[PATCH v2 2/2] Adding trace documentation
Vidushi Vashishth reachvidu at gmail.com
Sun Jun 10 04:45:51 UTC 2018
- Incorporated suggested changes (except making use case example as close to the actual output)
- Added trace linker section (to be completed)
- Added capture engine section
- Added trace buffering and printk trace generation in introduction
- Added trace examples section (to be completed)
The only tool to be installed is babeltrace which is in the introduction page under the babeltrace heading.
This documentation covers the following links:
1) https://devel.rtems.org/wiki/Developer/Tracing
2) https://devel.rtems.org/wiki/Developer/Tracing/Trace_Buffering
3) https://devel.rtems.org/wiki/Developer/Tracing/Trace_Linker
4) https://devel.rtems.org/attachment/wiki/Developer/Tracing/Trace_Buffering/fileio-trace.ini
5) https://ftp.rtems.org/pub/rtems/people/chrisj/capture/capture-pc586.txt
6) http://diamon.org/ctf/
7) http://diamon.org/babeltrace/
 user/index.rst                 |   2 +
 user/tracing/captureengine.rst | 167 +++++++++++++++++++++++++++
 user/tracing/examples.rst      |  11 ++
 user/tracing/index.rst         |  26 +++++
 user/tracing/introduction.rst  | 150 ++++++++++++++++++++++++
 user/tracing/tracelinker.rst   | 253 +++++++++++++++++++++++++++++++++++++++++
 user/tracing/usecases.rst      | 110 ++++++++++++++++++
 7 files changed, 719 insertions(+)
 create mode 100644 user/tracing/captureengine.rst
 create mode 100644 user/tracing/examples.rst
 create mode 100644 user/tracing/index.rst
 create mode 100644 user/tracing/introduction.rst
 create mode 100644 user/tracing/tracelinker.rst
 create mode 100644 user/tracing/usecases.rst
diff --git a/user/index.rst b/user/index.rst
index 8cbcd1b..a764fe8 100644
--- a/user/index.rst
+++ b/user/index.rst
@@ -52,6 +52,8 @@ to the Community Project hosted at http://www.rtems.org/.
 	tools/index
+        tracing/index
 	support/index
 	glossary/index
diff --git a/user/tracing/captureengine.rst b/user/tracing/captureengine.rst
new file mode 100644
index 0000000..49f8a58
--- /dev/null
+++ b/user/tracing/captureengine.rst
@@ -0,0 +1,167 @@
+.. comment SPDX-License-Identifier: CC-BY-SA-4.0
+.. comment: Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
+.. comment: All rights reserved.
+.. _capturengine:
+Capture Engine
+Capture Engine is a trace tool built inside the RTEMS operating system. Capture Engine
+is designed to cause the lowest load on the system when operating. Hence it does not
+effect RTEMS when operating or when disabled. It binds to RTEMS at runtime and does not
+require RTEMS or your application to be rebuilt in order to use it.
+The Capture Engine's sample testcase for the `sparc/erc32` is available in the
+"$HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples" directory,
+provided you followed the installation directions of the quickstart section. In order to
+access the capture testcase perform the following set of operations.
+.. code-block:: shell
+  $ cd $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples
+  $ ../samples
+  $ sparc-rtems5-run ./capture.exe
+  *** BEGIN OF TEST CAPTURE ENGINE ***
+  *** TEST VERSION: 5.0.0.de9b7d712bf5da6593386fd4fbca0d5f8b8431d8
+  *** TEST STATE: USER_INPUT
+  *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
+  *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB a3a6c34c150a357e57769a26a460c475e188438f, Newlib 3.0.0)
+  Press any key to start capture engine (20s remaining)
+  Press any key to start capture engine (19s remaining)
+  Press any key to start capture engine (18s remaining)
+  Monitor ready, press enter to login.
+  1-rtems $
+Capture Engine comes with a set of commands to perform various actions.
+Capture Engine Commands
+1) ``copen <buffer-size>``: Used to initialize the Capture Engine with the trace buffer size in bytes. By default the Capture Engine is not initialized and not running.
+2) ``cwceil <priority-value>``: Capture Engine filter used to put an upper limit on the event priority to be captured.
