[PATCH] Fix --show-commands.
Christian Mauderer list at c-mauderer.de
Fri Jun 8 16:45:19 UTC 2018
Am 08.06.2018 um 15:35 schrieb Chris Johns:
>> On 8 Jun 2018, at 4:21 pm, Christian Mauderer <christian.mauderer at embedded-brains.de> wrote:
>>> Am 06.06.2018 um 09:48 schrieb Christian Mauderer:
>>> In the current version of libbsd, if the --show-commands option is used,
>>> the cwd is passed as a Nod3. Popen does not work with that. Therefore
>>> create a string from cwd if it isn't already.
>>> rtems.py | 2 ++
>>> 1 file changed, 2 insertions(+)
>>> diff --git a/rtems.py b/rtems.py
>>> index 6907709..a88c679 100644
>>> --- a/rtems.py
>>> +++ b/rtems.py
>>> @@ -579,6 +579,8 @@ def output_command_line():
>>>         else:
>>>             cmdstr = ' '.join(cmd)
>>>             Logs.info('(%d) %s' % (len(cmdstr), cmdstr)) # here is the change
>>> +        if not isinstance(kw['cwd'], str):
>>> +            kw['cwd'] = str(kw['cwd'])
>>>         Logs.debug('runner_env: kw=%s' % kw)
>>>         try:
>>>             if self.logger:
>> Hello Chris,
>> do you see any problems with that patch?
> The patch is fine. I have not had time to merge it, I am still catching up.
No problem. It's no time critical patch. I only wanted to make sure that
you have seen it.
Did you also note Gedares suggestion to move the rtems_waf.git to the
public repos? Maybe that would be a good idea.
>> Please note that this is for your personal rtems_waf.git repo. So I
>> can't check it in even if it would be acceptable. But if it is OK for
>> you, I'll create and commit a patch for libbsd to use the new version as
>> soon as this patch is commited.
> Thanks.
> Chris
> devel mailing list
> devel at rtems.org
