[PATCH v2 2/2] Adding trace documentation
Sun Jun 10 10:32:16 UTC 2018
I can't give a detailed review, but one possible problem I notice is
the line lengths. I think in the docs we also have 79/80 character
widths for lines. Please set your editor to hard-wrap at 79 or 80, and
break the long lines. (Unless I'm mistaken about the line length in
the doc files.)
On Sun, Jun 10, 2018 at 12:45 AM, Vidushi Vashishth <reachvidu at gmail.com> wrote:
> - Incorporated suggested changes (except making use case example as close to the actual output)
> - Added trace linker section (to be completed)
> - Added capture engine section
> - Added trace buffering and printk trace generation in introduction
> - Added trace examples section (to be completed)
> The only tool to be installed is babeltrace which is in the introduction page under the babeltrace heading.
> This documentation covers the following links:
> 1) https://devel.rtems.org/wiki/Developer/Tracing
> 2) https://devel.rtems.org/wiki/Developer/Tracing/Trace_Buffering
> 3) https://devel.rtems.org/wiki/Developer/Tracing/Trace_Linker
> 4) https://devel.rtems.org/attachment/wiki/Developer/Tracing/Trace_Buffering/fileio-trace.ini
> 5) https://ftp.rtems.org/pub/rtems/people/chrisj/capture/capture-pc586.txt
> 6) http://diamon.org/ctf/
> 7) http://diamon.org/babeltrace/
>  user/index.rst                 |   2 +
>  user/tracing/captureengine.rst | 167 +++++++++++++++++++++++++++
>  user/tracing/examples.rst      |  11 ++
>  user/tracing/index.rst         |  26 +++++
>  user/tracing/introduction.rst  | 150 ++++++++++++++++++++++++
>  user/tracing/tracelinker.rst   | 253 +++++++++++++++++++++++++++++++++++++++++
>  user/tracing/usecases.rst      | 110 ++++++++++++++++++
>  7 files changed, 719 insertions(+)
>  create mode 100644 user/tracing/captureengine.rst
>  create mode 100644 user/tracing/examples.rst
>  create mode 100644 user/tracing/index.rst
>  create mode 100644 user/tracing/introduction.rst
>  create mode 100644 user/tracing/tracelinker.rst
>  create mode 100644 user/tracing/usecases.rst
> diff --git a/user/index.rst b/user/index.rst
> index 8cbcd1b..a764fe8 100644
> --- a/user/index.rst
> +++ b/user/index.rst
> @@ -52,6 +52,8 @@ to the Community Project hosted at http://www.rtems.org/.
>         tools/index
> +        tracing/index
>         support/index
>         glossary/index
> diff --git a/user/tracing/captureengine.rst b/user/tracing/captureengine.rst
> new file mode 100644
> index 0000000..49f8a58
> --- /dev/null
> +++ b/user/tracing/captureengine.rst
> @@ -0,0 +1,167 @@
> +.. comment SPDX-License-Identifier: CC-BY-SA-4.0
> +.. comment: Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
> +.. comment: All rights reserved.
> +.. _capturengine:
> +Capture Engine
> +Capture Engine is a trace tool built inside the RTEMS operating system. Capture Engine
> +is designed to cause the lowest load on the system when operating. Hence it does not
> +effect RTEMS when operating or when disabled. It binds to RTEMS at runtime and does not
> +require RTEMS or your application to be rebuilt in order to use it.
> +The Capture Engine's sample testcase for the `sparc/erc32` is available in the
> +"$HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples" directory,
> +provided you followed the installation directions of the quickstart section. In order to
> +access the capture testcase perform the following set of operations.