+3) ``cwfloor <priority-value>``: Capture Engine filter used to put a lower limit on the event priority to be captured.
+4) ``cwglob <on/off>``: Enable or disable the global watch.
+5) ``cenable``: Enables the Capture Engine. Capture Engine is by default disabled after being opened.
+6) ``cdisable``: Disables the Capture Engine.
+7) ``ctlist``: Lists the watch and trigger configurations.
+8) ``ctrace``: Dumps the recorded traces. By default this command displays 24 trace records. Repeated use of this command will display all the recorded traces.
+9) ``cwadd <task-name>``: Add watch on a particular task.
+10) ``cwtctl <task-name> <on/off>``: Enable or disable watch on a particular task.
+11) ``ctset``: Used to set a trigger. The general form of the command is:
+``ctset [-?] type [to name/id] [from] [from name/id]``
+'type' in the above command refers to the type of trigger needed. The types of triggers that currently exist
+are:
+- switch  : a context switch from one task to another task
+- create  : the executing task creates a task
+- start   : the executing task starts a task
+- restart : the executing task restarts a task
+- delete  : the executing task deletes a task
+- begin   : a task is beginning
+- exitted : a task is exitting
+Example
+The following is a sample run of the capture testsuite. The test1 command on the Capture Engine Command Line
+Interface (CLI) makes the 'RMON' task invoke a call to the 'capture_test_1()' command. This function (in the
+'test1.c' source code) creates and starts three tasks : 'CT1a', 'CT1b' and 'CT1c'. These tasks are passed the
+object id of a semaphore as a task argument. This run through traces the context switches between these tasks.
+``cwceil`` and ``cwfloor`` are set to a narrow range of task priorities to avoid creating noise from a large number
+of context switches between tasks we are not interested in.
+.. code:: shell
+  Press any key to start capture engine (17s remaining)
+  1-rtems $ copen 50000
+  capture engine opened.
+  1-rtems $ cwceil 100
+  watch ceiling is 100.
+  1-rtems $ cwfloor 102
+  watch floor is 102.
+  1-rtems $ cwglob on
+  global watch enabled.
+  1-rtems $ ctset RMON
+  trigger set.
+  1-rtems $ cenable
+  capture engine enabled.
+  1-rtems $ test1
+  1-rtems $ cdisable
+  capture engine disabled.
+  1-rtems $ ctrace
+   0     0:20:09.772382673              0a010003 CT1a 102 102 102   4096  TASK_RECORD
+   0     0:20:09.772467512            0 0a010003 CT1a 102 102             CREATED
+   0     0:20:09.772716535       249023 0a010003 CT1a 102 102             STARTED
+   0     0:20:09.772972883       256348 0a010003 CT1a 102 102             SWITCHED_IN
+   0     0:20:09.773137678       164795 0a010003 CT1a 102 102             BEGIN
+   0     0:20:09.773404402       266724 0a010003 CT1a 102 102             SWITCHED_OUT
+   0     0:20:10.771417096              0a010004 CT1b 101 101 101   4096  TASK_RECORD
+   0     0:20:10.771502545    998098143 0a010004 CT1b 101 101             CREATED
+   0     0:20:10.771752179       249634 0a010004 CT1b 101 101             STARTED
+   0     0:20:10.772003034       250855 0a010004 CT1b 101 101             SWITCHED_IN
+   0     0:20:10.772168439       165405 0a010004 CT1b 101 101             BEGIN
+   0     0:20:11.771003888    998835449 0a010004 CT1b 101 101             SWITCHED_OUT
+   0     0:20:11.771500104              0a010005 CT1c 100 100 100   4096  TASK_RECORD
+   0     0:20:11.771584943       581055 0a010005 CT1c 100 100             CREATED
+   0     0:20:11.771833966       249023 0a010005 CT1c 100 100             STARTED
+   0     0:20:11.772087873       253907 0a010005 CT1c 100 100             SWITCHED_IN
+   0     0:20:11.772252668       164795 0a010005 CT1c 100 100             BEGIN
+   0     0:20:11.772543806       291138 0a010005 CT1c 100 100             SWITCHED_OUT
+   0     0:20:11.772620100        76294 0a010004 CT1b 101 101             SWITCHED_IN
+   0     0:20:12.271004193    498384093 0a010004 CT1b 101 101             SWITCHED_OUT
