse_error(state, "Section name is too long");
+ else
+ state->expectation = whitespace_after_section_specification;
+ break;
+ case whitespace_before_item_value:
+ printf("Expectation: whitespace_before_item_value\n");
+#endif
+ if(is_not_quoted && c == ';')
+ parser_event = item_parsed;
+ state->expectation = more_item_value_chars;
+ break;
+ case more_item_value_chars:
+ printf("Expectation: more_item_value_chars\n");
+#endif
+ /* Item value is stored in value_buffer */
+ parse_error(state, "Item value is too long");
+ else
+ break;
+ default:
+ printf("Expectation: %d (?)\n", state->expectation);
+#endif
+ parse_error(state, "Internal error: Unhandled state of expectation");
+ switch(parser_event)
+ /* TODO: pointer tuff */
+ case item_parsed:
+ state->name_buffer[state->name_length] = 0;
+ state->value_buffer[state->value_length] = 0;
+#if DEBUG&DEBUG_READVALUES
+ printf("== Item %s is '%s' ==\n", state->name_buffer, state->value_buffer);
+#endif
+ new_item = ptf_alloc_item(item, state->name_buffer, state->value_buffer);
+ if(new_item == NULL)
+ parse_error(state, "Internal error: "
+ "Could not allocate memory for new item");
+ return;
+ add_ptf_item(state, new_item);
+ state->current_item = new_item;
+ break;
+ case section_opened:
+ struct ptf *new_section;
+ printf("== New %s section '%s' opened ==\n", state->name_buffer, state->value_buffer);
+#endif
+ if(state->section_level >= PTFPARSER_MAXDEPTH-1)
+ "cannot handle sections nested as deep as here.");
+ return;
+ new_section = ptf_alloc_item(section, state->name_buffer, state->value_buffer);
+ if(new_section == NULL)
+ "Could not allocate memory for new section");
+ return;
+ add_ptf_item(state, new_section);
+ state->current_in[state->section_level] = new_section;
+ state->section_level++;
+ break;
+ case section_closed:
+ if(state->section_level < 1)
+ parse_error(state, "Found closing '}' without opening '{' before");
+ return;
+ state->section_level--;
+ state->current_item = state->current_in[state->section_level];
+ printf("-- Closed section --\n");
+#endif
+ break;
+ default:
+ break;
+struct ptf *ptf_parse_file(char *filename)
+ FILE *f;
+ char buffer[1024];
+ struct ptf *root;
+ struct ptf_parser_state state;
+ if(filename == NULL)
+ fprintf(stderr, "Internal error: "
+ "No filename was given to ptf_read()\n");
+ return NULL;
+ f = fopen(filename, "r");
+ if(f == NULL)
+ perror(filename);
+ return NULL;
+ init_parser(&state, filename);
+ while(!feof(f))
+ size_t r, n;
+ if(ferror(f))
+ perror(filename);
+ abort_parsing(&state);
+ fclose(f);
+ return NULL;
+ n = fread(buffer, 1, 1024, f);
+ for(r=0; r<n && (state.flag.error==0); r++) parse_char(&state, buffer[r]);
+ fclose(f);
+ if(state.section_level != 0)
+ parse_error(&state, "Input file seems to be incomplete, "
+ "one or more sections are not closed with '}'\n");
+ if(state.flag.error)
+ return NULL;
+ return state.tree;
+struct ptf *ptf_concat(struct ptf *a, struct ptf *b)
+ struct ptf *leaf = a;
+ if(!a) return b;
+ if(!b) return a;
+ for(leaf = a; leaf->next != NULL; leaf = leaf->next);
+ leaf->next = b;
+ return a;
+void ptf_dump_ptf_item(FILE *f, struct ptf_item *pi)
+ int i;
+ fprintf(f, "level=%d in %p\n", pi->level, pi);