> +.. code-block:: shell
> +  $ cd $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples
> +  $ ../samples
> +  $ sparc-rtems5-run ./capture.exe
> +  *** BEGIN OF TEST CAPTURE ENGINE ***
> +  *** TEST VERSION: 5.0.0.de9b7d712bf5da6593386fd4fbca0d5f8b8431d8
> +  *** TEST STATE: USER_INPUT
> +  *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
> +  *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB a3a6c34c150a357e57769a26a460c475e188438f, Newlib 3.0.0)
> +  Press any key to start capture engine (20s remaining)
> +  Press any key to start capture engine (19s remaining)
> +  Press any key to start capture engine (18s remaining)
> +  Monitor ready, press enter to login.
> +  1-rtems $
> +Capture Engine comes with a set of commands to perform various actions.
> +Capture Engine Commands
> +1) ``copen <buffer-size>``: Used to initialize the Capture Engine with the trace buffer size in bytes. By default the Capture Engine is not initialized and not running.
> +2) ``cwceil <priority-value>``: Capture Engine filter used to put an upper limit on the event priority to be captured.
> +3) ``cwfloor <priority-value>``: Capture Engine filter used to put a lower limit on the event priority to be captured.
> +4) ``cwglob <on/off>``: Enable or disable the global watch.
> +5) ``cenable``: Enables the Capture Engine. Capture Engine is by default disabled after being opened.
> +6) ``cdisable``: Disables the Capture Engine.
> +7) ``ctlist``: Lists the watch and trigger configurations.
> +8) ``ctrace``: Dumps the recorded traces. By default this command displays 24 trace records. Repeated use of this command will display all the recorded traces.
> +9) ``cwadd <task-name>``: Add watch on a particular task.
> +10) ``cwtctl <task-name> <on/off>``: Enable or disable watch on a particular task.
> +11) ``ctset``: Used to set a trigger. The general form of the command is:
> +``ctset [-?] type [to name/id] [from] [from name/id]``
> +'type' in the above command refers to the type of trigger needed. The types of triggers that currently exist
> +are:
> +- switch  : a context switch from one task to another task
> +- create  : the executing task creates a task
> +- start   : the executing task starts a task
> +- restart : the executing task restarts a task
> +- delete  : the executing task deletes a task
> +- begin   : a task is beginning
> +- exitted : a task is exitting
> +Example
> +The following is a sample run of the capture testsuite. The test1 command on the Capture Engine Command Line
> +Interface (CLI) makes the 'RMON' task invoke a call to the 'capture_test_1()' command. This function (in the
> +'test1.c' source code) creates and starts three tasks : 'CT1a', 'CT1b' and 'CT1c'. These tasks are passed the
> +object id of a semaphore as a task argument. This run through traces the context switches between these tasks.
> +``cwceil`` and ``cwfloor`` are set to a narrow range of task priorities to avoid creating noise from a large number
> +of context switches between tasks we are not interested in.
> +.. code:: shell
> +  Press any key to start capture engine (17s remaining)
> +  1-rtems $ copen 50000
> +  capture engine opened.
> +  1-rtems $ cwceil 100
> +  watch ceiling is 100.
> +  1-rtems $ cwfloor 102
> +  watch floor is 102.
> +  1-rtems $ cwglob on
> +  global watch enabled.
> +  1-rtems $ ctset RMON
> +  trigger set.
> +  1-rtems $ cenable
> +  capture engine enabled.
> +  1-rtems $ test1
> +  1-rtems $ cdisable
> +  capture engine disabled.