+   0     0:20:12.271081097        76904 0a010003 CT1a 102 100             SWITCHED_IN
+   0     0:20:12.271410077       328980 0a010003 CT1a 102 102             SWITCHED_OUT
+  1-rtems $ ctrace
+   0     0:20:12.271486981            0 0a010005 CT1c 100 100             SWITCHED_IN
+   0     0:20:12.271740888       253907 0a010005 CT1c 100 100             SWITCHED_OUT
+   0     0:20:12.271818402        77514 0a010004 CT1b 101 101             SWITCHED_IN
+   0     0:20:12.771035626    499217224 0a010004 CT1b 101 101             SWITCHED_OUT
+   0     0:20:12.771288312       252686 0a010005 CT1c 100 100             SWITCHED_IN
+   0     0:20:12.771492780       204468 0a010005 CT1c 100 100             TERMINATED
+   0     0:20:12.771815656       322876 0a010005 CT1c 100 100             SWITCHED_OUT
+   0     0:20:12.771892560        76904 0a010004 CT1b 101 101             SWITCHED_IN
+   0     0:20:12.772083600       191040 0a010004 CT1b 101 101             TERMINATED
+   0     0:20:12.772405256       321656 0a010004 CT1b 101 101             SWITCHED_OUT
+   0     0:20:12.772482770        77514 0a010003 CT1a 102 102             SWITCHED_IN
+   0     0:20:12.772677473       194703 0a010003 CT1a 102 102             TERMINATED
+   0     0:20:12.773001570       324097 0a010003 CT1a 102 102             SWITCHED_OUT
+  1-rtems $ ctrace
+  1-rtems $
diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
index 0000000..f2beb7f
--- /dev/null
+++ b/user/tracing/examples.rst
@@ -0,0 +1,11 @@
+.. _examples:
+Tracing Examples
+[TBD]
diff --git a/user/tracing/index.rst b/user/tracing/index.rst
index 0000000..c321848
--- /dev/null
+++ b/user/tracing/index.rst
@@ -0,0 +1,26 @@
+.. _tracing-framework:
+RTEMS Tracing Framework
+.. index:: Tracing Framework
+RTEMS Tracing Framework is an on-target software based system which helps track
+the ongoings inside applications, 3rd party packages, and the kernel in real time.
+Software based tracing is a complex process which requires components on both the
+target and the host to work together. However its portability across all architectures
+and board support packages makes it a useful asset. A key requirement in RTEMS trace process
+is to take existing code in compiled format (ELF) and instrument it in order to log various events
+and records in real time. However instrumenting of the code for tracing should happen without rebuilding
+the code from the source and without annotating the source with trace code.
+.. toctree::
+   introduction
+   usecases
+   examples
diff --git a/user/tracing/introduction.rst b/user/tracing/introduction.rst
index 0000000..0a6e87e
--- /dev/null
+++ b/user/tracing/introduction.rst
@@ -0,0 +1,150 @@
+.. _introduction:
+Introduction to Tracing
+Tracing is an important function which has several applications including identification of
+complex threading, detection of deadlocks, tracing functions along with their argument values,
+and return values through progression of several function calls and audit the performance of an
+application according to required specifications.
+RTEMS tracing framework is under development and welcomes contribution by users.
+RTEMS has the following trace components:
+- RTEMS :ref:`tracelinker`
+- RTEMS :ref:`capturengine`
+- Common Trace Format Integration
+RTEMS trace framework can currently function using the following methods. Both of the methods make use
+of the :ref:`tracelinker` :
+.. _tracebuffering:
+RTEMS Trace Using Trace Buffering
+This scheme of tracing goes through the flow of events described in a subsequent flowchart:
+Step 1: The user creates an application and user configuration file. The configuration file specifies the use
+of the trace buffer generator and other standard initializations. The user then configures her BSP and invokes
+the trace linker using a command to link the application executable. The trace linker uses the application
+files in compiled format (ELF) and the libraries used to build the application for performing this link.
