Thoughts on Reusing FreeBSD msun tests
Joel Sherrill
joel at rtems.org
Thu Jun 7 18:59:26 UTC 2018
Sigh.. that makes things even more complex.
As a general rule, we probably should just set a goal to run newlib
tests on an RTEMS BSP and help improve newlib's tests.
--joel
On Thu, Jun 7, 2018 at 1:40 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Relatedly, you may also want to read through
> https://sourceware.org/ml/newlib/2017/msg01216.html
> On Wed, Jun 6, 2018 at 12:05 PM, Joel Sherrill <joel at rtems.org> wrote:
> > Hi
> > I can't find this on FreeBSD head but it looks like a decent
> > set of tests for fenv and other libm functionality.
> > http://web.mit.edu/freebsd/head/tools/regression/lib/msun/
> > Thoughts on incorporating this into our tests?
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180607/f51f5f4f/attachment-0001.html>
