error while building leon3 with gcov flags
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Jun 9 11:01:47 UTC 2018
Hello,
I was going through the gcc manual for gcov
https://gcc.gnu.org/onlinedocs/gcc/Gcov-and-Optimization.html#Gcov-and-Optimization
It mentions that the flag -fprofile-arcs is necessary for generating the
.gcda files.
I have tried it with a small hello world program to see the reports, and it
seems
that for .gcda files this flag is necessary.
when I include the flag `-fprofile-arcs` with `-ftest-coverage` and then
make
I'm getting the following error.
checking whether the C compiler works... no
configure: error: in
`/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3':
configure: error: C compiler cannot create executables
See `config.log' for more details
gmake[2]: *** [Makefile:731: leon3] Error 1
gmake[2]: Leaving directory
'/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c'
gmake[1]: *** [Makefile:289: all-recursive] Error 1
gmake[1]: Leaving directory
gmake: *** [Makefile:414: all-recursive] Error 1
On 8 June 2018 at 01:13, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Fri, 8 Jun 2018, 01:09 Joel Sherrill, <joel at rtems.org> wrote:
>> Bringing in Krzysztof. Hoping he can get us on the right track here.
>> I don't think you can run GcovData.cc independent of a covoar run.
> Understood.
>> If you can figure out how to write a unit test that would be helpful.
> Will try to do that if possible.
>> On Thu, Jun 7, 2018 at 2:29 PM, Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> Hello,
>>> I was looking into the code in GcovData.cc to see how it works
>>> and what it's doing, too me it looked like very messed up, I couldn't
>>> understand (yet) what it's trying to do.
>>> Is there some way I can manually run it for one file?
>>> Is there any place where I can read how it was intended to work?
>>> Or something like a flow diagram?
>>> -- vijay
>>> On 7 June 2018 at 02:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> On Thu, 7 Jun 2018, 02:39 Joel Sherrill, <joel at rtems.org> wrote:
>>>>> On Wed, Jun 6, 2018, 3:56 PM Vijay Kumar Banerjee <
>>>>>> On 7 June 2018 at 01:48, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> On Wed, Jun 6, 2018, 2:07 PM Vijay Kumar Banerjee <
>>>>>>>> On 6 June 2018 at 20:49, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>> I can't duplicate this. My configure command was:
>>>>>>>>> ../rtems/configure --target=sparc-rtems5 --enable-rtemsbsp=leon3
>>>>>>>>> --prefix=/home/joel/rtems-work/tools/5 \
>>>>>>>>> --disable-networking --enable-posix --disable-smp
>>>>>>>>> --disable-multiprocessing \
>>>>>>>>> --enable-tests --enable-cxx --enable-maintainer-mode
>>>>>>>>> What was yours?
>>>>>>>>> I didn't have --enable-cxx and --enable-maintainer-more.
>>>>>>>> I made some tries and somehow it's perfectly working now.
>>>>>>>> I am trying to find out now how covoar generates the reports.
>>>>>>>> I made a file with a list of all gcno in score/ and run with -g
>>>>>>>> argument
>>>>>>>> now I'mg seeing the following error while running covoar
>>>>>>>> Generating Gcov reports...
>>>>>>>> Processing file: libscore_a-allocatormutex.gcno
>>>>>>>> Unable to open libscore_a-allocatormutex.gcno
>>>>>>>> Processing file: libscore_a-apimutexisowner.gcno
>>>>>>>> Unable to open libscore_a-apimutexisowner.gcno
>>>>>>>> Processing file: libscore_a-apimutexlock.gcno
>>>>>>>> Unable to open libscore_a-apimutexlock.gcno
>>>>>>>> Processing file: libscore_a-apimutexunlock.gcno
>>>>>>>> Unable to open libscore_a-apimutexunlock.gcno
>>>>>>>> Processing file: libscore_a-chain.gcno
>>>>>>>> Unable to open libscore_a-chain.gcno
>>>>>>>> Processing file: libscore_a-chainnodecount.gcno
>>>>>>> I suspect this is another instance of the path issues inside the
>>>>>>> build tree you and Cillian fixed earlier.
>>>>>>> correcting the path worked.
>>>>> Submit a patch for this. It needs fixing to get 5onyour next issue.
>>>> It just needed the absolute path to be fed.
>>>> here's what I did.
>>>> I manually 'find' all the gcno files under score.
>>>> wrote it all in a file separated by newlines.
>>>> fed that file as an argument to covoar.
>>>> and that brought me here.
>>>> So when we write script, these are the
>>>> things that will be done by the script.
>>>> Once everything strats running manually,
>>>> we can proceed to write scripts.
>>>>>> Now I'm getting this error.
>>>>>> Processing file: sparc-rtems5/c/leon3/cpukit/
>>>>>> score/src/libscore_a-kern_tc.gcno
>>>>>> ERROR: Unable to read string from gcov file
>>>>>> ERROR: Unable to read string length from gcov file
>>>>>> ERROR: Unable to read Function starting line number
>>>>>> Segmentation fault (core dumped)
>>>>> Welcome to GSoC! You are now in new territory. :)
>>>> So here the real work begins!
>>>>> Dig in and see what went wrong. Be aware.that GCC file formats may (or
>>>>> may not) be subject to.changing over time and this could just be bitrot.
>>>> I got started with it.
>>>>> Gcov-dump is installed with the compiler.
>>>>> You should check it we have a .h file describing the file and it is
>>>>> out of date.
>>>> I'll look into it.
>>>>> Also I think we now should bring the gsov maintainer in.
>>>> The covoar's gcov support needs to be reworked.
>>>> We can get the help of the expert here.
>>>>> Good job!
>>>> Thanks. :)
>>>>>>>>> On Wed, Jun 6, 2018 at 9:40 AM, Vijay Kumar Banerjee <
>>>>>>>>>> Hello,
>>>>>>>>>> I have added the following changes in the
>>>>>>>>>> bsps/sparc/leon3/config/leon3.cfg
>>>>>>>>>> CFLAGS_OPTIMIZE_V = -Os -g
>>>>>>>>>> CFLAGS_OPTIMIZE_V += -ftest-coverage
>>>>>>>>>> While trying to build with these flags, I got a bunch of
>>>>>>>>>> the following errors:
>>>>>>>>>> {standard input}: Assembler messages:
>>>>>>>>>> {standard input}:6510: Error: can't resolve
>>>>>>>>>> `.data._SPARC_Counter' {.data._SPARC_Counter section} - `.LLtext0' {.text
>>>>>>>>>> section}
>>>>>>>>>> {standard input}:6511: Error: can't resolve
>>>>>>>>>> section}
>>>>>>>>>> after the `make install` I do get a lot of .gcno files, and no
>>>>>>>>>> executables.
>>>>>>>>>> -- vijay
>>>>>>>>>> _______________________________________________
>>>>>>>>>> devel mailing list
>>>>>>>>>> devel at rtems.org
>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180609/ecc96861/attachment-0001.html>
