[Tracing] Deciding the Yaml configuration for barectf input
Thu Jun 7 08:27:45 UTC 2018
Hello Vidushi,
I still have problems to see the big picture. Would it be possible to
implement both approaches using a simple example?
On 06/06/18 19:31, Vidushi Vashishth wrote:
> Hi!
> I have written a blog post
> (https://vidushivashishth.github.io/sixthpost/
> <https://vidushivashishth.github.io/sixthpost/>) summarizing two
> approaches to CTF generation that I can employ at this point. I prefer
> on working with the barectf approach. The only blocker that exists
> with this approach is deciding on a YAML configuration [1] for
> defining the structure of the CTF traces. This will be the input to
> the barectf. I needed advice on how to go about this.
> References:
> [1]
> https://github.com/efficios/barectf/wiki/Writing-the-YAML-configuration-file
> Thanks,
> Vidushi
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