> +  1-rtems $ ctrace
> +   0     0:20:09.772382673              0a010003 CT1a 102 102 102   4096  TASK_RECORD
> +   0     0:20:09.772467512            0 0a010003 CT1a 102 102             CREATED
> +   0     0:20:09.772716535       249023 0a010003 CT1a 102 102             STARTED
> +   0     0:20:09.772972883       256348 0a010003 CT1a 102 102             SWITCHED_IN
> +   0     0:20:09.773137678       164795 0a010003 CT1a 102 102             BEGIN
> +   0     0:20:09.773404402       266724 0a010003 CT1a 102 102             SWITCHED_OUT
> +   0     0:20:10.771417096              0a010004 CT1b 101 101 101   4096  TASK_RECORD
> +   0     0:20:10.771502545    998098143 0a010004 CT1b 101 101             CREATED
> +   0     0:20:10.771752179       249634 0a010004 CT1b 101 101             STARTED
> +   0     0:20:10.772003034       250855 0a010004 CT1b 101 101             SWITCHED_IN
> +   0     0:20:10.772168439       165405 0a010004 CT1b 101 101             BEGIN
> +   0     0:20:11.771003888    998835449 0a010004 CT1b 101 101             SWITCHED_OUT
> +   0     0:20:11.771500104              0a010005 CT1c 100 100 100   4096  TASK_RECORD
> +   0     0:20:11.771584943       581055 0a010005 CT1c 100 100             CREATED
> +   0     0:20:11.771833966       249023 0a010005 CT1c 100 100             STARTED
> +   0     0:20:11.772087873       253907 0a010005 CT1c 100 100             SWITCHED_IN
> +   0     0:20:11.772252668       164795 0a010005 CT1c 100 100             BEGIN
> +   0     0:20:11.772543806       291138 0a010005 CT1c 100 100             SWITCHED_OUT
> +   0     0:20:11.772620100        76294 0a010004 CT1b 101 101             SWITCHED_IN
> +   0     0:20:12.271004193    498384093 0a010004 CT1b 101 101             SWITCHED_OUT
> +   0     0:20:12.271081097        76904 0a010003 CT1a 102 100             SWITCHED_IN
> +   0     0:20:12.271410077       328980 0a010003 CT1a 102 102             SWITCHED_OUT
> +  1-rtems $ ctrace
> +   0     0:20:12.271486981            0 0a010005 CT1c 100 100             SWITCHED_IN
> +   0     0:20:12.271740888       253907 0a010005 CT1c 100 100             SWITCHED_OUT
> +   0     0:20:12.271818402        77514 0a010004 CT1b 101 101             SWITCHED_IN
> +   0     0:20:12.771035626    499217224 0a010004 CT1b 101 101             SWITCHED_OUT
> +   0     0:20:12.771288312       252686 0a010005 CT1c 100 100             SWITCHED_IN
> +   0     0:20:12.771492780       204468 0a010005 CT1c 100 100             TERMINATED
> +   0     0:20:12.771815656       322876 0a010005 CT1c 100 100             SWITCHED_OUT
> +   0     0:20:12.771892560        76904 0a010004 CT1b 101 101             SWITCHED_IN
> +   0     0:20:12.772083600       191040 0a010004 CT1b 101 101             TERMINATED
> +   0     0:20:12.772405256       321656 0a010004 CT1b 101 101             SWITCHED_OUT
> +   0     0:20:12.772482770        77514 0a010003 CT1a 102 102             SWITCHED_IN
> +   0     0:20:12.772677473       194703 0a010003 CT1a 102 102             TERMINATED
> +   0     0:20:12.773001570       324097 0a010003 CT1a 102 102             SWITCHED_OUT
> +  1-rtems $ ctrace
> +  1-rtems $
> diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
> index 0000000..f2beb7f
> --- /dev/null
> +++ b/user/tracing/examples.rst
> @@ -0,0 +1,11 @@
> +.. _examples:
> +Tracing Examples
> +[TBD]
> diff --git a/user/tracing/index.rst b/user/tracing/index.rst
> index 0000000..c321848
> --- /dev/null
> +++ b/user/tracing/index.rst
> @@ -0,0 +1,26 @@
> +.. _tracing-framework:
> +RTEMS Tracing Framework
> +.. index:: Tracing Framework
> +RTEMS Tracing Framework is an on-target software based system which helps track
> +the ongoings inside applications, 3rd party packages, and the kernel in real time.
