configure/make with multiple jobs error?
Thu Jun 7 18:42:33 UTC 2018
On Wed, Jun 6, 2018 at 11:12 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 07/06/2018 03:55, Gedare Bloom wrote:
>> On Tue, Jun 5, 2018 at 9:02 PM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 31/5/18 2:56 am, Gedare Bloom wrote:
>>> Is this still only with a concurrent build?
>> I think this was without concurrent build.
> Then I suspect this is the space in the path.
>>>> make[4]: Entering directory '/media/gedare/Seagate Expansion
>>>> Drive/work/rtems/builds/b-erc32-5/sparc-rtems5/c/erc32/lib/libbsp'
>>> I wonder if some of the internal shell script processing we have is safe with a
>>> space in a path?
>> It is possible. I've had problems before with spaces in the path using
>> RSB and rtems-test tools. I haven't had trouble before with
>> configure/make though.
> The base autoconf and automake should be clean but we have a range of scripts
> and m4 fragments that may not be.
OK, and I concur with your assessment. It worked a couple months ago.
I might try to bisect if I have time. I would bet something in our
scripts that changed during the source code reorg causes the problem.
> Chris