+ for(i=pi->level;i>=0;i--)
+ if(pi->item[i] != NULL)
+ fprintf(f, " %d: %s name=%s value=%s\n",
+ i,
+ pi->item[i]->type == item ? "item":"section",
+ pi->item[i]->name,
+ pi->item[i]->value);
+ else
+ fprintf(f, " %d: NULL\n", i);
+ fflush(f);
+void ptf_printf(FILE *s, struct ptf *tree, char *prefix)
+ struct ptf *leaf;
+ for(leaf = tree; leaf != NULL; leaf = leaf->next)
+ switch(leaf->type)
+ case section:
+ char *new_prefix;
+ int new_prefix_len;
+ new_prefix_len = strlen(prefix) + strlen(leaf->name) + 2;
+ if(leaf->value != NULL && leaf->value[0] != 0)
+ new_prefix_len += strlen(leaf->value) + 1;
+ new_prefix = (char *)malloc(new_prefix_len);
+ if (new_prefix != NULL)
+ strcpy(new_prefix, prefix);
+ strcat(new_prefix, leaf->name);
+ strcat(new_prefix, ":");
+ strcat(new_prefix, leaf->value);
+ strcat(new_prefix, "/");
+ fputs(new_prefix, s);
+ fputs("\n", s);
+ ptf_printf(s, leaf->sub, new_prefix);
+ free(new_prefix);
+ break;
+ case item:
+ char *c;
+ fputs(prefix, s);
+ fputs(leaf->name, s);
+ fputs(" = \"", s);
+ if(leaf->value == NULL)
+ fputs("(NULL)", s);
+ else
+ for(c=leaf->value; *c; c++)
+ if(*c=='\\' || *c=='"') putc('\\', s);
+ putc(*c, s);
+ fprintf(s, "\"\n");
+ break;
+ default:
+ break;
+int ptf_advance_one(struct ptf_item *item)
+ int d;
+ struct ptf *leaf;
+ d = item->level;
+ leaf = item->item[d];
+ if(leaf != NULL)
+ if(leaf->type == section && leaf->sub != NULL)
+ if(item->level >= MAX_SECTION_NESTING-1)
+ /* raise an error? hm, for now we silently ignore the subtree */
+ else
+ d++;
+ item->item[d] = leaf->sub;
+ item->level = d;
+ return 0;
+ item->item[item->level] = leaf->next;
+ while(item->item[d] == NULL)
+ if(d == 0)
+ item->level = 0;
+ item->item[0] = NULL;
+ errno = ENOENT;
+ return -1;
+ d --;
+ if(leaf != NULL) item->item[d] = leaf->next;
+ item->level = d;
+ return 0;
+int ptf_advance_until(
+ struct ptf_item *item,
+ ptf_item_type ttype,
+ char *name,
+ char *value)
+ int r;
+ struct ptf *leaf;
+ do
+ leaf = item->item[item->level];
+#if DEBUG&DEBUG_FINDER
+ printf(" Does %s/%s match %s/%s?\n", leaf->name, leaf->value, name, value);
+#endif
+ if(leaf->type == ttype)
+ if(name == NULL)
+ if(value == NULL)
+ return 0; /* got it (any value) */
+ else if (leaf->value != NULL)
+ if(strcmp(leaf->value, value) == 0) return 0; /* got it */
+ else if(leaf->name != NULL)
+ if(strcmp(leaf->name, name) == 0)
+ if(value == NULL)
+ else if(leaf->value != NULL)
+ r = ptf_advance_one(item);
+ } while(r == 0);
+ return r;
+struct ptf *ptf_find(
+ struct ptf *tree,
+ char *name,
+ char *value)
+ int r;
+ if(item == NULL) { errno = EINVAL; return NULL; };
+ if(tree == NULL) { errno = ENOENT; return NULL; };
+ item->level = 0;
+ item->item[0] = tree;
+ if(ptf_advance_until(item, ttype, name, value) != 0) return NULL;
+ r = item->level;
+ item->level++; /* To match ptf_match */
+ return item->item[r];
+struct ptf *ptf_next(
+ char *name,
+ char *value)
+ int r;
+ struct ptf *leaf;
+ if(item->level < 1) return NULL;
+ item->level--; /* To match ptf_match */
+ if(r == 0) r = ptf_advance_until(item, ttype, name, value);
+ if(r != 0) return NULL;
+ r = item->level;
+int ptf_match(
+ struct ptf *const ptf,
+ struct ptf_item *const match,