> +Software based tracing is a complex process which requires components on both the
> +target and the host to work together. However its portability across all architectures
> +and board support packages makes it a useful asset. A key requirement in RTEMS trace process
> +is to take existing code in compiled format (ELF) and instrument it in order to log various events
> +and records in real time. However instrumenting of the code for tracing should happen without rebuilding
> +the code from the source and without annotating the source with trace code.
> +.. toctree::
> +   introduction
> +   usecases
> +   examples
> diff --git a/user/tracing/introduction.rst b/user/tracing/introduction.rst
> index 0000000..0a6e87e
> --- /dev/null
> +++ b/user/tracing/introduction.rst
> @@ -0,0 +1,150 @@
> +.. _introduction:
> +Introduction to Tracing
> +Tracing is an important function which has several applications including identification of
> +complex threading, detection of deadlocks, tracing functions along with their argument values,
> +and return values through progression of several function calls and audit the performance of an
> +application according to required specifications.
> +RTEMS tracing framework is under development and welcomes contribution by users.
> +RTEMS has the following trace components:
> +- RTEMS :ref:`tracelinker`
> +- RTEMS :ref:`capturengine`
> +- Common Trace Format Integration
> +RTEMS trace framework can currently function using the following methods. Both of the methods make use
> +of the :ref:`tracelinker` :
> +.. _tracebuffering:
> +RTEMS Trace Using Trace Buffering
> +This scheme of tracing goes through the flow of events described in a subsequent flowchart:
> +Step 1: The user creates an application and user configuration file. The configuration file specifies the use
> +of the trace buffer generator and other standard initializations. The user then configures her BSP and invokes
> +the trace linker using a command to link the application executable. The trace linker uses the application
> +files in compiled format (ELF) and the libraries used to build the application for performing this link.
> +Step 2: The RTEMS Trace Linker reads the user’s configuration file and that results in it reading the standard
> +Trace Buffering Configuration files installed with the RTEMS Trace Linker. The trace linker uses the target
> +compiler and linker to create the trace enabled application executable. It wraps the functions defined in the
> +user’s configuration with code that captures trace records into the statically allocated buffer. The trace wrapper
> +code is compiled with the target compiler and the resulting ELF object file is added to the standard link command
> +line used to link the application and the application is re-linked using the wrapping option of the GNU linker.
> +Step 3: The trace linker creates an executable which is capable of running on the target hardware or simulator.
> +Step 4: RTEMS shell provides the “rtrace” command to display and save trace buffers.
> +.. comment: taken from https://devel.rtems.org/wiki/Developer/Tracing
> +.. figure:: ../../images/user/rtems-trace-buffering.png
> +  :align: center
> +  :width: 75%
> +.. _printk:
> +RTEMS Trace Using Printk
> +Step 1: The user creates an RTEMS application in the normal manner as well as a Trace Linker configuration file.
> +The configuration file specifies using the Printk trace mode and the functions to trace. The user invokes the
> +Trace Linker with the configuration and the normal link command line used to the link the application executable.
> +The application ELF object files and libraries, including the RTEMS libraries are standard and do not need to be
> +built specially.
> +Step 2: The RTEMS Trace Linker reads the user's configuration file and that results in it reading the standard
> +Printk Trace Configuration files installed with the RTEMS Trace Linker. The trace linker uses the target compiler
> +and linker to create the trace enabled application executable. It wraps the functions defined in the user's
> +configuration with code that prints the entry with arguments and exit and return value if any. The trace wrapper
> +line used to link the application and the application is relinked using the wrapping option of the GNU linker.
> +Step 3: The trace linker creates and RTEMS ELF executable that can be run on the target hardware or simulator.
> +Step 4: The application is run in the hardware directly or using a debugger. The printk() output appears on the
> +target console and the user can save that to a file.