+Step 2: The RTEMS Trace Linker reads the user’s configuration file and that results in it reading the standard
+Trace Buffering Configuration files installed with the RTEMS Trace Linker. The trace linker uses the target
+compiler and linker to create the trace enabled application executable. It wraps the functions defined in the
+user’s configuration with code that captures trace records into the statically allocated buffer. The trace wrapper
+code is compiled with the target compiler and the resulting ELF object file is added to the standard link command
+line used to link the application and the application is re-linked using the wrapping option of the GNU linker.
+Step 3: The trace linker creates an executable which is capable of running on the target hardware or simulator.
+Step 4: RTEMS shell provides the “rtrace” command to display and save trace buffers.
+.. comment: taken from https://devel.rtems.org/wiki/Developer/Tracing
+.. figure:: ../../images/user/rtems-trace-buffering.png
+  :align: center
+  :width: 75%
+.. _printk:
+RTEMS Trace Using Printk
+Step 1: The user creates an RTEMS application in the normal manner as well as a Trace Linker configuration file.
+The configuration file specifies using the Printk trace mode and the functions to trace. The user invokes the
+Trace Linker with the configuration and the normal link command line used to the link the application executable.
+The application ELF object files and libraries, including the RTEMS libraries are standard and do not need to be
+built specially.
+Step 2: The RTEMS Trace Linker reads the user's configuration file and that results in it reading the standard
+Printk Trace Configuration files installed with the RTEMS Trace Linker. The trace linker uses the target compiler
+and linker to create the trace enabled application executable. It wraps the functions defined in the user's
+configuration with code that prints the entry with arguments and exit and return value if any. The trace wrapper
+line used to link the application and the application is relinked using the wrapping option of the GNU linker.
+Step 3: The trace linker creates and RTEMS ELF executable that can be run on the target hardware or simulator.
+Step 4: The application is run in the hardware directly or using a debugger. The printk() output appears on the
+target console and the user can save that to a file.
+.. figure:: ../../images/user/rtems-trace-printk.png
+  :align: center
+  :width: 75%
+The :ref:`examples` section describes generation of traces using both of the aforementioned techniques using the
+`fileio` testsuite available with RTEMS installation.
+RTEMS Trace Using CTF
+`Common Trace Format <http://diamon.org/ctf/>`_ (CTF) is a binary trace format which is fast to write
+and has great flexibility. It allows traces to be developed by bare-metal applications or by any
+other C/C++ system. RTEMS tracing framework can benefit from these features of CTF.
+A typical CTF *trace* consists of multiple *streams* of binary *events*. The *metadata* stream is a mandatory
+stream which describes the layout of all the other streams in a trace. This metadata stream is written
+using *Trace Stream Description Language* (TSDL).
+.. comment: image taken from view-source:http://diamon.org/ctf/img/ctf-trace.png
+.. comment: Not generating a copyright in the high chance we decide to not keep a descriptive section on CTF
+.. figure:: ../../images/user/ctf-trace.png
+  :align: center
+  :width: 75%
+A binary *stream* is further a concatenation of several packets each containing the following:
+- A packet header
+- An optional packet context
+- A set of concatenated events each containing:
+ - An event header
+ - A stream-specific context
+ - An event-specific context
+ - A payload
+.. comment: taken from view-source:http://diamon.org/ctf/img/ctf-stream-packet.png
+.. figure:: ../../images/user/ctf-stream-packet.png
+  :align: center
+  :width: 75%
+All the headers, contexts and payloads are written in TSDL using CTF data types. CTF supports a rich set of
+configurable datatypes which makes it possible to describe a larger variety of binary structure. Moreover types
+in CTF are organized as type classes where type specifications can be inherited to allow deriving types. These
+factors make CTF flexible. CTF enables fast writing of binary data as it usually involves appending memory contents,
+as it is to a binary CTF stream. CTF streams are capable of being sent or received over the network without any data
+being written to disk and hence can be useful in transporting traces from the target to the host machine for analysis.
+Due to these advantages tracing using CTF will prove to be beneficial for the users. This method of tracing is currently
+under development. Currently the RTEMS tracing framework is able to output trace data in the form of trace buffers,
+console output and csv files. A conversion tool which transforms these trace output formats to CTF will be viable
+approach to generating CTF traces. In this regard we utilize babeltrace, which is described in the following section.
