[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Jun 7 11:08:18 UTC 2018
Close #3440
 tester/rt/coverage.py |  6 ++++--
 tester/rt/test.py     | 15 ++++++++++-----
 2 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index 54933d5..af24124 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -163,7 +163,8 @@ class report_gen_html:
             row += " <td>" + summary.branches_uncovered + "</td>"
             row += " <td>" + summary.branches_total + "</td>"
             row += " <td> {:.3%} </td>".format(summary.percentage_branches_covered)
-            row += ' <td><progress value="{:.3}" max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
+            row += ' <td><progress value="{:.3}" max="100"></progress></td>'\
+                    .format(100*summary.percentage_branches_covered)
             row += "</tr>\n"
         return row
@@ -299,7 +300,8 @@ class covoar(object):
         if (not path.exists(covoar_result_dir)):
             path.mkdir(covoar_result_dir)
         if (not path.exists(symbol_file)):
-            raise error.general('symbol set file: coverage %s was not created for covoar, skipping %s'% (symbol_file, set_name))
+            raise error.general('symbol set file: %s was not '
+                    'created for covoar, skipping %s'% (symbol_file, set_name))
         command = ('covoar -S ' + symbol_file
                   + ' -O ' + covoar_result_dir
                   + ' -E ' + self.explanations_txt
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 0e744cd..cdb5157 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -232,7 +232,7 @@ def run(command_path = None):
                     '--filter':         'Glob that executables must match to run (default: ' +
                               default_exefilter + ')',
                     '--stacktrace':     'Dump a stack trace on a user termination (^C)',
-                    '--coverage':       'Perform coverage analysis of test executables.'}
+                    '--coverage-sets':  'Perform coverage for specific sets'}
         mailer.append_options(optargs)
         opts = options.load(sys.argv,
                             optargs = optargs,
@@ -279,15 +279,20 @@ def run(command_path = None):
         else:
             rtems_tools = '%{_prefix}'
         bsp = opts.find_arg('--rtems-bsp')
+        if 'cov' in bsp[1].split('-'):
+            coverage_enabled = True
         if bsp is None or len(bsp) != 2:
             raise error.general('RTEMS BSP not provided or an invalid option')
         bsp = config.load(bsp[1], opts)
         bsp_config = opts.defaults.expand(opts.defaults['tester'])
-        coverage_enabled = opts.find_arg('--coverage')
+        coverage_sets = opts.find_arg('--coverage-sets')
         if coverage_enabled:
-            if len(coverage_enabled) == 2:
-                coverage_runner = coverage.coverage_run(opts.defaults,
-                                                coverage_enabled[1],
+            if coverage_sets:
+                if len(coverage_sets) != 2:
+                    raise error.general('No sets provided in --coverage-sets')
+                else :
+                    coverage_runner = coverage.coverage_run(opts.defaults,
+                                                coverage_sets[1],
                                                 executables)
             else:
                 coverage_runner = coverage.coverage_run(opts.defaults, 0,
2.14.3