> +.. figure:: ../../images/user/rtems-trace-printk.png
> +  :align: center
> +  :width: 75%
> +The :ref:`examples` section describes generation of traces using both of the aforementioned techniques using the
> +`fileio` testsuite available with RTEMS installation.
> +RTEMS Trace Using CTF
> +`Common Trace Format <http://diamon.org/ctf/>`_ (CTF) is a binary trace format which is fast to write
> +and has great flexibility. It allows traces to be developed by bare-metal applications or by any
> +other C/C++ system. RTEMS tracing framework can benefit from these features of CTF.
> +A typical CTF *trace* consists of multiple *streams* of binary *events*. The *metadata* stream is a mandatory
> +stream which describes the layout of all the other streams in a trace. This metadata stream is written
> +using *Trace Stream Description Language* (TSDL).
> +.. comment: image taken from view-source:http://diamon.org/ctf/img/ctf-trace.png
> +.. comment: Not generating a copyright in the high chance we decide to not keep a descriptive section on CTF
> +.. figure:: ../../images/user/ctf-trace.png
> +  :align: center
> +  :width: 75%
> +A binary *stream* is further a concatenation of several packets each containing the following:
> +- A packet header
> +- An optional packet context
> +- A set of concatenated events each containing:
> + - An event header
> + - A stream-specific context
> + - An event-specific context
> + - A payload
> +.. comment: taken from view-source:http://diamon.org/ctf/img/ctf-stream-packet.png
> +.. figure:: ../../images/user/ctf-stream-packet.png
> +  :align: center
> +  :width: 75%
> +All the headers, contexts and payloads are written in TSDL using CTF data types. CTF supports a rich set of
> +configurable datatypes which makes it possible to describe a larger variety of binary structure. Moreover types
> +in CTF are organized as type classes where type specifications can be inherited to allow deriving types. These
> +factors make CTF flexible. CTF enables fast writing of binary data as it usually involves appending memory contents,
> +as it is to a binary CTF stream. CTF streams are capable of being sent or received over the network without any data
> +being written to disk and hence can be useful in transporting traces from the target to the host machine for analysis.
> +Due to these advantages tracing using CTF will prove to be beneficial for the users. This method of tracing is currently
> +under development. Currently the RTEMS tracing framework is able to output trace data in the form of trace buffers,
> +console output and csv files. A conversion tool which transforms these trace output formats to CTF will be viable
> +approach to generating CTF traces. In this regard we utilize babeltrace, which is described in the following section.
> +Babeltrace
> +Babeltrace is an open source trace format converter which can be used to convert RTEMS traces into CTF.
> +It is also a reference parser implementation of CTF. Babeltrace currently supports the following output
> +formats for traces:
> +- Text
> +- CTF
> +- CTF-metadata
> +- Dummy
> +- lttng-live
> +Babeltrace comes in the form of a library, python bindings (python3) and command line tool called ``babeltrace``.
> +To install babeltrace on your host you can install a distribution package or build from source using tarballs or
> +git repositories of babeltrace. Refer to http://diamon.org/babeltrace/ for further details.
> diff --git a/user/tracing/tracelinker.rst b/user/tracing/tracelinker.rst
> index 0000000..6bd8f20
> --- /dev/null
> +++ b/user/tracing/tracelinker.rst
> @@ -0,0 +1,253 @@
> +.. _tracelinker:
> +Trace Linker
> +RTEMS trace linker is a post link tool central to the RTEMS trace framework. It is installed as
> +a part of the RTEMS Tool Project.The RTEMS Trace Linker is a post link tool that performs a re-link
> +of your application to produce a trace executable. A trace executable has been instrumented by the
> +RTEMS Trace Linker with additional code that implements software tracing. A key requirement of the
> +trace process in RTEMS is to take existing code in a compiled format (ELF) and instrument it without
> +rebuilding that code from source and without annotating that source with trace code.