+ const ptf_match_action action,
+ void *arg)
+ int count;
+ struct ptf *p;
+ p = ptf;
+ count = 0;
+ pi.level = 0;
+ while(p != NULL)
+ ptf_item_type mtype = match->item[pi.level]->type;
+ char *mname = match->item[pi.level]->name;
+ char *mvalue = match->item[pi.level]->value;
+ printf("Looking for %s/%s, checking %s/%s\n",
+ mname, mvalue, p->name, p->value);
+#endif
+ if(mtype == p->type &&
+ (mname==NULL || p->name==NULL || strcmp(mname, p->name)==0) &&
+ (mvalue==NULL || p->value==NULL || strcmp(mvalue, p->value)==0))
+ pi.item[pi.level] = p;
+ if(pi.level == match->level - 1)
+ if(action != NULL) action(&pi, arg);
+ p = p->next;
+ count++;
+ else
+ if(p->sub != NULL && pi.level < MAX_SECTION_NESTING-1)
+ pi.level++;
+ p = p->sub;
+ else
+ p = p->next;
+ else
+ p = p->next;
+ while(p == NULL && pi.level > 0)
+ pi.level--;
+ p = pi.item[pi.level]->next;
+ return count;
+char *ptf_defused_name(char *orig_name)
+ int i,j;
+ char *s = (char *)malloc(1+strlen(orig_name));
+ if(!s) return NULL;
+ for(i=j=0;orig_name[i];i++)
+ if(!isalnum(orig_name[i]))
+ if(j>0) if(s[j-1]!='_') s[j++]='_';
+ else
+ s[j++] = toupper(orig_name[i]);
+ s[j] = 0;
+ return s;
diff --git a/misc/nios2gen/ptf.h b/misc/nios2gen/ptf.h
index 0000000..b1c181b
--- /dev/null
+++ b/misc/nios2gen/ptf.h
@@ -0,0 +1,69 @@
+#if !defined(__PTF_H)
+#define __PTF_H 1
+#include <stdio.h>
+#define MAX_SECTION_NESTING 20
+typedef enum
+ item, section
+ptf_item_type;
+struct ptf
+ ptf_item_type type;
+ char *name;
+ char *value;
+ struct ptf *sub;
+ struct ptf *next;
+struct ptf_item
+ int level;
+ struct ptf *item[MAX_SECTION_NESTING];
+typedef void (*ptf_match_action)(struct ptf_item *x, void *arg);
+struct ptf *ptf_parse_file(char *filename);
+struct ptf *ptf_concat(struct ptf *a, struct ptf *b);
+struct ptf *ptf_alloc_item(ptf_item_type t, char *name, char *value);
+void ptf_printf(FILE *s, struct ptf *tree, char *prefix);
+void ptf_dump_ptf_item(FILE *s, struct ptf_item *pi);
+ struct ptf *tree,
+ char *name,
+ char *value);
+ char *name,
+ char *value);
+int ptf_match(
+ void *arg);
+char *ptf_defused_name(char *);
+#endif /* !defined(__PTF_H) */
diff --git a/misc/nios2gen/sample.ptf b/misc/nios2gen/sample.ptf
index 0000000..eb4cf7f
--- /dev/null
+++ b/misc/nios2gen/sample.ptf
@@ -0,0 +1,462 @@
+N2GCOMM = "=============== Header output settings ===========================";
+BSPHEADER
+ LEADTEXT =
+"/* Autogenerated by nios2gen, (C) 2006 K. Waschk rtemsdev/ixo.de */
+#ifndef __SOPC_H
+#define __SOPC_H 1
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define CLOCK_FREQ_REF(clock) clock ## _FREQ
+#define CLOCK_FREQ(x) CLOCK_FREQ_REF(x)
+ EPILOG =
+#ifdef __cplusplus
+#endif
+#endif
+N2GCOMM = "=============== Class templates ==================================";
+CLASS altera_nios2
+ N2G_DEFINE_IS_AVAILABLE = "1";
+ Clock_Source = "N2G_CLOCKREF_CLOCK";
+ SLAVE jtag_debug_module
+ SYSTEM_BUILDER_INFO { Base_Address = "BASE_ADDR"; }
+ WIZARD_SCRIPT_ARGUMENTS
+ cache_has_dcache = "HAS_DCACHE";
+ cache_has_icache = "HAS_ICACHE";
+ cache_dcache_size = "DCACHE_SIZE";
+ cache_icache_size = "ICACHE_SIZE";
+ cache_dcache_line_size = "DCACHE_LINE_SIZE";
+ cache_icache_line_size = "ICACHE_LINE_SIZE";
+ cache_dcache_bursts = "DCACHE_BURSTS";
