error while building leon3 with gcov flags
Joel Sherrill
joel at rtems.org
Sat Jun 9 14:26:05 UTC 2018
On Sat, Jun 9, 2018, 6:01 AM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hello,
> I was going through the gcc manual for gcov
> https://gcc.gnu.org/onlinedocs/gcc/Gcov-and-Optimization.html#Gcov-and-Optimization
> It mentions that the flag -fprofile-arcs is necessary for generating the
> .gcda files.
> I have tried it with a small hello world program to see the reports, and
> it seems
> that for .gcda files this flag is necessary.
> when I include the flag `-fprofile-arcs` with `-ftest-coverage` and then
> make
> I'm getting the following error.
> checking whether the C compiler works... no
> configure: error: in
> `/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3':
> configure: error: C compiler cannot create executables
> See `config.log' for more details
> gmake[2]: *** [Makefile:731: leon3] Error 1
> gmake[2]: Leaving directory
> '/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c'
> gmake[1]: *** [Makefile:289: all-recursive] Error 1
> gmake[1]: Leaving directory
> gmake: *** [Makefile:414: all-recursive] Error 1
It may be looking for a symbol provided by libgov.a. We don't have that
based on how we do coverage.
The normal approach is to add it to the RTEMS dummy crt0.c in newlib.
> On 8 June 2018 at 01:13, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On Fri, 8 Jun 2018, 01:09 Joel Sherrill, <joel at rtems.org> wrote:
>>> Bringing in Krzysztof. Hoping he can get us on the right track here.
>>> I don't think you can run GcovData.cc independent of a covoar run.
>> Understood.
>>> If you can figure out how to write a unit test that would be helpful.
>> Will try to do that if possible.
>>> On Thu, Jun 7, 2018 at 2:29 PM, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> Hello,
>>>> I was looking into the code in GcovData.cc to see how it works
>>>> and what it's doing, too me it looked like very messed up, I couldn't
>>>> understand (yet) what it's trying to do.
>>>> Is there some way I can manually run it for one file?
>>>> Is there any place where I can read how it was intended to work?
>>>> Or something like a flow diagram?
>>>> -- vijay
>>>> On 7 June 2018 at 02:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>>>> > wrote:
>>>>> On Thu, 7 Jun 2018, 02:39 Joel Sherrill, <joel at rtems.org> wrote:
>>>>>> On Wed, Jun 6, 2018, 3:56 PM Vijay Kumar Banerjee <
>>>>>>> On 7 June 2018 at 01:48, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>> On Wed, Jun 6, 2018, 2:07 PM Vijay Kumar Banerjee <
>>>>>>>>> On 6 June 2018 at 20:49, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>>> I can't duplicate this. My configure command was:
>>>>>>>>>> ../rtems/configure --target=sparc-rtems5 --enable-rtemsbsp=leon3
>>>>>>>>>> --prefix=/home/joel/rtems-work/tools/5 \
>>>>>>>>>> --disable-networking --enable-posix --disable-smp
>>>>>>>>>> --disable-multiprocessing \
>>>>>>>>>> --enable-tests --enable-cxx --enable-maintainer-mode
>>>>>>>>>> What was yours?
>>>>>>>>>> I didn't have --enable-cxx and --enable-maintainer-more.
>>>>>>>>> I made some tries and somehow it's perfectly working now.
>>>>>>>>> I am trying to find out now how covoar generates the reports.
>>>>>>>>> I made a file with a list of all gcno in score/ and run with -g
>>>>>>>>> argument
>>>>>>>>> now I'mg seeing the following error while running covoar
>>>>>>>>> Generating Gcov reports...
>>>>>>>>> Processing file: libscore_a-allocatormutex.gcno
>>>>>>>>> Unable to open libscore_a-allocatormutex.gcno
>>>>>>>>> Processing file: libscore_a-apimutexisowner.gcno
>>>>>>>>> Unable to open libscore_a-apimutexisowner.gcno
>>>>>>>>> Processing file: libscore_a-apimutexlock.gcno
>>>>>>>>> Unable to open libscore_a-apimutexlock.gcno
>>>>>>>>> Processing file: libscore_a-apimutexunlock.gcno
>>>>>>>>> Unable to open libscore_a-apimutexunlock.gcno
>>>>>>>>> Processing file: libscore_a-chain.gcno
>>>>>>>>> Unable to open libscore_a-chain.gcno
>>>>>>>>> Processing file: libscore_a-chainnodecount.gcno
>>>>>>>> I suspect this is another instance of the path issues inside the
>>>>>>>> build tree you and Cillian fixed earlier.
>>>>>>>> correcting the path worked.
>>>>>> Submit a patch for this. It needs fixing to get 5onyour next issue.
>>>>> It just needed the absolute path to be fed.
>>>>> here's what I did.
>>>>> I manually 'find' all the gcno files under score.
>>>>> wrote it all in a file separated by newlines.
>>>>> fed that file as an argument to covoar.
>>>>> and that brought me here.
>>>>> So when we write script, these are the
>>>>> things that will be done by the script.
>>>>> Once everything strats running manually,
>>>>> we can proceed to write scripts.
>>>>>>> Now I'm getting this error.
>>>>>>> Processing file:
>>>>>>> sparc-rtems5/c/leon3/cpukit/score/src/libscore_a-kern_tc.gcno
>>>>>>> ERROR: Unable to read string from gcov file
>>>>>>> ERROR: Unable to read string length from gcov file
>>>>>>> ERROR: Unable to read Function starting line number
>>>>>>> Segmentation fault (core dumped)
>>>>>> Welcome to GSoC! You are now in new territory. :)
>>>>> So here the real work begins!
>>>>>> Dig in and see what went wrong. Be aware.that GCC file formats may
>>>>>> (or may not) be subject to.changing over time and this could just be bitrot.
>>>>> I got started with it.
>>>>>> Gcov-dump is installed with the compiler.
>>>>>> You should check it we have a .h file describing the file and it is
>>>>>> out of date.
>>>>> I'll look into it.
>>>>>> Also I think we now should bring the gsov maintainer in.
>>>>> The covoar's gcov support needs to be reworked.
>>>>> We can get the help of the expert here.
>>>>>> Good job!
>>>>> Thanks. :)
>>>>>>>>>> On Wed, Jun 6, 2018 at 9:40 AM, Vijay Kumar Banerjee <
>>>>>>>>>>> Hello,
>>>>>>>>>>> I have added the following changes in the
>>>>>>>>>>> bsps/sparc/leon3/config/leon3.cfg
>>>>>>>>>>> CFLAGS_OPTIMIZE_V = -Os -g
>>>>>>>>>>> CFLAGS_OPTIMIZE_V += -ftest-coverage
>>>>>>>>>>> While trying to build with these flags, I got a bunch of
>>>>>>>>>>> the following errors:
>>>>>>>>>>> {standard input}: Assembler messages:
>>>>>>>>>>> {standard input}:6510: Error: can't resolve
>>>>>>>>>>> `.data._SPARC_Counter' {.data._SPARC_Counter section} - `.LLtext0' {.text
>>>>>>>>>>> section}
>>>>>>>>>>> {standard input}:6511: Error: can't resolve
>>>>>>>>>>> section}
>>>>>>>>>>> after the `make install` I do get a lot of .gcno files, and no
>>>>>>>>>>> executables.
>>>>>>>>>>> -- vijay
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> devel mailing list
>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180609/43874952/attachment-0001.html>