> +Command Line
> +A typical command to invoke the trace linker consists of two parts separated by ``--``.  The first part
> +controls the trace linker and provides the various options it needs and the second part is a standard linker
> +command line you would use to link an RTEMS application. The current command line for trace linker consists
> +of:
> +  $ rtems-tld -h
> +  rtems-trace-ld [options] objects
> +  Options and arguments:
> +   -h          : help (also --help)
> +   -V          : print linker version number and exit (also --version)
> +   -v          : verbose (trace import parts), can supply multiple times
> +                 to increase verbosity (also --verbose)
> +   -w          : generate warnings (also --warn)
> +   -k          : keep temporary files (also --keep)
> +   -c compiler : target compiler is not standard (also --compiler)
> +   -l linker   : target linker is not standard (also --linker)
> +   -E prefix   : the RTEMS tool prefix (also --exec-prefix)
> +   -f cflags   : C compiler flags (also --cflags)
> +   -r path     : RTEMS path (also --rtems)
> +   -B bsp      : RTEMS arch/bsp (also --rtems-bsp)
> +   -W wrapper  : wrapper file name without ext (also --wrapper)
> +   -C ini      : user configuration INI file (also --config)
> +   -P path     : user configuration INI file search path (also --path)
> +The trace linker generates code that needs to be compiled and linked to the application executable so
> +it needs to know the target compiler and `CFLAGS`. There are a couple of ways to do this. The simplest
> +is to provide the path to RTEMS using the `-r` option and the architecture and BSP name in the standard
> +RTEMS format of arch/bsp. The trace linker will extract the compiler and flags used to build RTEMS and
> +will use them. If you require specific options you can use the `-f`, `-c`, `-l` and `-E` options to provide
> +them. If the functions you are tracing use types from your code then add the include path to the `CFLAGS`.
> +The trace linker requires you to provide a user configuration file using the `-C` or ``--config`` option.
> +This is an INI format file detailed in the Configuration section. You can also provide an INI file search
> +path using the `-P` option.
> +If you are working with new configuration files and you want to view the files the trace linker generates
> +add the `-k` option to keep the temporary files, and `-W` to specify an explicit wrapper C file name. If you
> +set the ``dump-on-error`` option in the configuration options section you will get a dump of the configuration
> +on an error.
> +Configuration (INI) files
> +The Trace Linker is controlled using configuration files. Configuration files are categorized into
> +3 types:
> +- User Configuration: These are specific to the user application to be traced. This file initializes the values of the trace generator, triggers, enables and traces.
> +- Tracer Configuration: These are like a library of common or base trace functions that can be referenced by an application. These files tend to hold the details needed to wrap a specific set of functions. Examples provided with the RTEMS Linker are the RTEMS API and Libc.
> +- Generator Configuration: This is used to encapsulate a specific method of tracing. Rtems currently provides generators for trace buffering, printk and printf.
> +The configuration files are in the *INI file format* which is composed of `sections`. Each section has
> +a section name and set of *keys* which consist of *names* and *values*. A typical key is of the form
> +``name=value``. Keys can be used to include other INI files using the include key name. This is shown
> +in the following example where the values indicate rtems and rtld-base configuration files:
> +.. code-block::shell
> +  include = rtems.ini, rtld-base.ini
> +The trace linker also uses values in keys to specify other sections. In this example the functions name
> +lists test-trace-funcs and that section contains a headers key that references a further section test-headers:
> +  functions = test-trace-funcs, rtems-api
> +  [test-trace-funcs]
> +  ; Parsed via the 'function-set', not parse as a 'trace'.
> +  headers = test-headers
> +  [test-headers]
> +  header = '#include "test-trace-1.h"'
> +The format of a configuration file is explained next. Snippets of the fileio-trace.ini file have been used for
> +explicit understanding. This file can be downloaded from `here <https://devel.rtems.org/attachment/wiki/Developer/Tracing/Trace_Buffering/fileio-trace.ini>`_.