+Babeltrace
+Babeltrace is an open source trace format converter which can be used to convert RTEMS traces into CTF.
+It is also a reference parser implementation of CTF. Babeltrace currently supports the following output
+formats for traces:
+- Text
+- CTF
+- CTF-metadata
+- Dummy
+- lttng-live
+Babeltrace comes in the form of a library, python bindings (python3) and command line tool called ``babeltrace``.
+To install babeltrace on your host you can install a distribution package or build from source using tarballs or
+git repositories of babeltrace. Refer to http://diamon.org/babeltrace/ for further details.
diff --git a/user/tracing/tracelinker.rst b/user/tracing/tracelinker.rst
index 0000000..6bd8f20
--- /dev/null
+++ b/user/tracing/tracelinker.rst
@@ -0,0 +1,253 @@
+.. _tracelinker:
+Trace Linker
+RTEMS trace linker is a post link tool central to the RTEMS trace framework. It is installed as
+a part of the RTEMS Tool Project.The RTEMS Trace Linker is a post link tool that performs a re-link
+of your application to produce a trace executable. A trace executable has been instrumented by the
+RTEMS Trace Linker with additional code that implements software tracing. A key requirement of the
+trace process in RTEMS is to take existing code in a compiled format (ELF) and instrument it without
+rebuilding that code from source and without annotating that source with trace code.
+Command Line
+A typical command to invoke the trace linker consists of two parts separated by ``--``.  The first part
+controls the trace linker and provides the various options it needs and the second part is a standard linker
+command line you would use to link an RTEMS application. The current command line for trace linker consists
+of:
+  $ rtems-tld -h
+  rtems-trace-ld [options] objects
+  Options and arguments:
+   -h          : help (also --help)
+   -V          : print linker version number and exit (also --version)
+   -v          : verbose (trace import parts), can supply multiple times
+                 to increase verbosity (also --verbose)
+   -w          : generate warnings (also --warn)
+   -k          : keep temporary files (also --keep)
+   -c compiler : target compiler is not standard (also --compiler)
+   -l linker   : target linker is not standard (also --linker)
+   -E prefix   : the RTEMS tool prefix (also --exec-prefix)
+   -f cflags   : C compiler flags (also --cflags)
+   -r path     : RTEMS path (also --rtems)
+   -B bsp      : RTEMS arch/bsp (also --rtems-bsp)
+   -W wrapper  : wrapper file name without ext (also --wrapper)
+   -C ini      : user configuration INI file (also --config)
+   -P path     : user configuration INI file search path (also --path)
+The trace linker generates code that needs to be compiled and linked to the application executable so
+it needs to know the target compiler and `CFLAGS`. There are a couple of ways to do this. The simplest
+is to provide the path to RTEMS using the `-r` option and the architecture and BSP name in the standard
+RTEMS format of arch/bsp. The trace linker will extract the compiler and flags used to build RTEMS and
+will use them. If you require specific options you can use the `-f`, `-c`, `-l` and `-E` options to provide
+them. If the functions you are tracing use types from your code then add the include path to the `CFLAGS`.
+The trace linker requires you to provide a user configuration file using the `-C` or ``--config`` option.
+This is an INI format file detailed in the Configuration section. You can also provide an INI file search
+path using the `-P` option.
+If you are working with new configuration files and you want to view the files the trace linker generates
+add the `-k` option to keep the temporary files, and `-W` to specify an explicit wrapper C file name. If you
+set the ``dump-on-error`` option in the configuration options section you will get a dump of the configuration
+on an error.
+Configuration (INI) files
+The Trace Linker is controlled using configuration files. Configuration files are categorized into
+3 types:
+- User Configuration: These are specific to the user application to be traced. This file initializes the values of the trace generator, triggers, enables and traces.
+- Tracer Configuration: These are like a library of common or base trace functions that can be referenced by an application. These files tend to hold the details needed to wrap a specific set of functions. Examples provided with the RTEMS Linker are the RTEMS API and Libc.
+- Generator Configuration: This is used to encapsulate a specific method of tracing. Rtems currently provides generators for trace buffering, printk and printf.
