(release notes generator) How to convert python dictionary to release notes using sphinx?
Dannie Huang
danxue.huang at gmail.com
Thu Jun 7 20:34:52 UTC 2018
Hi,
I think Chris mentioned that the RSB has a Markdown implementation:
https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/markdown
I am gonna use Markdown since it is good with everybody :)
Best,
Dannie
On Thu, Jun 7, 2018 at 2:21 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Jun 7, 2018 at 1:45 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Hello Chris, Dannie,
>> I am leaning toward a lighter method such as markdown for the release
>> notes. They are not necessary to be a beautifully formatted document.
>> Some basic document sectioning, lists, and url support seems
>> sufficient to me. This would also be easily parseable by other tools
>> in case someone wants to write some further scripts to process the
>> release notes, for example, to generate traceability documentation.
> I am OK with using something simple like markdown. The output needs
> to be "acceptable", not "beautiful". Plus I expect that there will be
> things
> in some tickets which are nearly impossible to pass through any processing
> and formatter without getting mangled. Might as well keep it simple.
> Is there documentation on the markdown format supported by the RSB?
> I assume it can be used to produce PDF and HTML.
> --joel
>> On Wed, Jun 6, 2018 at 11:55 PM, Dannie Huang <danxue.huang at gmail.com>
>> wrote:
>> > Hi Chris,
>> > Code is pushed on my github (link is attached below), it would be great
>> if
>> > you can review it for me!
>> > https://github.com/dh0072/ReleaseNotesGenerator
>> > I would go to check how Markdown works, thank you!
>> > -Dannie
>> > On Wed, Jun 6, 2018 at 10:46 PM, Chris Johns <chrisj at rtems.org> wrote:
>> >> On 07/06/2018 13:40, Dannie Huang wrote:
>> >> > Currently data from milestone page and ticket page is stored in
>> python
>> >> > dictionary,
>> >> This is great. Where is the code so it can be reviewed?
>> >> > how can I convert python dictionary to release notes using sphinx? I
>> >> > have checked sphinx documentation but not exactly sure how to do it.
>> >> I am not yet sure ReST and Sphinx is the best solution. We need to
>> decide.
>> >> We could use Markdown and get a similar result. The RSB has a Markdown
>> >> implementation ...
>> er/sb/markdown
>> >> Chris
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180607/645ff556/attachment.html>