+ cache_icache_burst_type = "ICACHE_BURST_TYPE";
+ hardware_multiply_present = "HAS_HWMULT";
+CLASS altera_avalon_onchip_memory2
+ Writeable = "WRITEABLE";
+ dual_port = "DUAL_PORT";
+ Size_Value = "SIZE_VALUE";
+ Size_Multiple = "SIZE_MULTIPLE";
+ SLAVE s1
+ N2G_DEFINE_CONNECTED_PORT = "S1";
+ Base_Address = "S1_BASE_ADDR";
+ Data_Width = "S1_DATA_WIDTH";
+ Address_Width = "S1_ADDR_WIDTH";
+ Address_Span = "S1_ADDR_SPAN";
+ SLAVE s2
+ N2G_DEFINE_CONNECTED_PORT = "S2";
+ Base_Address = "S2_BASE_ADDR";
+ Data_Width = "S2_DATA_WIDTH";
+ Address_Width = "S2_ADDR_WIDTH";
+ Address_Span = "S2_ADDR_SPAN";
+CLASS sram_256k_x_16_bit
+ SLAVE sram
+ Data_Width = "DATA_WIDTH";
+ Address_Width = "ADDR_WIDTH";
+ Address_Span = "ADDR_SPAN";
+CLASS altera_avalon_sysid
+ SLAVE control_slave
+ id = "ID";
+ timestamp = "TIMESTAMP";
+CLASS altera_avalon_timer
+ SLAVE s1
+ snapshot = "SNAPSHOT";
+ always_run = "ALWAYS_RUN";
+ mult = "MULT";
+ period = "PERIOD";
+ period_units = "PERIOD_UNITS";
+ fixed_period = "FIXED_PERIOD";
+CLASS altera_avalon_uart
+ use_cts_rts = "USE_CTS_RTS";
+ use_eop_register = "USE_EOP_REG";
+ SLAVE s1
+CLASS altera_avalon_jtag_uart
+CLASS altera_avalon_pio
+ SLAVE
+N2GCOMM = "=============== Linkcmds output settings =========================";
+LINKCMDS
+ LEADTEXT = "
+OUTPUT_FORMAT( "elf32-littlenios2",
+ "elf32-littlenios2",
+ "elf32-littlenios2" )
+OUTPUT_ARCH( nios2 )
+ENTRY( _start )
+ SECTION entry
+ COMMANDS =
+" KEEP (*(.entry))
+ SECTION exceptions
+ COMMANDS =
+" PROVIDE (__ram_exceptions_start = ABSOLUTE(.));
+ . = ALIGN(0x20);
+ *(.irq)
+ KEEP (*(.exceptions.entry.label));
+ KEEP (*(.exceptions.entry.user));
+ KEEP (*(.exceptions.entry));
+ KEEP (*(.exceptions.irqtest.user));
+ KEEP (*(.exceptions.irqtest));
+ KEEP (*(.exceptions.irqhandler.user));
+ KEEP (*(.exceptions.irqhandler));
+ KEEP (*(.exceptions.irqreturn.user));
+ KEEP (*(.exceptions.irqreturn));
+ KEEP (*(.exceptions.notirq.label));
+ KEEP (*(.exceptions.notirq.user));
+ KEEP (*(.exceptions.notirq));
+ KEEP (*(.exceptions.soft.user));
+ KEEP (*(.exceptions.soft));
+ KEEP (*(.exceptions.unknown.user));
+ KEEP (*(.exceptions.unknown));
+ KEEP (*(.exceptions.exit.label));
+ KEEP (*(.exceptions.exit.user));
+ KEEP (*(.exceptions.exit));
+ KEEP (*(.exceptions));
+ PROVIDE (__ram_exceptions_end = ABSOLUTE(.));
+ SECTION text
+ LOCATION = "SDRAM";
+ COMMANDS =
+" PROVIDE (stext = ABSOLUTE(.));
+ *(.interp)
+ *(.hash)
+ *(.dynsym)
+ *(.dynstr)
+ *(.gnu.version)
+ *(.gnu.version_d)
+ *(.gnu.version_r)
+ *(.rel.init)
+ *(.rela.init)
+ *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
+ *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
+ *(.rel.fini)
+ *(.rela.fini)
+ *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
+ *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
+ *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
+ *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
+ *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
+ *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
+ *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
+ *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
+ *(.rel.ctors)
+ *(.rela.ctors)
+ *(.rel.dtors)