+The configuration files are in the *INI file format* which is composed of `sections`. Each section has
+a section name and set of *keys* which consist of *names* and *values*. A typical key is of the form
+``name=value``. Keys can be used to include other INI files using the include key name. This is shown
+in the following example where the values indicate rtems and rtld-base configuration files:
+.. code-block::shell
+  include = rtems.ini, rtld-base.ini
+The trace linker also uses values in keys to specify other sections. In this example the functions name
+lists test-trace-funcs and that section contains a headers key that references a further section test-headers:
+  functions = test-trace-funcs, rtems-api
+  [test-trace-funcs]
+  ; Parsed via the 'function-set', not parse as a 'trace'.
+  headers = test-headers
+  [test-headers]
+  header = '#include "test-trace-1.h"'
+The format of a configuration file is explained next. Snippets of the fileio-trace.ini file have been used for
+explicit understanding. This file can be downloaded from `here <https://devel.rtems.org/attachment/wiki/Developer/Tracing/Trace_Buffering/fileio-trace.ini>`_.
+Tracer Section
+The topmost level section is the ``tracer`` section. It can contains the following keys:
+- name: The name of trace being linked.
+- options: A list of option sections.
+- defines: A list of sections containing defines or define record.
+- define: A list of define string that are single or double quoted.
+- enables: The list of sections containing enabled functions to trace.
+- triggers: The list of sections containing enabled functions to trigger trace on.
+- traces: The list of sections containing function lists to trace.
+- functions: The list of sections containing function details.
+- include: The list of files to include
+  [tracer]
+  name = File IO tracer
+  ; The configuration
+  options = fileio-options
+  traces = fileio
+  defines = fileio
+  enables = fileio
+  triggers = fileio
+  functions = fileio-funcs, rtems-api, rtems-posix, libc-heap
+  include = rtems.ini, rtld-base.ini, rtld-trace-buffer.ini, libc-heap.ini
+Options section
+The options section in the fileio-trace.ini is called the `fileio-options`. A general options section can
+contain following sets of keys:
+- dump-on-error: Dump the parsed configuration data on error. The value can be true or false.
+- verbose: Set the verbose level. The value can be true or a number value.
+- prefix: The prefix for the tools and an install RTEMS if rtems-path is not set.
+- cc: The compiler used to compile the generated wrapper code. Overrides the BSP configuration value if a BSP
+is specified.
+- ld: The linker used to link the application. The default is the cc value as read from the BSP configuration
+if specified. If your application contains C++ code use this setting to the change the linker to g++.
+- cflags: Set the CFLAGS used to compiler the wrapper. These flags are pre-pended to the BSP read flags if a BSP
+is specified. This option is used to provide extra include paths to header files in your application that contain
+types any functions being traced reference.
+- rtems-path: The path to an install RTEMS if not installed under the prefix.
+- rtems-bsp: The BSP we are building the trace executable for. The is an arch and bsp pair. For example sparc/erc32.
+  [fileio-options]
+  dump-on-error = true
+  ; Tools
+  prefix = /development/rtems/5
+  rtems-path = /development/rtems/kernel/5
+  rtems-bsp = sparc/erc32
+  ; Generator options.
+  gen-enables = enable
+  gen-triggers = enable
+Trace Section
+A trace section defines how trace wrapper functions are built. To build a trace function that wraps an existing
+function in an ELF object file or library archive we need to have the function's signature. A signature is the
+function's declaration with any types used. The the signature has specific types we need access to those types
+which means the wrapper code needs to include header files that define those types. There may also be specific
+defines needed to access those types.
+- generator: The generator defines the type of tracing being used.
+- headers: List of sections that contain header files keys.
+- header: A header key. Typically the include code.
+- defines: List of sections that contain defines.
+- define: A define key. Typically the define code.
+- signatures: List of function signature sections.
+- trace: Functions that are instrumented with trace code.
+[TBD]
+Function Wrapping
+The trace linker's major role is to wrap functions in the existing executable with trace code. The directions
+on how to wrap application functions is provided by the generator configuration. The wrapping function uses a
+GNU linker option called --wrap=symbol. The GNU Ld manual states:
+"Use a wrapper function for symbol. Any undefined reference to symbol will be resolved to __wrap_symbol. Any
+undefined reference to __real_symbol will be resolved to symbol."