> +Tracer Section
> +The topmost level section is the ``tracer`` section. It can contains the following keys:
> +- name: The name of trace being linked.
> +- options: A list of option sections.
> +- defines: A list of sections containing defines or define record.
> +- define: A list of define string that are single or double quoted.
> +- enables: The list of sections containing enabled functions to trace.
> +- triggers: The list of sections containing enabled functions to trigger trace on.
> +- traces: The list of sections containing function lists to trace.
> +- functions: The list of sections containing function details.
> +- include: The list of files to include
> +  [tracer]
> +  name = File IO tracer
> +  ; The configuration
> +  options = fileio-options
> +  traces = fileio
> +  defines = fileio
> +  enables = fileio
> +  triggers = fileio
> +  functions = fileio-funcs, rtems-api, rtems-posix, libc-heap
> +  include = rtems.ini, rtld-base.ini, rtld-trace-buffer.ini, libc-heap.ini
> +Options section
> +The options section in the fileio-trace.ini is called the `fileio-options`. A general options section can
> +contain following sets of keys:
> +- dump-on-error: Dump the parsed configuration data on error. The value can be true or false.
> +- verbose: Set the verbose level. The value can be true or a number value.
> +- prefix: The prefix for the tools and an install RTEMS if rtems-path is not set.
> +- cc: The compiler used to compile the generated wrapper code. Overrides the BSP configuration value if a BSP
> +is specified.
> +- ld: The linker used to link the application. The default is the cc value as read from the BSP configuration
> +if specified. If your application contains C++ code use this setting to the change the linker to g++.
> +- cflags: Set the CFLAGS used to compiler the wrapper. These flags are pre-pended to the BSP read flags if a BSP
> +is specified. This option is used to provide extra include paths to header files in your application that contain
> +types any functions being traced reference.
> +- rtems-path: The path to an install RTEMS if not installed under the prefix.
> +- rtems-bsp: The BSP we are building the trace executable for. The is an arch and bsp pair. For example sparc/erc32.
> +  [fileio-options]
> +  dump-on-error = true
> +  ; Tools
> +  prefix = /development/rtems/5
> +  rtems-path = /development/rtems/kernel/5
> +  rtems-bsp = sparc/erc32
> +  ; Generator options.
> +  gen-enables = enable
> +  gen-triggers = enable
> +Trace Section
> +A trace section defines how trace wrapper functions are built. To build a trace function that wraps an existing
> +function in an ELF object file or library archive we need to have the function's signature. A signature is the
> +function's declaration with any types used. The the signature has specific types we need access to those types
> +which means the wrapper code needs to include header files that define those types. There may also be specific
> +defines needed to access those types.
> +- generator: The generator defines the type of tracing being used.
> +- headers: List of sections that contain header files keys.
> +- header: A header key. Typically the include code.
> +- defines: List of sections that contain defines.
> +- define: A define key. Typically the define code.
> +- signatures: List of function signature sections.
> +- trace: Functions that are instrumented with trace code.
> +[TBD]
> +Function Wrapping
> +The trace linker's major role is to wrap functions in the existing executable with trace code. The directions
> +on how to wrap application functions is provided by the generator configuration. The wrapping function uses a
> +GNU linker option called --wrap=symbol. The GNU Ld manual states:
> +"Use a wrapper function for symbol. Any undefined reference to symbol will be resolved to __wrap_symbol. Any
> +undefined reference to __real_symbol will be resolved to symbol."
> +The trace linker generates C code with a wrapper for each function to be instrumented. The trace code generated
> +is driven by the configuration INI files.
> +Function Signatures
> +A function signature is the function's declaration. It is the name of the function, the return value and the
> +arguments. Tracing using function wrappers requires that we have accurate function signatures and ideally we
> +would like to determine the function signature from the data held in ELF files. ELF files can contain DWARF data,
> +the ELF debugging data format. In time the trace project would like to support libdwarf so the DWARF data can be
> +accessed and use to determine a function's signature. This work is planned but not scheduled to be done and so in
> +the meantime we explicitly define the function signatures in the configuration files.