+ *(.rela.dtors)
+ *(.rel.got)
+ *(.rela.got)
+ *(.rel.sdata .rel.sdata.* .rel.gnu.linkonce.s.*)
+ *(.rela.sdata .rela.sdata.* .rela.gnu.linkonce.s.*)
+ *(.rel.sbss .rel.sbss.* .rel.gnu.linkonce.sb.*)
+ *(.rela.sbss .rela.sbss.* .rela.gnu.linkonce.sb.*)
+ *(.rel.sdata2 .rel.sdata2.* .rel.gnu.linkonce.s2.*)
+ *(.rela.sdata2 .rela.sdata2.* .rela.gnu.linkonce.s2.*)
+ *(.rel.sbss2 .rel.sbss2.* .rel.gnu.linkonce.sb2.*)
+ *(.rela.sbss2 .rela.sbss2.* .rela.gnu.linkonce.sb2.*)
+ *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
+ *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
+ *(.rel.plt)
+ *(.rela.plt)
+ KEEP (*(.init))
+ *(.plt)
+ *(.text .stub .text.* .gnu.linkonce.t.*)
+ /* Special FreeBSD sysctl sections. */
+ . = ALIGN (16);
+ __start_set_sysctl_set = .;
+ *(set_sysctl_*);
+ __stop_set_sysctl_set = ABSOLUTE(.);
+ *(set_domain_*);
+ *(set_pseudo_*);
+ *(.gnu.warning.*)
+ KEEP (*(.fini))
+ PROVIDE (__etext = ABSOLUTE(.));
+ PROVIDE (_etext = ABSOLUTE(.));
+ PROVIDE (etext = ABSOLUTE(.));
+ *(.eh_frame_hdr)
+ /* Ensure the __preinit_array_start label is properly aligned. We
+ could instead move the label definition inside the section, but
+ the linker would then create the section even if it turns out to
+ be empty, which isn't pretty. */
+ . = ALIGN(32 / 8);
+ PROVIDE (__preinit_array_start = ABSOLUTE(.));
+ *(.preinit_array)
+ PROVIDE (__preinit_array_end = ABSOLUTE(.));
+ PROVIDE (__init_array_start = ABSOLUTE(.));
+ *(.init_array)
+ PROVIDE (__init_array_end = ABSOLUTE(.));
+ PROVIDE (__fini_array_start = ABSOLUTE(.));
+ *(.fini_array)
+ PROVIDE (__fini_array_end = ABSOLUTE(.));
+ SORT(CONSTRUCTORS)
+ KEEP (*(.eh_frame))
+ *(.gcc_except_table)
+ *(.dynamic)
+ PROVIDE (__CTOR_LIST__ = ABSOLUTE(.));
+ KEEP (*(.ctors))
+ KEEP (*(SORT(.ctors.*)))
+ PROVIDE (__CTOR_END__ = ABSOLUTE(.));
+ PROVIDE (__DTOR_LIST__ = ABSOLUTE(.));
+ KEEP (*(.dtors))
+ KEEP (*(SORT(.dtors.*)))
+ PROVIDE (__DTOR_END__ = ABSOLUTE(.));
+ KEEP (*(.jcr))
+ SECTION rodata
+ COMMANDS =
+" PROVIDE (__ram_rodata_start = ABSOLUTE(.));
+ *(.rodata .rodata.* .gnu.linkonce.r.*)
+ *(.rodata1)
+ PROVIDE (__ram_rodata_end = ABSOLUTE(.));
+ SECTION rwdata
+ COMMANDS =
+" PROVIDE (__ram_rwdata_start = ABSOLUTE(.));
+ *(.got.plt) *(.got)
+ *(.data1)
+ *(.data .data.* .gnu.linkonce.d.*)
+ _gp = ABSOLUTE(. + 0x8000);
+ PROVIDE(gp = _gp);
+ *(.sdata .sdata.* .gnu.linkonce.s.*)
+ *(.sdata2 .sdata2.* .gnu.linkonce.s2.*)
+ _edata = ABSOLUTE(.);
+ PROVIDE (edata = ABSOLUTE(.));
+ PROVIDE (__ram_rwdata_end = ABSOLUTE(.));
+ SECTION bss
+ COMMANDS =
+" __bss_start = ABSOLUTE(.);
+ PROVIDE (__sbss_start = ABSOLUTE(.));
+ PROVIDE (___sbss_start = ABSOLUTE(.));
+ *(.dynsbss)
+ *(.sbss .sbss.* .gnu.linkonce.sb.*)
+ *(.sbss2 .sbss2.* .gnu.linkonce.sb2.*)
+ *(.scommon)
+ PROVIDE (__sbss_end = ABSOLUTE(.));
+ PROVIDE (___sbss_end = ABSOLUTE(.));
+ *(.dynbss)
+ *(.bss .bss.* .gnu.linkonce.b.*)
+ *(COMMON)
+ __bss_end = ABSOLUTE(.);
+ STABS =
+" .stab 0 : { *(.stab) }
+ .stabstr 0 : { *(.stabstr) }
+ .stab.excl 0 : { *(.stab.excl) }
+ .stab.exclstr 0 : { *(.stab.exclstr) }
+ .stab.index 0 : { *(.stab.index) }
+ .stab.indexstr 0 : { *(.stab.indexstr) }
+ .comment 0 : { *(.comment) }
+ /* DWARF debug sections.
