[Tracing] Deciding the Yaml configuration for barectf input
Thu Jun 7 09:38:23 UTC 2018
On 07/06/18 11:31, Vidushi Vashishth wrote:
> Hi!
> Quick question. I tried to modify the printk trace generator to print
> the output traces into a text file instead of the console. On running
> the normal link and trace linker commands there are no compilation
> errors. However when I run the application executable using GDB it
> says [Inferior 1 (process 42000) exited normally].
> This is what I am doing to the code section of the rtld-print.ini's
> printk generator:
> static inline void rtld_pg_printk_entry(const char* func_name,
>                                         void*       func_addr)
>   FILE* fp = fopen("trace.txt", "a");
Always check the return value of functions which may fail.
>   fprintf (fp, ">>> %s (0x%08x)\n", func_name, func_addr);
>   fclose(fp);
> Is there something wrong with this approach?
Maybe the wrong execution context. The fprintf() must be called from
task context. I would debug the rtld_pg_printk_entry() function to
figure out what is going on.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