> +Development
> +The Trace Linker is part of the RTEMS tools git repository available at : https://git.rtems.org/rtems-tools
> +The RTEMS tools project utilizes the waf build system. Use the following commands in the topmost build directory
> +to build the tools project:
> +First we configure using:
> +  $./waf configure --prefix=$HOME/development/rtems/5
> +Then we build and install using:
> +  $./waf build install
> diff --git a/user/tracing/usecases.rst b/user/tracing/usecases.rst
> index 0000000..95a283b
> --- /dev/null
> +++ b/user/tracing/usecases.rst
> @@ -0,0 +1,110 @@
> +.. _usecases:
> +Tracing Use Cases
> +Following are the use cases of the tracing framework that are currently under development:
> +Function Tracing
> +Tracing the entry and exit of a function as well as the values of the arguments and
> +return values can prove to be an important application for the tracing framework.
> +Objective
> +This use case can prove to be helpful in debugging of applications for the users. It can also
> +be used to understand the working of existing application code bases. Capturing of argument and
> +return values maybe useful in tracking unexpected output results from the applications.
> +Requirements
> +The current tracing framework provides this functionality with :ref:`tracebuffering`. The output is
> +provided in the form of printing on console or saving the buffer in the form of a bin file. In order to
> +develop this use case using CTF we need to be able to convert this RTEMS trace output into CTF. This could
> +be done using babeltrace. The converted CTF traces would then be sent over to the host using a transport
> +mechanism.
> +Example
> +As a start to the development of function tracing using CTF we can work on the fileio
> +sample testsuite and trace all the calls to malloc, calloc, free and realloc functions.
> +Along with the calls made to these functions the trace must also capture the values of
> +their arguments at entry and the return values at function exit. As an example of an application
> +having the following progression of function calls:
> +.. code-block:: c
> +  #include <stdlib.h>
> +  int main(int argc, char** argv)
> +    int* a = malloc(sizeof(int));
> +    free(a);
> +    a = calloc(1, sizeof(int));
> +    return 0;
> +The trace of such an application must be output of the following kind:
> +  Timestamp1    entry of malloc > argument value
> +  Timestamp2    exit of malloc < return value
> +  Timestamp3    entry of free > argument value
> +  Timestamp4    exit of free < return value (null)
> +  Timestamp5    entry of calloc > argument1 value, argument2 value
> +  Timestamp6    exit of calloc < return value1
> +There could be additional columns of details including current priority, task state etc.
> +Tracing Thread Operations
> +Tracing thread creation, switching and termination operation in a thread's lifetime within an application.
> +Objective
> +Real time applications inherently utilize parallel programming which entails several
> +tasks executing simultaneously and competing for common resources. On single processor systems
> +the CPU performs context switching between each of these tasks rapidly. By tracing the creation and
> +termination of tasks as well as the context switches between them one can possibly identify probable race
> +conditions or complex threading operations.
> +Requirements
> +[TBD]
> +Example
> +A sample trace tracking two tasks Ta and Tb could have an output of the following kind:
> +  Timestamp1 taskid Ta CREATED
> +  Timestamp1 taskid Ta SWITCHED-IN
> +  Timestamp1 taskid Ta BEGIN
> +  Timestamp1 taskid Tb CREATED
> +  Timestamp1 taskid Ta SWITCHED-OUT
> +  Timestamp1 taskid Tb SWITCHED-IN
> +  Timestamp1 taskid Tb BEGIN
> +  Timestamp1 taskid Tb SWITCHED-OUT
> +  Timestamp1 taskid Tb TERMINATED
> +  Timestamp1 taskid Ta TERMINATED
> 2.7.4
> devel mailing list
> devel at rtems.org