+The trace linker generates C code with a wrapper for each function to be instrumented. The trace code generated
+is driven by the configuration INI files.
+Function Signatures
+A function signature is the function's declaration. It is the name of the function, the return value and the
+arguments. Tracing using function wrappers requires that we have accurate function signatures and ideally we
+would like to determine the function signature from the data held in ELF files. ELF files can contain DWARF data,
+the ELF debugging data format. In time the trace project would like to support libdwarf so the DWARF data can be
+accessed and use to determine a function's signature. This work is planned but not scheduled to be done and so in
+the meantime we explicitly define the function signatures in the configuration files.
+Development
+The Trace Linker is part of the RTEMS tools git repository available at : https://git.rtems.org/rtems-tools
+The RTEMS tools project utilizes the waf build system. Use the following commands in the topmost build directory
+to build the tools project:
+First we configure using:
+  $./waf configure --prefix=$HOME/development/rtems/5
+Then we build and install using:
+  $./waf build install
diff --git a/user/tracing/usecases.rst b/user/tracing/usecases.rst
index 0000000..95a283b
--- /dev/null
+++ b/user/tracing/usecases.rst
@@ -0,0 +1,110 @@
+.. _usecases:
+Tracing Use Cases
+Following are the use cases of the tracing framework that are currently under development:
+Function Tracing
+Tracing the entry and exit of a function as well as the values of the arguments and
+return values can prove to be an important application for the tracing framework.
+Objective
+This use case can prove to be helpful in debugging of applications for the users. It can also
+be used to understand the working of existing application code bases. Capturing of argument and
+return values maybe useful in tracking unexpected output results from the applications.
+Requirements
+The current tracing framework provides this functionality with :ref:`tracebuffering`. The output is
+provided in the form of printing on console or saving the buffer in the form of a bin file. In order to
+develop this use case using CTF we need to be able to convert this RTEMS trace output into CTF. This could
+be done using babeltrace. The converted CTF traces would then be sent over to the host using a transport
+mechanism.
+Example
+As a start to the development of function tracing using CTF we can work on the fileio
+sample testsuite and trace all the calls to malloc, calloc, free and realloc functions.
+Along with the calls made to these functions the trace must also capture the values of
+their arguments at entry and the return values at function exit. As an example of an application
+having the following progression of function calls:
+.. code-block:: c
+  #include <stdlib.h>
+  int main(int argc, char** argv)
+    int* a = malloc(sizeof(int));
+    free(a);
+    a = calloc(1, sizeof(int));
+    return 0;
+The trace of such an application must be output of the following kind:
+  Timestamp1    entry of malloc > argument value
+  Timestamp2    exit of malloc < return value
+  Timestamp3    entry of free > argument value
+  Timestamp4    exit of free < return value (null)
+  Timestamp5    entry of calloc > argument1 value, argument2 value
+  Timestamp6    exit of calloc < return value1
+There could be additional columns of details including current priority, task state etc.
+Tracing Thread Operations
+Tracing thread creation, switching and termination operation in a thread's lifetime within an application.
+Objective
+Real time applications inherently utilize parallel programming which entails several
+tasks executing simultaneously and competing for common resources. On single processor systems
+the CPU performs context switching between each of these tasks rapidly. By tracing the creation and
+termination of tasks as well as the context switches between them one can possibly identify probable race
+conditions or complex threading operations.
+Requirements
+[TBD]
+Example
+A sample trace tracking two tasks Ta and Tb could have an output of the following kind:
+  Timestamp1 taskid Ta CREATED
+  Timestamp1 taskid Ta SWITCHED-IN
+  Timestamp1 taskid Ta BEGIN
+  Timestamp1 taskid Tb CREATED
+  Timestamp1 taskid Ta SWITCHED-OUT
+  Timestamp1 taskid Tb SWITCHED-IN
+  Timestamp1 taskid Tb BEGIN
+  Timestamp1 taskid Tb SWITCHED-OUT
+  Timestamp1 taskid Tb TERMINATED
+  Timestamp1 taskid Ta TERMINATED
2.7.4