+ Symbols in the DWARF debugging sections are relative to the beginning
+ of the section so we begin them at 0. */
+ /* DWARF 1 */
+ .debug 0 : { *(.debug) }
+ .line 0 : { *(.line) }
+ /* GNU DWARF 1 extensions */
+ .debug_srcinfo 0 : { *(.debug_srcinfo) }
+ .debug_sfnames 0 : { *(.debug_sfnames) }
+ /* DWARF 1.1 and DWARF 2 */
+ .debug_aranges 0 : { *(.debug_aranges) }
+ .debug_pubnames 0 : { *(.debug_pubnames) }
+ /* DWARF 2 */
+ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
+ .debug_abbrev 0 : { *(.debug_abbrev) }
+ .debug_line 0 : { *(.debug_line) }
+ .debug_frame 0 : { *(.debug_frame) }
+ .debug_str 0 : { *(.debug_str) }
+ .debug_loc 0 : { *(.debug_loc) }
+ .debug_macinfo 0 : { *(.debug_macinfo) }
+ /* SGI/MIPS DWARF 2 extensions */
+ .debug_weaknames 0 : { *(.debug_weaknames) }
+ .debug_funcnames 0 : { *(.debug_funcnames) }
+ .debug_typenames 0 : { *(.debug_typenames) }
+ .debug_varnames 0 : { *(.debug_varnames) }
+ /* Altera debug extensions */
+ .debug_alt_sim_info 0 : { *(.debug_alt_sim_info) }
+ HEAP = "SDRAM";
+ STACK = "SDRAM";
diff --git a/misc/wscript b/misc/wscript
index 0000000..2b1332e
--- /dev/null
+++ b/misc/wscript
@@ -0,0 +1,70 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2014-2016 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# RTEMS miscellaneous build script.
+import sys
+def init(ctx):
+ pass
+def options(opt):
+ opt.load('compiler_c')
+def configure(conf):
+ conf.load('compiler_c')
+ conf.write_config_header('config.h')
+def build(bld):
+ # The local configuration.
+ conf = {}
+ # Build flags.
+ conf['warningflags'] = ['-Wall', '-Wextra', '-pedantic']
+ conf['optflags'] = bld.env.C_OPTS
+ conf['cflags'] = ['-pipe', '-g'] + conf['optflags']
+ conf['linkflags'] = ['-g']
+ # The list of defines
+ defines = ['RTEMS_VERSION=\"%s\"' % (bld.env.RTEMS_VERSION),
+ 'RTEMS_RELEASE=\"%s\"' % (bld.env.RTEMS_RELEASE)]
+ # Build the nios2gen.
+ bld.program(target = 'rtems-nios2gen',
+ source = [ 'nios2gen/bridges.c', 'nios2gen/clocks.c',
+ 'nios2gen/devices.c', 'nios2gen/linkcmds.c',
+ 'nios2gen/memory.c', 'nios2gen/nios2gen.c',
+ 'nios2gen/output.c', 'nios2gen/ptf.c'],
+ defines = defines,
+ cflags = conf['cflags'] + conf['warningflags'],
+ linkflags = conf['linkflags'])
+def tags(ctx):
+ ctx.exec_command('etags $(find . -name \*.[sSch])', shell = True)
diff --git a/wscript b/wscript
index 0f51f96..d4f841e 100644
--- a/wscript
+++ b/wscript
@@ -34,6 +34,7 @@ import wafwindows
subdirs = ['rtemstoolkit',
'linkers',
+ 'misc',
'tester',
'tools/gdb/python']
2.13.7
